To say I've given this subject a little thought would be the understatement of the year, I more or less decided to go with a parallel centred 3-link with a screw-adjustable Watts Linkage (for roll centre adjustment), not using any of the factory mountings so as to fit the longest trailing arms possible.
An offset 3-link is a slightly better design because it will reduce torque-steer but I have to consider the packaging, I don't want to end up with a stripped-out two-seater race car with bar-work running everywhere. (I didn't draw this but it's close to what I was thinking)
20131021_rear_susp.png 440.74K
9 downloads
The sway bar and Watts Link need to be mounted to the body not the diff, unsprung weight is something that needs to be reduced as much as possible, I even gave some thought to a dry sump system for the diff, that may sound weird but the diff oil accounts for a couple of extra kilos of unsprung weight, you'd have to remove a lot of metal to make up 2kg.
As 76lxhatch said in post #4, I'm pretty confident that a centre trailing arm to body mount can be made strong enough yet still retain two rear seats, the only load should be fore/aft as the Watts Link accounts for any lateral load?
You would need to relieve part of the floor pan above the diff centre to make room for the upper mount but that space is wasted below the false floor in a hatch anyway so no loss there. You'd also have to modify the boot floor / spare wheel hump (which means custom fuel tank) as well as adding a couple of extra cross-members between the rails for mounting points, but you should still get away with that without it becoming an ICV?
I'd want to incorporate a vertical screw adjuster to the body-end of the upper trailing arm instead of simply having a couple of holes though, this is the anti-squat adjustment and without a threaded adjuster you'd have to remove half the rear trim and have two people to fine tune.
Top Link Remote Adjuster.jpg 4.58K
9 downloads
I've read good things about using a tuneable torque-box in the upper arm to absorb some of the shock-loads too.
Top Link Torque Absorber.jpg 25.67K
6 downloads
Most of this comes from Ron Sutton's thread over on the Pro Touring Forum, well worth the read if you haven't already.
