JOHN BOWE TO RACE TORANA TCM
#26
Posted 14 May 2015 - 10:15 AM
#27
Posted 14 May 2015 - 11:19 AM
Pre 76, 245 fronts and 275 rears for all.
5 litre Holden or Chev for the Toranas.
That would be cool if you could run somethink akin to a 1969 Z28 spec 302 SBC with a Tremec or Muncie and a 9" rear axle. Would make an LH a decent race car with brake and suspension mods.
#28
Posted 14 May 2015 - 12:11 PM
#30
Posted 15 May 2015 - 10:07 PM
9 inch diff by race products, most use either tex racing 4 speed(full house spec t10) or jerrico(nascar spec).
There are weight limits, torana allowed to run lighter due to 5litre engine, less power.
Common wheel and tyre sizes.
And a rule some people won't like, torana is allowed to use the 5litre chev engine due to been able to get cheaper/reliable more power.
#31
Posted 16 May 2015 - 06:43 AM
The TCM specs are pretty wild now, most are running similar things.
spec).
This ones running a Holden V8 I read.
#32
Posted 16 May 2015 - 08:27 AM
I was watching the TCM practice on Fox yesterday, this one uses a 308 and as a result is allowed to be 100kg lighter. Limiter set to 8000rpm. The cars that run a 302 have to carry an extra 100kg as the Chevs produce more power. Commentators were saying though that there are smart 308 builders in Australia with bulk Commodore Cup and similar experience that can pull 580hp out of one under the rules but the challenge is keeping them together. Apparently they were popping the heads last year.
#33
Posted 16 May 2015 - 10:09 AM
Block strength is not as good with holden.
Torque power have addressed the issues with holden motors with there new little paw iron block and heads with extra bolts, they shld fill the void and push the holden motor forward, yay for us holden fans.
Always going to be hard on the big tracks to run down the fords bigger engines.
Fords are allowed rack and pinion steering and most cars use similar brake setups too.
Love these cars, better to watch than the v8's
#34
_Marco72_
Posted 16 May 2015 - 10:30 AM
#35
_ChaosWeaver_
Posted 16 May 2015 - 11:02 AM
Twin Turbo's under the engine...... no one will look there ..
#36
_Baronvonrort_
Posted 16 May 2015 - 12:32 PM
Bowe put it on pole and won the first race.
#37
Posted 18 May 2015 - 05:43 PM
Well 3 from 3. Bowe is the master.
#38
Posted 18 May 2015 - 06:50 PM
Well done Gary and the boy,s in bendigo for building the car the 308 is back!
#39
Posted 21 May 2015 - 07:39 PM
Is JB driving the SLR/5000 at Hidden Valley or was it just a one off drive.
#40
Posted 21 May 2015 - 09:23 PM
#41
_ChaosWeaver_
Posted 22 May 2015 - 11:47 AM
#42
Posted 22 May 2015 - 02:35 PM
Awesome.
#43
_The Baron_
Posted 22 May 2015 - 03:43 PM
#44
_big jack_
Posted 22 May 2015 - 04:44 PM
Go you good thing.
#45
_reefhog_
Posted 22 May 2015 - 05:28 PM
#46
_Baronvonrort_
Posted 22 May 2015 - 05:43 PM
Bowe put it on pole.
He won all the races
Set fastest laps and I think a new lap record.
Didn't scratch the car
I can't see any reason why the car owner wouldn't let him have another go,i reckon Bowe could be keen.
It was hitting good speed on the s/f straight not far off a V8 supercar,the gearing for a shorter track could have helped with 4 speed box.
I reckon it will go ok at longer tracks if they put a good driver in it.
#47
Posted 22 May 2015 - 11:10 PM
Awesome vid.... "I just want one" !!!
#48
Posted 24 May 2015 - 11:03 PM
#49
Posted 25 May 2015 - 07:48 AM
#50
_ChaosWeaver_
Posted 25 May 2015 - 04:14 PM
Looks wicked.... how good to see a Torana up the front.... where they belong...
And hopefully this will work too...........
https://www.youtube.com/watch?v=m0oGzU3LFEw&feature=player_detailpage
