The ones on the pink one stops short of the badge Grant. But they are also upside down lolI think it is correct.
But I could be wrong.
I know mine doesn't, but I think it should
IMORAL has a baby brother
#126
Posted 22 August 2016 - 09:18 AM
#127
Posted 22 August 2016 - 10:36 PM
Restored dash turned up and couldn't be happier
From this
(That's not my place so no I don't have those parts in the back ground forsale )
To this in only a week
So decided on the way home the orange red motor needs to be red
Bit of tape, cardboard and plastics here and there and she's done
Had one fan of the job done
#128
Posted 22 August 2016 - 10:46 PM
#129 _LS2 Hatch_
Posted 22 August 2016 - 10:47 PM
I would love to repainted my engine in the LC, it lets the rest of the car down.
Don't know if I will be able to get under the tripples though
#130
Posted 22 August 2016 - 10:51 PM
You need a nice shiny glass bowl fuel pump lol
Yeah. Im waiting
#131
Posted 22 August 2016 - 10:54 PM
How much of a prick was it to mask up?
Not as bad as I thought. I got a set of tripples for it so if I put them on I'll pull the extractors off and get the back part of the block.
Its far from your car Grant so this will do. Something like yours it would probably be quicker and easier to just pull the engine out imo
#132
Posted 22 August 2016 - 10:57 PM
Yeah. Im waiting
Patience grasshopper
#133 _LS2 Hatch_
Posted 23 August 2016 - 05:54 AM
Thanks for the advise, might give it a skip for a while.
I do like the idea though.
Well done
#134 _Bomber Watson_
Posted 23 August 2016 - 02:35 PM
#135
Posted 23 August 2016 - 03:16 PM
Good tip. That's a great idea.Hot tip for that kinda job, alfoil is real handy over wiring and the like....
I just pulled the wiring out as I'm changing it but will try that should the need arise. The stuff on the inner guard was under a plastic sheet but its also getting changed.
#136
Posted 23 August 2016 - 03:18 PM
#137
Its not that bad to do Grant. Especially on that rig of yours. You'd be surprised where you can get the paint to go. I'm still shocked I didn't end up with over spray every whereThanks for the advise, might give it a skip for a while.
Well done
#138
Posted 23 August 2016 - 03:19 PM
#139
go send those bolts! Ya holdin the entire job up! typical bloody tiler!Do some work ya slack dogs
#140
Posted 23 August 2016 - 03:20 PM
#141
Gene. You said a similar thing one minute ago. You realise this is the first signs........Do some work slacker
Edited by IMORAL, 23 August 2016 - 03:24 PM.
#142 _Skapinad_
Posted 23 August 2016 - 05:40 PM
Only one not working is Geno. We know he can't operate a smart device so obviously at home when making those posts...
#143
Posted 23 August 2016 - 06:10 PM
#144
Posted 23 August 2016 - 10:25 PM
That fuel line going to the pump is a shocking job
I didn't do it
That said it supplies the required fuel so it's doing its job so shut up
#145
Posted 27 August 2016 - 04:15 PM
Cut the plastic off the crimps. Then crimped, soldered and heat shrink
Rewired the dash because I changed from a circuit board one to no board
Just has two plugs to undo
After putting the dash in and out 30 times it's finally done
Then pulled the indicator switch apart to get the horn working and put an aftermarket wheel on. The Gtr wheel can go on the Gtr when I get to it
Then pulled it back off cos while cleaning up I found the circlip I forgot to fit. Dough!
Just got to finish off the wiring under the dash and fit carpet and inside is done!
#146
Posted 27 August 2016 - 04:47 PM
#147 _Skapinad_
Posted 27 August 2016 - 05:09 PM
Can you get one piece aftermarket carpet for the little toranas ?
#148
Posted 28 August 2016 - 08:27 PM
Dunno. Was just going to get a caddy boot mat and trim it downLooking good mate.
#149
Posted 28 August 2016 - 08:57 PM
Dont think you canLooking good mate.
#150
Posted 29 August 2016 - 11:31 PM
Door trims back on
All wiring is done a shit even works so happy days
Grille and hl surrounds back on. I wanted to get them refirbed but brought new bumpers instead
Didn't have the bracket or switch for the hand brake so welded a couple of m3 bolts to the hb and fitted a limit switch I had laying around so the brake light now works in the dash
Gave it a squirt of paint while it was out
Made a couple of hinge pin removers on the weekend ready for when I start the Gtr
Sold most of my model cars years ago but still kept the torries and Walky.
I reckon it's a close colour match
Took them out of the cupboard and put the in a display thingo in the shed now
Probably will be broken in a week cos something things get thrown around in there lol
