Little Rotary
#1 _Lostit_
Posted 25 August 2006 - 11:08 PM
ANyway ill put some pics up once i figure how to load it here.. unless some one can explain in lameman terms hehe.
ANyway plans for the little buzz box.
New Powerglide with steel hub,few more clutches,full manual and transbrake set up.
As for motor will be pulling it down checking bottom end replace bearings if needed and tidy up, as for headwork well see if we can extract some more flow out of them . Throwing the solid out and going roller cam , that doest allow a coke can to stand on the bonnet when its idling ) .
Upgrade fuel system and brakes .
Was hoping to redo the paint a little but i think ill leave it this time and look at it possible end of next year.
Hopefully all this by the end of the year finished , and get to the Nats with it , if not then a low 10 to high 9 sec pass will do me happily , since it still is a street car . )
Denis
Lostit
Pics asap when i work them out )
#2 _Keithy's_UC_
Posted 25 August 2006 - 11:16 PM
Keith
#3 _Lostit_
Posted 27 August 2006 - 09:25 PM
http://img228.images...dsc00107pv1.jpg
http://img228.images...dsc00108yx0.jpg
http://img228.images...dsc00109gw4.jpg
http://img228.images...dsc00110nn0.jpg
http://img228.images...dsc00104vw0.jpg
As you can see not much room at all had to pull motor outwards with transmission next time thinking i might drop the whole front end and wheel it out.
Anyway time to clean it all up and then sort out the motor and box .)
Denis
Lostit
Edited by Lostit, 27 August 2006 - 09:27 PM.
#4 _JBird_
Posted 27 August 2006 - 11:03 PM
either way looks like itll go fast as ****
#5 _Keithy's_UC_
Posted 28 August 2006 - 09:01 AM
Keith
#6 _gtr-xu1_
Posted 28 August 2006 - 09:21 PM
#7 _LX8VD69_
Posted 28 August 2006 - 09:34 PM
#8 _Lostit_
Posted 29 August 2006 - 01:12 PM
I brought this car off a decrease estate... luckily not in the car.
Only changes ive done to it is change heads, since old ones developed a crack ( , carb , and ignition system. And the rear end
BAsic specs of the car atm are
Motor :
400 chev
brodix heads
11 to 1 comp ( aluminium heads dont you love em .. runs on prem leaded )
solid cam
850 dp holley
Ice ignition
Powerglide, manual valve body, 4500 conv
35 spline,3.9 ratio Moser diff centre
Most of these will be changed even thinking of going to 3.5 or 3.7 ratio in rear end since the torque of the motor i run out og legs before the 400m mark ( .
PS.. Oh yeah totally forgot yes, its totally reistered and RWC.. and this has been proven , thank you TOG in Epping area.. which have pulled me over no less then 5 times in the last year .)
No sir it doesnt have nitrous no need )
Lostit
Edited by Lostit, 29 August 2006 - 01:13 PM.
#9 _Lostit_
Posted 28 December 2006 - 09:01 PM
Just got my Auto back a few days ago .This wont breakdown ) .
Cut out the top of tunnel and replaced with new sheetmetal since who every had a play with it last butchered the crap out of it.
Hopefully in the early part of the new year will get to the motor. /fingers crossed
Denis
#10 _1QUICK LJ_
Posted 28 December 2006 - 11:10 PM
Posted 28 December 2006 - 11:40 PM
You've only just got the auto back after finishing it off at the GMH drags early in 06!? I thought I took ages to do stuff! hehehehe
Cant wait to see this thing in full anger mate! Looks like you'll be ready for the next drag day! YES!!
Cheers mate!
#12 _lurkin308_
Posted 29 December 2006 - 12:02 AM
PS.. Oh yeah totally forgot yes, its totally reistered and RWC.. and this has been proven , thank you TOG in Epping area.. which have pulled me over no less then 5 times in the last year .)Nah im on the right forum... always a torana nut... but i couldnt find a decent lc/lj for 6 months when i was looking for one.
Motor :
400 chev
brodix heads
solid cam
850 dp holley
Ice ignition
Lostit
was it bateman hes a tog
#13 _Lostit_
Posted 30 January 2007 - 04:35 PM
Just a update and not too bloody happy atm.
Decide to drop sump off while its out of car, and discovered the xxxx who build the bottom end . put some sort of crappy oil pump ,pickup . probadly why its low psi on oil at idle sucking in air.
So anyway atm sourcing out to put a remote oil pump setup with new pan. but at this rate looks like a complete dry sump system for just a few more $$$. ANd if im going to do this i might as well do the motor up .
No wonder chev+rx4 = rare as dog Sh!t. this is why they put windsors ( ford crap) in them. pick up and stuff at front of motor with plenty of room.
So ill close the garage door and decide which lub im going to use so my butt cheeks dont hurt too much .
Ahh the joy of going fast .
Denis
#14 _bushi_
Posted 30 January 2007 - 05:09 PM
good luck
Posted 30 January 2007 - 07:25 PM
Dont worry mate.. Just focus on the end result ( Even MORE power!!) and you'll be right.. the reaming wont hurt so much
#16 _QIKSLR_
Posted 31 January 2007 - 07:34 AM
Good luck mate
Marty
#17 _Lostit_
Posted 27 February 2007 - 07:49 PM
Well finally after contacting a few different places .. found a brand new geniune oil pump that is in the motor , its been placed on order from the states and should land anyday at my front door.Summit racing site( Mellings oil pump from a chevy II 64-67 283 SBC)
Rewired some of the wiring ( or more to the point cleaned up ) and fitting a quarter stick instead of the crappy setup it had.. which will hopefully in the ( near) future to a brand new interior.
So in saying that next post i should have her fired up with a few photos, and hopefully it stays in one piece when the transbrake is used down the street LOL .
Denis
Posted 28 February 2007 - 01:34 PM
Keep us updated!
#19 _Lostit_
Posted 03 May 2007 - 04:07 PM
New oil pump and pick up cured my little low oil pressure on idle.. 40 psi on idle ) .
Took it around the block first time on saturday minus exhaust ... guess the new neighbors werent too impressed.
Time to fix the other little problems and give the transbrake a shot in the next few weeks then off to calder to get banned for no cage !
Will up date progress and some new photos asap.
Im a happy camper now.
Denis
Posted 03 May 2007 - 04:11 PM
Cheers!
#21 _Lostit_
Posted 10 August 2007 - 03:00 PM
Hopefully as i promised i can get some pics up soon. Anyway got a link to HOW the frig i post photos up again.
PS. Ive posted my application for the http://www.vicsupercruz.com.au/ so hopefully all should be good to rip up some tarmac .
#22
Posted 10 August 2007 - 04:52 PM
#23 _Lostit_
Posted 10 August 2007 - 05:10 PM
Edited by Lostit, 10 August 2007 - 05:12 PM.
#24 _Lostit_
Posted 10 August 2007 - 05:11 PM
Edited by Lostit, 10 August 2007 - 05:13 PM.
#25 _Lostit_
Posted 10 August 2007 - 05:12 PM
It looks like a mess but it organised chaos hopefully this weekend it will be together .
Edited by Lostit, 10 August 2007 - 05:14 PM.
