Molasses Miracles
40 replies to this topic
#1 rexy
rexy
  • 3,598 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 04 June 2023 - 03:10 PM
This a spot for people to put their before and after efforts.
I scored a B&M ratchet shifter in a job lot of parts. It looked like it had been submerged for some time.
Attached File  IMG_0218.jpeg   130.06K   8 downloads
Attached File  IMG_0219.jpeg   68.2K   4 downloads
I made a very weak solution in a bucket with $5 wort of supermarket molasses.
After 3 weeks:
Attached File  IMG_0328.jpeg   114.99K   4 downloads
Attached File  IMG_0330.jpeg   120.56K   4 downloads
Nice high tide mark.
After a couple more weeks with lightly helping some of the scale off with a toothbrush a couple of times and voila!
Attached File  IMG_0384.jpeg   131.43K   7 downloads
Attached File  IMG_0385.jpeg   34.87K   3 downloads
Attached File  IMG_0386.jpeg   21.02K   3 downloads
Now oiled up after a wash down and works perfectly. Even the small springs have recovered.
#2 RallyRed
  • 7,845 posts
Posted 04 June 2023 - 05:54 PM
That's incredible!
#3 yel327
  • 13,096 posts
Posted 04 June 2023 - 06:20 PM
What ratio of Molasses to Water?
#4 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 04 June 2023 - 08:36 PM
Search molasses on the forums, it's been mentioned a couple of times.
#5 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 04 June 2023 - 08:40 PM
Used 10:1 but prefer citric acid because I’m impatient.
#6 Ice
  • 15,126 posts
Posted 04 June 2023 - 08:54 PM
Bad rust 5 water to 1 Molasses light rust 10 to 1 should do it
works for me
#7 rexy
rexy
  • 3,598 posts
  • Name:Rexy
Posted 04 June 2023 - 09:27 PM
I used a mix of about 40:1
Talk is cheap. -  lets see your before and after pics ladies and gentlemen!
#8 LXCHEV
LXCHEV
  • 3,510 posts
  • Car:'76 LX - 383 Chev
Posted 04 June 2023 - 10:04 PM
I’m about to re-rust the internal walls of the main fuel lines on a Commodore (they’re pretty filthy - brown and rusty after being neglected by previous owner).
Would this molasses mixture be thin enough to be pumped through a small aqua pump or electric fuel pump?
I’ve previously used white vinegar, but being acidic, have then had to follow up with bi-carb soda to neutralise.
Edited by LXCHEV, 04 June 2023 - 10:04 PM.
#9 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 04 June 2023 - 10:27 PM
Citric acid is perfect for this application. Either way you just need to flush with high pressure water.
#10 4dabush
4dabush
  • 162 posts
  • Name:Adam
  • Car:73 LJ S
Posted 05 June 2023 - 06:05 AM
Just watch certain steel, springs, spring washers, alloy bits and small and very fine threads can all disappear in molasses. I had some springs and  washers there one week, gone the next while the nuts and bolts were fine and about 90% rust free in the same solution. Some stuff like bumper brackets came up brilliantly though.
#11 yel327
  • 13,096 posts
Posted 05 June 2023 - 06:12 AM
I’m thinking of cleaning up a SBC block and heads that are surface rusty. If 40:1 works then I can do it in a big drum.
#12 4dabush
4dabush
  • 162 posts
  • Name:Adam
  • Car:73 LJ S
Posted 05 June 2023 - 06:17 AM
Just read up on it first, I think cast was one that molasses likes a LOT… if it’s only surface rusty, deoxidine and steel wool might be safer for the cast…not, you, but the steel!
#13 rexy
rexy
  • 3,598 posts
  • Name:Rexy
Posted 05 June 2023 - 05:40 PM
The mixture I used is water consistency.
Nothing fancy required for clean up, just water.
#14 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 06 June 2023 - 10:29 AM
it works good on cast
did my headers in 20- 1 for about a week
washed down with hose ready for paint then barbecued at 150c
#15 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 06 June 2023 - 12:35 PM
The ceramic coater didn't like it when I did my headers, albeit in citric. He said it made them porous and had a lot of trouble getting paint to stick. He told me just let him blast them next time.
#16 IanC
IanC
  • 544 posts
  • Name:Ian
  • Car:LJ XU-1
Posted 08 June 2023 - 12:08 PM
I don't have a before picture. But this spring was really badly rusted. Molasses and water works awesome with delicate stuff.https://photos.app.g...qkv2WSP3k2c8xA8
#17 LXCHEV
LXCHEV
  • 3,510 posts
Posted 16 June 2023 - 11:01 PM
I'm going to have a play with molasses shortly - but firstly, just thought I'd add some old photos to this thread of my previous success with white vinegar.
Some of you may recall my "sender unit from satin's toilet"....
Attached File  VR sender 01.jpg   180.35K   1 downloads
Attached File  VR sender 02.jpg   135.55K   1 downloads
Attached File  VR sender 03.jpg   124.6K   1 downloads
Attached File  VR sender 04.jpg   165.9K   1 downloads
I cleaned this one up within a matter of hours using white vinegar. I was pleasantly surprised at being able to bring this one back to life....
Attached File  VR sender 05.jpg   154.68K   1 downloads
Attached File  VR sender 06.jpg   125.15K   1 downloads
After a couple of years sitting around, still out of the car - it hasn't shown any signs of further rusting, so I'm confident this should serve me well once back in service...
Once comment I will make here - whilst the chosen solution (in this case, white vinegar) is key to lifting the rust - I certainly found working and stimulating the rusty item (eg. brushing) is what really made the transformation happen quickly). rexy made a similar comment earlier. Since my next challenge is cleaning the internal walls of the main fuel rails on the car, I'm soley reliant upon the solution only doing the work, without any kind of scrubbing...
#18 LXCHEV
LXCHEV
  • 3,510 posts
Posted 16 June 2023 - 11:08 PM
This was another item I cleaned up with white vinegar. Fully submerged - from memory for around 24 hours or so...
Attached File  Bracket 01.jpg   185.85K   1 downloads
Attached File  Bracket 02.jpg   196.34K   1 downloads
#19 LXCHEV
LXCHEV
  • 3,510 posts
Posted 16 June 2023 - 11:15 PM
And another bit of play time....
I had a couple of rusty old Y pipes....
Attached File  Y Pipe 1.jpg   131.86K   1 downloads
These were way too big to submerge, so only the very ends received a bath.... for the rest I just brushed them for a while.... you can see the difference that the submerging makes...
Attached File  Y Pipe 2.jpg   153.56K   1 downloads
Overall though, this did a magic job and I later hit them with some paint.
#20 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 16 June 2023 - 11:20 PM
Great results. As you say physical abrasion plays a significant role. I use scotch brite pads on things like rims, but th3 pressure washer is great for anything not to delicate.
#21 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 16 June 2023 - 11:22 PM
Fish crates, pickle barrels, even old bath tubs are good.
#22 LXCHEV
LXCHEV
  • 3,510 posts
Posted 16 June 2023 - 11:36 PM
So before I attack the fuel lines on the car, I thought I'd experiment with this short fuel pipe that sits above the diff... you've got me interested in molasses as it sounds quite gentle (and obviously is non-acidic). With all my white vinegar efforts previously, I've always finished by brushing on bi-carb soda and washing off with water in order to neutralise the acid and ensure it doesn't keep eating all the steel away.
So Molasses play time began last week...
Here's the test pipe:
Attached File  Fuel Pipe 1.jpg   205.62K   3 downloads
Hard to get good photos, but this one did capture it well.... as you can see, it's pretty filthy... brown, rusty, plenty of 'build-up' present... certainly can't be ignored..
Attached File  Fuel Pipe 2.jpg   56.78K   1 downloads
Attached File  Fuel Pipe 3.jpg   58.7K   1 downloads
At first, I wanted to test the aqua-pump method as this is how I'll have to do the main lines.... my mixture was quite strong - somewhere around 7:1 water/molasses:
Attached File  Fuel Pipe 4.jpg   185K   2 downloads
Had that going on and off for the first day... then killed the pump. So ended up just throwing the pipe into the bath and fully submerging it...
I let it sit for a bit over a week, then had a look..... externally, brilliant - a slight wipe with my finger and the outside looks new again (really just wiping off dirt)...
Attached File  Fuel Pipe 5.jpg   151.09K   1 downloads
Internally, it was slightly better, but still far from shiny clean....
Attached File  Fuel Pipe 6.jpg   60.91K   2 downloads
I blew it out with compressed air and that definitely seemed to help move some of the built up gunk...
Attached File  Fuel Pipe 7.jpg   81.72K   1 downloads
I think it's heading in the right direction, but for now, I've thrown it back in the bath for another week.
#23 LXCHEV
LXCHEV
  • 3,510 posts
Posted 16 June 2023 - 11:42 PM
I'm really torn as to how to approach the fuel lines - eeny meeny miney mo..... molasses, citric acid, or my trusty old white vinegar!
They don't appear to be terrible...
Attached File  VR Fuel Lines 1a.jpg   92.13K   1 downloads
Attached File  VR Fuel Lines 2a.jpg   80.73K   1 downloads
Edited by LXCHEV, 16 June 2023 - 11:43 PM.
#24 Bruiser
Bruiser
  • 698 posts
  • Name:Bruce
Posted 17 June 2023 - 11:21 AM
What about tying a bit of fishing line to a round bead, blow it through to the other end and tie a small bit of rag or something to it?
Kind of like cleaning out a chimney flue
Might be tricky with a longer line, though
#25 FLY_LX
FLY_LX
  • 159 posts
  • Car:LX sedan
Posted 17 June 2023 - 12:26 PM
how long does a molasses mixture last?
so ive got a bucket of vinegar that that i drop rusty bits in.
molasses looks alot more gentle on coatings
if i filled up another bucket with molasses mix, how long would it last?
