What Fan is this, TORANA?
33 replies to this topic
#26 _outer control_
_outer control_
Posted 28 August 2014 - 09:59 PM
L34 are 14.75" Wayne, but if they use the same p/n as 6cyl LH (which they do) it musn't be that one as those aren't bent on the ends apparantly.
Thats right Byron thats the size unless a Qld car and some cars up there had bigger ones fitted but all genuine original L34 fans that i can verify as original are all the same but are different to 6 banger fans
#27 _outer control_
_outer control_
Posted 28 August 2014 - 10:03 PM
I picked up 4 NOS 6 banger fans 5 years ago at a swap meet in Perth and they are different to the L34 fans that i have seen even if they are the same part no
#28 _macdou_
_macdou_
Posted 29 August 2014 - 02:55 PM
Which fan blade do you want to do the '73 cutouts to?
Either a standard 15.5" LJ Fan, or a 14 and 9/16" straight fan, of which I only have the curled tip version...
I may just modify a 15.5" fan yet to 14 and 9/16" and then cutout...
#29 S pack
  • 15,541 posts
Posted 29 August 2014 - 03:54 PM
Best to use the 15.5" LJ fan.
#30 _macdou_
_macdou_
Posted 29 August 2014 - 07:04 PM
Just need those elusive measurements Dave. :-)
#31 _SableMet7/73_
_SableMet7/73_
Posted 30 August 2014 - 02:13 PM
Hi, would like to find out if my fan is original for my late July 73 XU1 or something else
thats been swapped out & long gone.
Sorry cant do pics atm
Mine looks like the top 1 in Ken's first pic..
rounded flat blade
tad over 14.75"...(14 13/16ths)
no stenciling to be seen
has only the number "8" stamped into each blade near where they cross & are rivetted.
any help appreciated
Jono
#32 N/A-PWR
  • 9,595 posts
Posted 30 August 2014 - 03:38 PM
Mine is saved from the rust now,
thank's to this thread:-
Torana straight Fan Blade is 15.4 inches, tip to tip ( 391mm ),
2 1/8" water pump PCD ( 54mm ), and no cut-outs:-
Attached File  WP_000097.jpg   70.41K   1 downloads
Attached File  WP_000096.jpg   39.86K   1 downloads
Attached File  WP_000090.jpg   45.44K   1 downloads
Attached File  WP_000091.jpg   67.81K   1 downloads
and I cannot find any number stamped near the rivets hey.
#33 N/A-PWR
  • 9,595 posts
Posted 30 August 2014 - 04:30 PM
http://www.gmh-toran...-xu1-fan-blade/
#34 _macdou_
_macdou_
Posted 31 August 2014 - 07:40 AM
Dave which type of fan did you use to copy your original Bathurst fan cut outs to your spare fan you have made?
