L34 radiator
Posted 06 January 2021 - 05:59 PM
Back to the overheating, he took the radiator out to get it cleaned or re-cored but turns out it is a HQ radiator, supposedly. Must have been changed by the dealer. So what exactly does he need to make it right? I have a close finned 2 core here I got out of a UC back in maybe 1986 that had a SBC and Muncie in it. It has Chev spouts but would it have the right bands?
Posted 06 January 2021 - 06:09 PM
Posted 06 January 2021 - 06:12 PM
3 Core radiator would be the go that will keep it cool
Posted 06 January 2021 - 06:22 PM
Posted 06 January 2021 - 06:40 PM
Don’t fancy you’re chances on the correct one for an L34
Are they different to a normal Torana radiator ?
Posted 06 January 2021 - 06:41 PM
skinny 3 core fine row does the job with no fuss and thats what was fitted,..a lot of people fit the big 3 core ones but then you have modify the shroud..
Posted 06 January 2021 - 07:02 PM
Gene, I think the L34 one is the same as any other V8 LH, just has the aircon or HD core. Just trying to find out exactly what he needs as I’m not sure.
Posted 06 January 2021 - 07:27 PM
A quick ID is the Torana mounting flange is flat but a HQ one has a step where the bolt holes are and another flange on engine side for the fibreglass fan shroud (sometimes removed for a Torana install).
The straps from any original V8 Torana radiator will suffice.
Here's a picture from another thread when Brad was searching for the same.
The HQ straps put the tank closer to the engine and leave a gap between tank and radiator support panel. Torana straps place the tank 7mm in front of the mounting flange so there's minimal gap.
I showed my car as a reference yesterday and mentioned he'd find you here.
Posted 06 January 2021 - 07:39 PM
Posted 07 January 2021 - 08:21 AM
Yeah thats interesting. I prob should have considered getting a HD core built when I had mine constructed. Does it still use the same tanks and mounting strap? Just has 3 cores?
Posted 07 January 2021 - 08:39 AM
C46BDB3E-A724-4F9B-87D5-559D25156F19.jpeg 141.81K 2 downloads
527406A7-E3D8-4CA3-BFFF-4EE0B297A21B.jpeg 154.93K 3 downloads
224EB4B4-40C0-4516-A4D1-AD213E19BAE6.jpeg 155.45K 4 downloads
Posted 07 January 2021 - 09:10 AM
http://www.gmh-toran...ginal-radiator/Standard factory heavy duty radiator for L34 and A9X is two rows of 73 tubes. (146 in total) Thanks to Dave Mac.
Edited by hanra, 07 January 2021 - 09:11 AM.
Posted 07 January 2021 - 09:16 AM
Posted 07 January 2021 - 10:02 AM
Posted 07 January 2021 - 10:04 AM
The one in my pictures is 2 rows of 73. It will be from a HK Brougham with A/C. Will have to keep that core for my GTS327.
Posted 08 January 2021 - 09:30 AM
2 rows of 73 is same as the heavy duty radiator found in L34 and A9X.
Posted 08 January 2021 - 09:43 AM
Posted 08 January 2021 - 07:51 PM
These guys on the Gold Coast have a multitude of cores available including a 2 core 8.4mm tube centre version which would do the job.
https://redbackradia...au/core_matrix/
