new engine
119 replies to this topic
#1 _Drag lc_
_Drag lc_
Posted 24 September 2008 - 12:14 PM
hi,
i will try again to get some pics up if they work
we have our new 202 has been bored.015" over and has now been grout filled and is awaiting my return from usa with a set of ross forged pistons and total seal gapless top rings to suit you will also see the torque plate i made and gregs girdle on engine aswell the final bore size will be .017" over.
Thanks hayden
#2 orangeLJ
Posted 24 September 2008 - 01:40 PM
wow!
#3 Evan
Evan
  • 1,287 posts
Posted 24 September 2008 - 01:41 PM
looking very nice there!!!
i hope that this one holds togeather for you and you get some better times.
Evan.
#4 _Bomber Watson_
Posted 24 September 2008 - 06:44 PM
Yeah stop blowing my damb motos up :P
Looking good Hayden.
#5 rodomo
  • 18,055 posts
Posted 24 September 2008 - 08:41 PM
Would Araldite be better than grout? :huh:
Good luck! :spoton:
#6 mr5000
mr5000
    chief break-everything
  • 3,456 posts
  • Car:77 lx 4door
Posted 24 September 2008 - 10:21 PM
wats the advantage of filling it with grout
#7 _73LJWhiteSL_
_73LJWhiteSL_
Posted 24 September 2008 - 10:31 PM
Wow... looks expensive.
Yeah whats the advantage with filling with grout?
Steve
#8 _@milco@_
_@milco@_
Posted 24 September 2008 - 11:07 PM
helps the motor hold together as there is no room to the bored to shift/move only really for drag motors not advisable for the street....
#9 _ChevLX_77_
_ChevLX_77_
Posted 24 September 2008 - 11:20 PM
You can fill at different levels. i have seen street engines grout filled to the water pump bolts.
Looking good guys! What exactly have you done to your motors, just curious as my mates one seems to have a habit of cracking bores (186)
#10 orangeLJ
Posted 26 September 2008 - 10:01 AM
Yeah Ive seen my fair share of grout filled blocks for high HP street cars. As said, up to the water pump bolts.
Some of the drag guys and hi performance guys are filling them completely...
#11 _Drag lc_
_Drag lc_
Posted 19 October 2008 - 11:31 AM
hi, i now have the ross forged pistons for the new 202 engine i was after some information on converting the blue rods to full floaters as i was told this might be a good idea has any body else done this before? any help would be great.
Thanks hayden
#12 _uglybob_
_uglybob_
Posted 19 October 2008 - 06:37 PM
they look tops hayden would love some of those for mine! cant see the top photos but. how do u mean full floaters? as in usings circlips for the gugeon pin instead of pressing it into the little end bore with so much crush on it so the gugeon pin can spin freely in the little end bore??
does that explenation make sence??
the engines i usually work on like cat 3516's run that spec, dont know if its because its real easy to wack another piston on the rod or its stronger that way.
i built a 4g54 for my mate wich had oiled gugeon pins that would be handy if ur thinking about playing with the blue rods some how.
#13 orangeLJ
Posted 20 October 2008 - 09:08 AM
Wouldnt the best bet to be buying some to suit the application?
#14 _Drag lc_
_Drag lc_
Posted 20 October 2008 - 07:38 PM
Uglybob, yes you are correct that is what i mean and the new pistons have provisions for spirolocks
to hold gudgion in place.
Orangelj, they were made to press fit onto blue rod as per std but aparently they can also be run as
full floaters.
Thanks hayden
#15 _uglybob_
_uglybob_
Posted 21 October 2008 - 03:21 AM
ah kool bananas. ok then well wouldnt u just enlarge the little end bore and then just wack in your circlips. would this realy improve the life of the piston/gugeon pin/rod do you think? i suppose it could help with wear in the pin bores in the piston.
r u going a roller cam in the girl this time round??
#16 _Drag lc_
_Drag lc_
Posted 21 October 2008 - 05:52 PM
Uglybob,
yes that it what happens but they put a bush in the little end aswell so i am unsure if it
will weaken it more so by doing this or will i be better off leaving it press fit as we never
had a problem with the pin area of the ACL pistons.
no roller cam yet, as old cam was salvaged from last engine.
Thanks Hayden
#17 _uglybob_
_uglybob_
Posted 22 October 2008 - 03:08 AM
ah ok then, i rekon that would make the rod weaker just because you would have to take so much meat out of the little end bore with the bush and all but what ever floats your boat.
do you rekon you could send me a pici of your torque plate?!
ben
#18 _Drag lc_
_Drag lc_
Posted 22 October 2008 - 05:38 PM
Uglybob,
yes wont be for a couple of days though.
Thanks hayden
#19 warrenm
warrenm
  • 2,126 posts
  • Car:1972 LJ Torana
Posted 23 October 2008 - 07:05 AM
I'm interested in a pic of your torque plate aswell.
Warren
#20 _82911_
_82911_
Posted 23 October 2008 - 08:25 AM
Hayden, bushing the little end is a common mod, I have been doing it for years and never, never seen a rod failure in that area.
Welcome to the world of spiro locks...... enjoy! :P
#21 _Drag lc_
_Drag lc_
Posted 23 October 2008 - 06:34 PM
Greg,
just to confirm, even if we bush them to suit a .866" dia wrist pin (std)?. yes i must say that in the 2 engine failures i have seen the rod is cirtanly not the weak part at all but we arnt making a lot of power.
Warren, i have told uglybob the same i have no pics until some time next week hopefully as i am getting new computor tommorow and computor shop is swapping all the stuff from this one to new one then i will be able to post pics properly.
Thanks Hayden
#22 warrenm
warrenm
  • 2,126 posts
Posted 24 October 2008 - 12:08 PM
Thanks, there is no urgent rush.
Warren
#23 _82911_
_82911_
Posted 24 October 2008 - 01:07 PM
No problem with the 0.866".
#24 _Drag lc_
_Drag lc_
Posted 24 October 2008 - 02:36 PM
Greg,
Thanks we will do it.
Thanks hayden
#25 _Drag lc_
_Drag lc_
Posted 25 October 2008 - 11:53 AM
just thought i might put this pic up it is me driving it at the strip a while ago on alcohol.
