* * * * * 1 votes
Project SLR5000 replica / LX Torana Sedan 77
1102 replies to this topic
#376 Bigfella237
Posted 03 March 2017 - 06:03 PM
That distributor pictured above is electronic ignition, it's the HEI (High Energy Ignition) distributor from a blue motor (WB or Commodore), providing it works I'd be using that over a points dizzy any day, although it requires a different coil, leads and some re-wiring of the ignition circuit in a Torana.
It looks like only the bottom half of the cap that's broken and it looks like you're missing the top half of the cap, but I think those large caps hit the firewall in a Torana anyway? You can get a smaller cap and rotor for those distributors, from memory I think there was a ford HEI cap that fitted but wasn't as big as the Commodore one?
But honestly I wouldn't be taking on any new projects for now, just get it running with what you have and worry about upgrades later, unless there's some wrong with your current dizzy of course?
Edited by Bigfella237, 03 March 2017 - 06:04 PM.
#377 _livo74_
_livo74_
Posted 03 March 2017 - 06:47 PM
"..although it requires a different coil, leads and some re-wiring of the ignition circuit in a Torana."
yup. later project!
damn it. i think i bought the new cap too that you are talking about.. only i can't find !
was told to by guy bought car off, and did/tried to. 2 years and many beers ago.
don't think anything wrong with dizzy, he just wanted me to have the better one.
i think i snapped it by having in same box as starter motor, though cant find any broken bits in.
puzzler.
#378 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 03 March 2017 - 07:05 PM
you know what they say about the cat , had a look at a pollution WW stromy (253) , there is a vac. take off marked CAN on the carb. , i am thinking that there was a tube from CAN that led to PURGE on the canister ? (someone might be able to confirm or otherwise ?)
If this is so the then it is ported in a similar fashion as the vac. advance to the dizzy and only operates at part throttle and is fairly restricted by the drill hole sizes  used . It may well work ok connected to full vac. but if the idle speed is too high and there is not enough
adjustment left on the idle screw then i would look at just kinking that tube and see what happens to idle speed once fired up ?
#379 _livo74_
_livo74_
Posted 03 March 2017 - 07:06 PM
see, looks like everybody else's!
doh!!
fine tuning aplenty, (and most don't have clips to secure hoses.)
"purge" to #4 hose was all had and is wayyyy to short. will re-route when have more.
not keeping, but put EXTRA filter so could see fuel when trying to get going.
don't know if good idea or not.
and here is the first of the pcv's as yet.
am going to get an angled tee, so leads to carb better.
.. that said, wondering if i can get a double, like this.
or, the one to the air filter needs to come from other rocker cover.
and haven't connected tee to trimatic and booster as yet.
Edited by livo74, 03 March 2017 - 07:06 PM.
#380 _livo74_
_livo74_
Posted 03 March 2017 - 07:10 PM
sadly eunuch, i again don't understand enough of what you are saying.
but i do know that andrew said he hoped i had an extra port off front of carb to lead to "carb" on canister.. but i don't think that's what you are meaning. Sorry!
(working with me can be a ..tad.. difficult.
noticed..??
it doesn't have any other ports coming off it, other than rear pcv and little one to dizzy vac
Edited by livo74, 03 March 2017 - 07:19 PM.
#381 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 03 March 2017 - 07:47 PM
That's ok ,  and its all a learning curve anyway where we just try and sort things out bit by bit :)
I think what i was trying to say that "if" the original pollution carb. had a line from the PURGE nipple on the charcoal canister to the CAN fitting on the carb. that was "ported", or probably more correctly said, "timed" with a small hole that the butterfly  exposed when at light throttle that those nasty petrol fumes that were "trapped' in the charcoal canister were "purged" or drawn off the canister under vac. and get burnt , and that introducing full vac. to the canister would be like a massive "air leak" ?
Yes ,the holley does not have too many "extras" in the way of vac. take offs hence the comment by another member that the holley
may be a small glitch but things can be overcome in various ways :)
dunno :)
#382 _livo74_
_livo74_
Posted 03 March 2017 - 09:35 PM
 "introducing full vac. to the canister would be like a massive "air leak" ?" doesn't sound good.
might be "crimping" hoses here and there as i was told to do,
to see result/improvements when firing up, and just keep it basic as till then
#383 gtrboyy
gtrboyy
  • 3,241 posts
Posted 04 March 2017 - 12:26 AM
Ditch glass filter...when it's running you'll see fuel in plastic filter easily enough.
If I was doing it for first start up I'd use gerry can or 1 litre bottle(long hose off fuel pump)...that factory tank will need a good cleanout..bet ya smells like paint stripper & manky rusted water.
Ps Looks like that new rotor(xd falcon??) button is for small cap so it's probably hiding somewhere,check if points one fits (search on forum to be sure)
     Coil looks 6cyl hei,bolt it to the exposed bolt hole 4 inches behind 'firing order'
*Hose from vacuum tree to modulator should be ok...can check again later when it drives.
*starter motor looks like chunky earlier version,will be fine with cast headers...check that it works off the car then use it untill it dies,get proper factory bolts
Not keen on purge line like that...rather glue fake nozzle underneath aircleaner or carb for it.
Same with pcv hose off rocker cover goes to fitting underneath aircleaner...then VAC hose off canister to that.(My guess)
How's that for sensory overload haha
#384 Bigfella237
Posted 04 March 2017 - 05:55 AM
I can't remember exactly but I think there's a twist to that PCV valve, I think the top port 'controls' when the lower port opens, or something like that?
Are you running the auto trans cooler lines to the radiator (is that even a radiator from an automatic car)?
Or are you using a dedicated transmission cooler? If so, you'll need to get your air con condenser mounted in front of the radiator first, then mount the cooler in front of that.
I would definitely install and test (or test and install) the starter motor before installing the exhaust, if you're gonna test it on the car, make sure you have engine oil and trans fluid before turning it over (do you even have a tailshaft in yet)?
Did you get the speedo cable in too? Did you happen to see what coloured speedo drive gear was inside the trans? If we know that, and your diff ratio and tyre size, we can tell you how accurate your speedo will read and which driven gear you need to fix it?
EDIT: I've been meaning to mention as well...
I'd be a little concerned with the way those heater hoses are angled too, there's a good chance you will get two pockets of air trapped in those? Is there any way you can turn them clockwise so they run flat or is that second bend moulded into them?
Technically the radiator cap is supposed to be the highest point in the cooling system so any air pockets find their way there and are expelled automatically when the system builds pressure, but I don't know if the flow through those heater hoses would be enough to push such a big air bubble through?
Edited by Bigfella237, 04 March 2017 - 06:06 AM.
#385 _livo74_
_livo74_
Posted 04 March 2017 - 09:42 AM
ok, here goes fellas.. (and gtr, being capable of dealing with sensory overload is not my.. specialty ;) )
1 -will ditch glass filter...
2 - FUEL TANK
-never done before/or researched, classy aye!
..but imagined before ran car was going to open/disconnected fuel line at engine bay.. and point hose into a jerry can ,
-then, pour in 5 litres, send power to fuel pump? (or are they solely mech?), then run pump till tank empty, ...
-repeat another 3 times... to have cleaned tank... and then THROW AWAY the petrol,
- and then reattach fuel line, and fill tank with new petrol
or... use jerry can as gtr said ??
3 - DISTRIBUTOR
re: "new rotor(xd falcon??) button is for small cap so it's probably hiding somewhere,check if points one fits"
- will take photo's of the rotor and serial, will look for new cap i bought.. or tried to buy.. but failed? something happened, can't remember
4 -COIL
"Coil looks 6cyl hei,bolt it to the exposed bolt hole 4 inches behind 'firing order'"
-ok, will do
5 - VACUUM TREE AND MODULATOR
"Hose from vacuum tree to modulator should be ok...can check again later when it drives."
-here i go again;) what's a modulator? which vac tree? the one behind carby?
6 - STARTER MOTOR
"starter motor looks like chunky earlier version,will be fine with cast headers...check that it works off the car then use it untill it dies,
get proper factory bolts"
and
" I would definitely install and test (or test and install) the starter motor before installing the exhaust, if you're gonna test it on the car,"
- will test off car.
??in a vice, or on floor.... and just plug power to it??
- damn, i bought NEW bolts off ebay for it, will show a pic to see if right ones.
7 - CANNISTER PURGE LINE
"Not keen on purge line like that...rather glue fake nozzle underneath aircleaner or carb for it.
-will block off #4 for now ?,
- and not run canister purge anywhere for now maybe.
-i can glue fake nozzle underneath aircleaner or carb for it, if needed easily
8- PCV VALVE AND HOSE
-was planning on running TWO pcv's
-one from pcv hose off rocker cover goes to fitting underneath aircleaner...
and one from back of carby to the other rocker pcv
(all trickiness caused because my carrby doesn't have the usual carby port on front of it.. to simply run to canister "purge", i believe. )
re: "then VAC hose off canister to that.(My guess)"
- none of canister ports are labled "vac".. do you mean "carb", "tank" or "purge"
9 - DUAL PCV
throw away
10 - TRANS COOLER
"Are you running the auto trans cooler lines to the radiator"
-surprise! i have no idea. (slaps forehead) will post pics of what i have
"Is that even a radiator from an automatic car"?
. um. hmm. again, will post pics
"Or are you using a dedicated transmission cooler? If so, you'll need to get your air con condenser mounted in front of the radiator first,
then mount the cooler in front of that."
(i do have another two smaller radiators, but it think are for AIR CON. ?? will post pics)
-was given radiator with car. believe is V8.
-and, is it better to run DEDICATED trans cooler?
or... simpler to run lines into main (proper/correct AUTO) radiator?
- will buy new one if need to
11 - HEATER HOSES
"Technically the radiator cap is supposed to be the highest point in the cooling system"
- wondered about that.
-and, that is how they are molded.
-tried to look at other pics, but always seem to be hiding behind "air cleaner" in pics of others engines.
-they are FAR higher than radiator cap, at present
-turning clockwise (in pic) might help,will try,
-anti might too, as would PULL away and lower height, i have been suspecting
12 - TAIL SHAFT
-i have one... was given with car. will post pics. (might be off a six/wrong one)
-is not connected. (nothing was. dont even have engine mount bolts, just "plonked in", was told.) *must remember to buy Mount Bolts!
13- TRIMATIC
-i STILL don't as yet have the selector rod and plate, so trans not connected to tbar at all, as yet
14 - AAARGH!!!!!!!!!
-Aaargh!!
i have too many unknowns, will take a lot of photos, will post asap
Edited by livo74, 04 March 2017 - 09:47 AM.
#386 Bigfella237
Posted 04 March 2017 - 10:30 AM
Errgghh, I'm just gonna pick a few things from that list...
1. may as well leave that glass fuel filter where it is for the initial start up, the more filters the better for now!
2a. looks like you just have a standard mechanical fuel pump it won't pump unless the engine is running.
2b. the only way to really clean a fuel tank is to remove it so you can slosh it around and drain every last drop (the fuel pickup never gets the last little bit on the bottom of the tank and that's where any water/rust/crud/etc. will be). You can get fuel tank "treatments" that leave a coating on the inside of the tank but you still have to clean it properly first.
If you're not going to pull the tank out, then you can put some fresh fuel in, disconnect the fuel line from the fuel pump and siphon it through the line to the front of the car yourself (try not to swallow too much), in this case, include a couple of litres of mentholated spirits in your first flushes (it absorbs water).
5. the modulator is the round thing on the back of the transmission that the vacuum line plugs into
7. you already have the PURGE line connected so leave it now until the engine runs, you can test whether it draws too much vacuum then.
8. no point running two PCV valves, the hose to the second rocker cover (which you don't have a hole for BTW) is just an open hose which runs into the air cleaner, it just vents crankcase fumes into the air cleaner instead of the atmosphere... more pollution crap that you don't really need.
10. radiators from automatic cars have an extra tube inside the lower tank (you will see two 1/4" flare nut fittings on the back of the lower tank), the oil lines from the trans goes into one end and out the other just to cool the fluid, or you can buy a separate trans fluid cooler, like a mini radiator.
You can simply leave those fittings on the radiator open (disconnected) if not used, the pipe inside the radiator is sealed off from the coolant.
12. tailshaft... who knows! All the yokes on the back of Trimatics are the same, but I think you said this car was originally a 4 cylinder, which I think have the same diff yokes as 6 cylinders? But V8's have a bigger diff yoke and different length tailshafts.
All you can do is crawl under there and see if it fits I guess, if it's the right yoke it will probably be the wrong length and vice versa.
Do you know what diff ratio is in the car now (if it's the original diff, tell us what the "RR AXLE" code is on the body plate (passenger's side engine bay))?
#387 _livo74_
_livo74_
Posted 04 March 2017 - 11:01 AM
massive cheers andrew! have tried to incorporate answers :)
________
1 -will leave glass filter... till cleaned tank
2 - FUEL TANK
 -ok, gothcha
-ok, gotcha. not sure in or out as yet.
3 - DISTRIBUTOR
pic
-i take it i need to buy "upper and a lower " caps ??
4 -COIL
-ok, will do
pic
re: " the modulator is the round thing on the back of the transmission that the vacuum line plugs into"
-ok, gotcha
6 - STARTER MOTOR
and
pic
 re: already have the PURGE line connected so leave it now until the engine runs, you can test whether it draws too much vacuum then.
-ok, will leave for now
and,
"can glue fake nozzle underneath aircleaner or carb for it,"
-can do if needed to get rwc :)
re:  "no point running two PCV valves, the hose to the second rocker cover (which you don't have a hole for BTW) is just an open hose which runs into the air cleaner, it just vents crankcase fumes into the air cleaner instead of the atmosphere... more pollution crap that you don't really need."
-thought was doing so as to look right for rwc. can leave and worry about later.
9 - DUAL TIP PCV
throw away
10 - TRANS COOLER
pics
-auto, now ..i think ?!
re:adiators from automatic cars have an extra tube inside the lower tank (you will see two 1/4" flare nut fittings on the back of the lower tank), the oil lines from the trans goes into one end and out the other just to cool the fluid
- will buy trans oil lines!
11 - HEATER HOSES
12 - TAIL SHAFT
re: tailshaft... who knows! All the yokes on the back of Trimatics are the same, but I think you said this car was originally a 4 cylinder, which I think have the same diff yokes as 6 cylinders? But V8's have a bigger diff yoke and different length tailshafts.
-car was a six originally
-rr axle  is plated "GV4"
pics
re: "All you can do is crawl under there and see if it fits I guess, if it's the right yoke it will probably be the wrong length and vice versa"
-fun!
13- TRIMATIC
-Aaargh!!
__________
15 - AIR CON
wasn't planning to worry about till far later date! have enough on plate, maybe ;)
16- SPEEDO CABLE
re:Did you get the speedo cable in too? Did you happen to see what coloured speedo drive gear was inside the trans? If we know that, and your diff ratio and tyre size, we can tell you how accurate your speedo will read and which driven gear you need to fix it?
-not as yet looked/attempted
gotta jack up car
Edited by livo74, 04 March 2017 - 11:12 AM.
#388 Bigfella237
Posted 04 March 2017 - 11:24 AM
"GV4" is a 3.36:1 diff ratio
What size are your rear tyres (they look something like 245/60R14)?
#389 _livo74_
_livo74_
Posted 04 March 2017 - 11:27 AM
245/60R14
correct!
(and, side note:  lucky i didn't try to fit them to the front!   as are about an inch TALLER than the 225/60/24's on front, ..would never fit inside the flares/firewall!)
*which i thought was weird!
thought a "60" wall was a set "60" wall.
but no.   is a heaps taller/bigger diameter tyre
Edited by livo74, 04 March 2017 - 11:29 AM.
#390 _livo74_
_livo74_
Posted 04 March 2017 - 11:36 AM
re: help!!!!!!!!
never mind, got it ALL sorted.
..just bought a can of  "Start  ya bastard!" off ebay.
so,
will be going in no time!!
hahaha!
#391 Bigfella237
Posted 04 March 2017 - 11:56 AM
Okay some "fun with numbers":
Tyre Size = 245/60R14
Tyre Revolutions = 490 per km
Diff Ratio = 3.36 : 1
5000 RPM in 1st Gear (2.31 : 1) = 79 km/h
5000 RPM in 2nd Gear (1.46 : 1) = 125 km/h
5000 RPM in 3rd Gear (1.00 : 1) = 182 km/h
5000 RPM in Rev Gear (1.85 : 1) = 98 km/h
This does not account for any torque converter slippage. I can change the RPM figure above if you want?
Gear Ratio = 1.00 : 1 (drive / third gear)
40 km/h = 1098 RPM
60 km/h = 1646 RPM
80 km/h = 2195 RPM
100 km/h = 2744 RPM
120 km/h = 3293 RPM
140 km/h = 3842 RPM
160 km/h = 4390 RPM
200 km/h = 5488 RPM
So your 3.36 diff will be good fun around town, but probably annoying if you plan to spend any length of time at highway speeds?
As far as your speedo goes, we know you have a red driven gear (on the end of the cable) so
IF you have a red drive gear (inside the trans) then your speedo will read very slow (reading 80.1km/h at 100)
IF you have a white drive gear then your speedo will read a little slow (reading 91.6km/h at 100)
IF you have a blue drive gear then your speedo will read a little fast (reading 103km/h at 100)
IF you have a yellow drive gear then your speedo will read a lot fast (reading 114.4km/h at 100)
Once you confirm the colour of the drive gear we can change the gear on the cable to fine tune the speedo reading, for example IF you have the white drive gear, you will need to change the driven gear (on the cable) to a green (21 tooth) gear, which will give you a speedo reading of 100.3 at 100
You can either hunt around for one second hand or hit up Rare Spares for replacements, for example:
http://www.rarespare...cription=SG1008
P.S. Don't even try that tailshaft into the transmission without first scouring all the rust off that slip yoke, otherwise you'll damage the rear seal and possibly the bush in the extension housing!
Edited by Bigfella237, 04 March 2017 - 11:58 AM.
#392 Bigfella237
Posted 04 March 2017 - 12:29 PM
The "60" is a percentage of the width, so a 245/60R14 tyre is 245mm wide and has a (60% of 245 = ) 147mm high sidewall
A 225/60R14 is 225mm wide and has a (60% of 225 = ) 135mm high sidewall (12mm less)
Remember that you have sidewall at the top as well as the bottom so the overall height of the rears would be 24mm (or roughly 1 inch) bigger
#393 _livo74_
_livo74_
Posted 04 March 2017 - 01:07 PM
"This does not account for any torque converter slippage. I can change the RPM figure above if you want?"
yes, change so i can understand! haha
i think/imagine i have standard torque converter, soo... don't know if change necessary,
or for what ever reason would be!
will stick with those numbers for now i'm guessin'!
"So your 3.36 diff will be good fun around town, but probably annoying if you plan to spend any length of time at highway speeds?"
annoying it is then!
..as ALL i have around me are 100kph zones.
oh well, at least i have only intention of "cruising" around, say 80-95 at most.
(if the old girl gets up to that speed!)
am hoping for a BLUE drive gear then!
will see, and search for the corresponding cable color as you say.
_____
which end is slip yoke?
(sorry!)
ah!!!! "60" is the PERCENTAGE! gotcha, thought was mm height something, obviously
#394 _76lxJAS_
_76lxJAS_
Posted 04 March 2017 - 01:54 PM
Left side of your photo is the slip yoke./the end that goes into the box.
As said above give it a good clean before fitting it so it don't damage the seal in the box.
Also when cleaning try to go in circles around the yoke. Not up and down as the up down marks can cause it to leak.
Use a very fine emery paper then some scotch Brite with some crc etc to clean it until u get it nice as smooth.
Edited by 76lxJAS, 04 March 2017 - 01:55 PM.
#395 _livo74_
_livo74_
Posted 04 March 2017 - 02:09 PM
cheers jas!
imagine you and andrew were saying scouring/clean the "outer" surface..
(and not the inside/splines..??)
#396 _livo74_
_livo74_
Posted 04 March 2017 - 02:27 PM
continued incorporated answers
(i get flustered and forgetful, so continually adding so as not to forget)  :)
________
2 - FUEL TANK
 -ok, gothcha
3 - DISTRIBUTOR
pic
-later date upgrade, if want.
-buy "upper and a lower " caps, coil etc
4 -COIL
-ok, will do
pic
-ok, gotcha
6 - STARTER MOTOR
and
-starter works! (engages/spins)
and,
9 - DUAL TIP PCV
throw away
10 - TRANS COOLER
pics
11 - HEATER HOSES
12 - TAIL SHAFT
pics
-fun!
13- TRIMATIC
-Aaargh!!
__________
15 - AIR CON
16- SPEEDO CABLE
gotta jack up car
Edited by livo74, 04 March 2017 - 02:35 PM.
#397 _76lxJAS_
_76lxJAS_
Posted 04 March 2017 - 04:44 PM
Yes clean up the outside of the yoke clean and smooth. Wouldn't hurt to get a tooth brush and some spray to clean up the inside splines also. Ya can get small tooth brush size wire brushes they would make it easier to clean up the splines.
#398 _livo74_
_livo74_
Posted 04 March 2017 - 05:19 PM
cool, can do!
#399 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 04 March 2017 - 05:34 PM
You might find that with the lectronic dizzy  it looks like once the "lower" bit that is broken is taken off the dizzy it might reveal that the dizzy will take a standard cap and rotor ? , i think the bit in between was only an adapter to take a bigger cap which was supposed to have had something to do with genetic engineering in the spark school that was an attempt to space out the posts that led to the leads and plugs to stop "cross fire" within the cap ?
Maybe take the broken bit off and put up a picture so that we might be able to see what can be done , if it is just a stock body then it is a hell of a lot easier just to put on a stock cap and rotor and retain the lectronic side of things , it won't arc over , i put the guts of one of those electronic setups into a points body dizzy and had no trouble , just be careful with the stuff inside the dizzy , there are some very fine wires on the coil , when i say fine i mean like about .04mm and they can be damaged easily and i am not sure if you can still get the pick up coil anymore ?
#400 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 04 March 2017 - 06:25 PM
By memory the dissy cap & rotor button is 351 Cleveland xd falcon. Repco stock them, can't remember the part numbers & i think when running the 2 breathers that the pcv went from the passenger side rocker cover to the back of the carby, under throttle plate & the drivers side rocker cover vented to under the air cleaner base. The vacuum tee has the brake booster vacuum pipe & the line to the vacuum modulator on the transmission ( make sure it's clean inside the tee or the trimatic changes are pretty ordinary ) coils are pretty cheap so I'd buy a new 1, the vs v8 starter is very easy to fit in with extractors anyway so that would be what I'd use when you need to replace it. Personally I'd run a separate Trans cooler with a good gap to the air con condenser, pwr coolers are stocked at repco too & cheap enough. 3.36 should be fine in that i have run 3.9 on 50 series tyres on the highway before with a trimatic, got of the line quick though
