Molasses Miracles
40 replies to this topic
#26 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 17 June 2023 - 01:42 PM
What about tying a bit of fishing line to a round bead, blow it through to the other end and tie a small bit of rag or something to it?
Kind of like cleaning out a chimney flue
Might be tricky with a longer line, though
that’s clever Bruce. I would’ve just fed some mig wire and pull rag through.
#27 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 17 June 2023 - 01:47 PM
Molasses and citric acid both work by chelating the iron, 2hich essentially suspends it in a gel bit like truck wash. The active ingredient gets used up in the emulsion and byproducts I would say. Havin said, I tend to re use it with decreasing effectiveness over months. This is in 40-100 litre batches.
#28 dattoman
  • 16,471 posts
Posted 17 June 2023 - 04:50 PM
how long does a molasses mixture last?
so ive got a bucket of vinegar that that i drop rusty bits in.
molasses looks alot more gentle on coatings
if i filled up another bucket with molasses mix, how long would it last?
You can stir it up a bit and keep using it
But it stinks !!!
It gets moldy and smells feral
#29 FLY_LX
FLY_LX
  • 159 posts
  • Car:LX sedan
Posted 17 June 2023 - 05:31 PM
thanks, clay & datto,
handy to know.
#30 LXCHEV
LXCHEV
  • 3,510 posts
  • Car:'76 LX - 383 Chev
Posted 20 June 2023 - 10:21 PM
Bruce - your fishing line idea is fantastic!
Leveraging that idea, this week I created special tool # 304-01 - the internal pipe cleaner...
I cut out an appropriate size piece of scotch brite and then threaded some fishing line right through the middle, before tying a knot either side to hold it in place:
Attached File  Special Tool 304-01.jpg   57.96K   1 downloads
I then proceeded to pull this backwards and forwards through the pipe. I thought it might break straight away as it looks quite flimsy, but was pleasantly surprised at just how well it held up. I could hear it scuffing the pipe (it actually made some pretty weird musical noises - I may have invented a new instrument).
Attached File  Special Tool 304-02.jpg   66.08K   2 downloads
Prior to this I had flushed the pipe several times and thought it was looking really clean, but you should have seen how much brown filth came out after scrubbing. Definitely proves the theory that physical scrubbing is so important.
Attached File  Special Tool 304-03.jpg   190.17K   1 downloads
It did eventually break after a dozen or so pull-throughs, so I quickly made another, flushed the pipe and repeated.... and for good measure squirted some throttle body/carby cleaner in there to keep it well nourished. Another flush and now I'm seeing bright shiny steel inside once again.
It's back in the molasses bath now for one final time. Then I'll give it a final scuff and be done with it.
So coming back to the main fuel lines on the car - I tried pushing fishing line through, but only got half way along before it just wouldn't continue any more. I think I need something slightly stiffer. I reckon the MIG wire idea could be the go here.
#31 LXCHEV
LXCHEV
  • 3,510 posts
Posted 20 June 2023 - 10:46 PM
Quite a while back, I'd also made another very special, high-tech tool # 304-00 - the fuel rail scrubber...
I had a feral old set of rails off the neglected 5L:
Attached File  Rail Resto 1.jpg   177.41K   2 downloads
At least being aluminium, rust and pitting isn't a concern, only cleaning off the coating of filth...
Attached File  Rail Resto 2.jpg   60.02K   2 downloads
Attached File  Rail Resto 3.jpg   75.88K   2 downloads
You can see special tool here - an old coat hanger with scotch brite hot glued onto the end... and again - worked an absolute treat!!
Attached File  Rail Resto 4.jpg   188.76K   2 downloads
#32 Indy Orange
Indy Orange
  • 2,850 posts
  • Name:Paul
Posted 20 June 2023 - 11:16 PM
What about a pipe cleaner and fishing line.https://www.australi...leaners-44-pack
Edited by Indy Orange, 20 June 2023 - 11:22 PM.
#33 Indy Orange
Indy Orange
  • 2,850 posts
  • Name:Paul
Posted 20 June 2023 - 11:34 PM
A metal guitar string may work also.
#34 Bruiser
Bruiser
  • 698 posts
  • Name:Bruce
Posted 21 June 2023 - 12:22 AM
Good news, I am glad it worked for you. Are there any tightish radiuses bends in the long main fuel line?
Occasionally while pulling cables through wall cavities I have had them hook up, and then not want to come back either
caught like a Chinese finger trap.
It’s giving me the anxious yips thinking you could end up with a piece of something snagging up halfway down your line
and not be able to get it out again.
Attached File  AF7D13AB-7286-4C5B-A9C4-AC38DC750737.png   33.67K   1 downloads
Went looking for something like these, but with metal loops at both ends, but can’t see any
What about using some magic fishing knot which has a shrinking loop
that gets smaller as you pull, so the line is continuous and can’t tear out of the scourer pad?
A dab of glue on the knot?
#35 dattoman
  • 16,471 posts
Posted 21 June 2023 - 08:41 AM
Barrel cleaners/oilers from the gun shop ?
#36 LXCHEV
LXCHEV
  • 3,510 posts
Posted 21 June 2023 - 09:48 AM
All great ideas, cheers.
I'm extremely wary about pulling anything through the main lines, for fear of breaking or getting stuck, just as Bruce said. I don't believe there are any super crazy tight bends in the lines, but there's enough general bends to make it plenty tricky.
Whilst I continue pondering the options - I've been blowing carby cleaner through those lines with compressed air. Each day I'll give it another dose.
#37 Rockoz
Rockoz
  • 3,969 posts
  • Name:Rob
Posted 21 June 2023 - 10:27 AM
Get some brickies string line, tie a few knots in it then place inside pipe, and get the pipe end in the vacuum cleaner to suck the string through.
Rob
#38 Bruiser
Bruiser
  • 698 posts
  • Name:Bruce
Posted 21 June 2023 - 12:07 PM
That’s a good idea
Does carby cleaner dissolve nylon fishing line?
#39 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 21 June 2023 - 01:26 PM
Do a test in a small container first.
#40 LXCHEV
LXCHEV
  • 3,510 posts
Posted 27 June 2023 - 10:15 PM
I called time on the molasses bath and removed the fuel pipe for the final time. Flushed with water, then ran my scotch brite scrubber through it again, but this time, not a hint of anything dirty. Very happy with this now - a fantastic transformation.....
BEFORE:
Attached File  VR Rear Fuel Pipe Dirty.jpg   56.78K   1 downloads
AFTER:
Attached File  VR Rear Fuel Pipe Clean.jpg   56.88K   1 downloads
#41 rexy
rexy
  • 3,598 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 28 June 2023 - 06:08 PM
Very nice.
