Well done on the video mate, damn she certainly sounds nice at idle!
186 Triple Webers Running Rich
#51
Posted 01 February 2015 - 04:00 PM
#52
_glennhailstone_
Posted 01 February 2015 - 04:31 PM
Posted 02 February 2015 - 06:52 AM
Dynos are for tuning and comparing progress, not for determining how fast the car is.
Even the dyno dynamics shootout software (meant to make any run at any place comparable) is limited in its effectiveness.
Best way to see how fast it is would be the track
So don't stress about the power figure, just enjoy it
#54
Posted 02 February 2015 - 04:31 PM
Ok finally some answers.
You were right orangeLJ, to take it to get put on a dyno was the correct thing to do, after I had got it running the best I could. This is important because if it was running too lean at high RPM apparently you can start welding pistons, not the best thing for a brand new engine. So I recommend this to anybody who has just built a new engine. I didn't know, and a dyno is the only way to be sure.
The outcome of the dyno was that the carbs are set up fine, and all the emission figures are within spec. Its not running too lean or too rich.
I then took it to another carb specialist for a second opinion who immediately asked where my vac advance was. Now, the first guy told me that I didn't need a vac advance because it only helps with fuel efficiency. However this guy reckons that this is what is causing the hesitation at initial throttle.
So, he told me to advance my timing (which is currently set at 12BTDC) by 5 deg and see if it fixes the issue. It did, not completely, but it certainly made a difference.
The reason I didn't have my vac advance set up is that my triple webers did not come with vac advance as an option. It looks like you have to drill new holes in the carbs, which all seems a bit strange.
Anyway, she's putting down 83kw on the ground which isn't much, but not too bad for a little 186.
Thanks for all the help on this thread, I really appreciate it.
Do you have any engine specs? What cam is it running? Head- is it 9 port or 12 port? Is it ported? Also, do you have any idea what compression ratio the engine was built with?
If you can track down this info it would really help us with helping you get the best set-up... You don't need vac advance, however you may need to get your distributor re-graphed to suit the cam as well as the engine compression. If you just give the engine more initial advance at idle, you will also be giving the engine more total advance, which if too much can cause real issues with detonation and melted pistons etc...
For example, 12'BTDC at idle is about right for a mild set-up, with between 32-34 total (again for mild set-up)- a bigger cam will probably want more initial timing (like 16-18) depending on the compression ratio and about 32 total timing...
If you can find more specs we should be able to point you in the right direction!
Edited by LC-GTR-1969, 02 February 2015 - 04:35 PM.
#55
_glennhailstone_
Posted 02 February 2015 - 06:03 PM
Yes I've got all that Mr GTR. I will post soon.
9.2:1 or close to compression. Cam specs I will have to dig out, its a race cam though. Basically its fully worked, the head is a 9 port fully worked, ported, massive valves, polished, roller rockers, and cut out casting bolt housings.
I have another thread going now about the timing curve rate. I have a Bosch HEI and the rate is too fast 16 deg int, 34 deg total, (which is where I want it and where the 3 webers perform at their best with this set up). The problem is its reaching 34 deg too fast, at 2100 RPM where it should be 3000 - 3500RPM.
Now the Bosch dissys seem to be very difficult to change the rate of advance. Like I can't find any spring and weight kits for it.
_Agent 34_
Posted 02 February 2015 - 11:40 PM
Take the dizzy out and send to scorcher ignition or now called performance ignition in Melbourne.
give them the following
application for engine - street - track - strip
cam specs
carby specs
compression
not sure if you need to give the cylinder type
for 120 ( i think) they will re graph to the best settings for your engine- 120 also includes a general service. they have all parts for the bosch to do the job property.
I have had to discussions with ignition places and one (ice) said that you cannot get parts at all and scorcher ( the second ) has them all !
anyway three cents.
#57
_glennhailstone_
Posted 03 February 2015 - 03:10 AM
That sounds like it might be the answer there Grant!
#58
_glennhailstone_
Posted 08 May 2015 - 06:58 PM
I finally found the problem! The cam timing was out! The clues were there when I said about lining the dots on the cam gear and crank gear up. Because I have a wild cam I need and adjustable cam gear.
