Electric handbrake
8 replies to this topic
#1 _1275greg_
_1275greg_
Posted 12 February 2019 - 07:18 AM
Wondering if anyone has fitted an electric handbrake from a late model car, or has any info on the wiring side of things and what’s required, considering one as an option on our hatch
#2 dattoman
  • 16,472 posts
Posted 12 February 2019 - 08:53 AM
Factory ones are a nightmare
But you can buy an aftermarket hotrod style one
Which is just a pull type solenoid attached to a lever on the caliper
https://www.trwafter...park-brake-epb/
https://totalability...DUaAuZYEALw_wcB
https://www.estopp.com/
#3 bat 53
bat 53
  • 493 posts
  • Name:albert
  • Car:lc gtr
Posted 12 February 2019 - 09:38 AM
yes mounted a vf one on a custom at4 pickup
removed the electonics and operated it manualy
put a brake light switch on the cables connected to a light
light on brake on
cheers  bat
#4 _1275greg_
_1275greg_
Posted 12 February 2019 - 09:46 AM
Thanks for the links, I’ve sent off a couple of enquiries, the car will have to be engineered so might have to stick to an off the shelf option unfortunately.
Bat did you have to modify the unit itself or just do your own wiring?
Greg
#5 Bigfella237
  • 4,377 posts
Posted 12 February 2019 - 11:27 AM
A few more links for aftermarket options, these first two appear to be a Chinese company:
https://www.artc.org...il.aspx?pdid=34
https://www.artc.org...il.aspx?pdid=35
And this one is Bluewire Automotive here in Australia:
https://bluewireauto...-20th-july-2013
Although I'm not sure if they still sell these as I can't find them listed in their catalog? But they were a US brand called "American Shifters", see here:
https://www.american...ency-brake-kits
#6 _1275greg_
_1275greg_
Posted 12 February 2019 - 08:38 PM
thanks mate, time to read up and have a chat to the engineer to see whats required
#7 rodomo
  • 17,999 posts
Posted 12 February 2019 - 09:19 PM
+1 :spoton:
#8 bat 53
bat 53
  • 493 posts
  • Name:albert
  • Car:lc gtr
Posted 13 February 2019 - 11:07 AM
when you pull out the electonics there are only 2 wires left
the dodge had to go through engineering also
i fitted cmplete front and rear suspension from a vf commodore onto the dodge chassie
with the L98 6lt
passed all tests
cheers  bat
#9 _1275greg_
_1275greg_
Posted 14 February 2019 - 03:29 PM
Cheers bat sounds like a good option
