replacing triple SU's with a holley?
#1 _troy_
Posted 27 September 2006 - 07:38 PM
#2 _Keithy's_UC_
Posted 27 September 2006 - 09:09 PM
It's up to you mate!!
Keith
#3 _@milco@_
Posted 27 September 2006 - 10:19 PM
#4 _Keithy's_UC_
Posted 28 September 2006 - 02:06 AM
Keith
#5 _jklumpp_
Posted 28 September 2006 - 01:30 PM
SU's are by nature of their design, a very efficient carby.
Not sure of your reasons, But I would say spend the money on getting the SU's right, and you'll never look back....
#6 _@milco@_
Posted 28 September 2006 - 11:25 PM
#7 _DocDamage_
Posted 29 September 2006 - 12:06 AM
But if you don't have a smooth idle, you'll have a clean engine bay from the shower of petrol the fuel bowl vents give it at idle. In traffic thats always expensive.
Posted 29 September 2006 - 12:53 AM
#9 _Aquarius - LC_
Posted 29 September 2006 - 09:24 PM
I've had a number carb set-ups on my hot 6, twin stromy's,34adm webber,
WW stromy & holleys 350,500 & 465. All set up properly and dynod each time.
Of all these the 465 gave the best results, very good power & reasonable
economy. At that time the car was really quick, so i used the 465 for 18 months
or so & it was good.
Then i found a really good set of 1"3/4 SU's. WELL...let me tell you,the tripples rule. More power all through the rev range[dyno proven] better idle quality,even better responsiveness & driveability & a BIG improvement in fuel efficiency.
As others have said, They have to be set up properly & be in good condition,
You have to run a fuel pressure regulator also. I might add in almost 12 months
there has been no need to retune anything.
I love em, tripples really allow the old holden 6 to give you it's best
#10 _draglc_
Posted 29 September 2006 - 11:24 PM
i dont know what your on about mate, i have never experienced that from my SU's...SU's are self metering and are as efficient or expensive as you want to drive them.
mine are absolutely fantastic, no need to retune for ages, and especially dont leak fuel. can be as fuel efficient as i want, or dont want, and they dont let me down in the power department.
A1
#11 _smcbr6_
Posted 30 September 2006 - 10:34 AM
Aquarius - quick question regarding the fuel pressure regulator... On mine I have a holley Red, according to the spec it can flow as low as 4psi and doesn't need a regulator. But I've heard the SU's only require 3 psi - do you run a regulator and what is it set at?
Cheers,
Shane
'71 LC
http://manny.homelin...ent/torana.html
#12 _DocDamage_
Posted 30 September 2006 - 11:26 AM
I probably should have been more specific and exaggerated less.i dont know what your on about mate, i have never experienced that from my SU's...SU's are self metering and are as efficient or expensive as you want to drive them.
A1
I am talking specifically about SU's not sidedraught strombergs, I don't mean a slightly rough idle I'm talking a lumpy idle, set too low, that throws the motor about a bit. It's not a shower but my stockcar with the long 8" armours manifold leaks like a sieve when its cold as do many of the other stockcars at the track. Their fine within a few minutes when the idle picks up.
Don't be mistaken, I love 'em and wouldn't use anything else on the stockcar.
#13 _Aquarius - LC_
Posted 30 September 2006 - 12:06 PM
You've heard correct, If you don't run a reg with SU's they tend to
overfuel & even leak at idle & low revs. I ran mine the first couple
of days without one & it ran very rich, and ended up fowling the plugs.
My engine builder told me to fit a reg and set at 21/2 - 3psi. That's
what i did & even before the dyno tune it ran perfect !
I often wonder when i hear people say SU's are thirsty,tempromental,
can't get em set right, Blah Blah, If they just need to fit a regulator?
They are Brilliantly simple and very efficient.
This is just from my experiences.
#14 _levis_
Posted 30 September 2006 - 12:16 PM
#15 _Aquarius - LC_
Posted 30 September 2006 - 12:23 PM
#16 _DocDamage_
Posted 30 September 2006 - 12:45 PM
I've often wondered how quad SU's might go on a V8.
#17 _UCV80_
Posted 30 September 2006 - 01:01 PM
600km out of a 50L tank, on a hot worked 6.
#18 _draglc_
Posted 30 September 2006 - 05:21 PM
and i have an extremely lumpy cam, 512thou lift, and mine dont leak a single drop, and neither do i have a regulator either.
A1
Posted 30 September 2006 - 05:52 PM
Rover had a 3.5 ltre V8 with twin CDs before fuel injection and the first V12 Jags had 4 CD 150s, 2 twin manifolds, one for each 6cylinder bank.I've often wondered how quad SU's might go on a V8.
both worked very well and efficient,
I once saw an after market manifold to put twin CD175 (or SUs) on Holden 308, don't how it went though.
#20 _DocDamage_
Posted 30 September 2006 - 06:35 PM
As far as V8's go surely it wouldn't be too difficult to fabricate a valley cover, & do the manifold in a cross over config. Would be interested in knowing what anyone with relevant experience thought of how it might perform.
#21
Posted 30 September 2006 - 07:05 PM
#22 _smcbr6_
Posted 01 October 2006 - 08:25 AM
#25 _troy_
Posted 25 October 2006 - 11:35 AM
