new engine
#51
_Drag lc_
Posted 05 March 2009 - 06:26 PM
yes dizzy cap clean have ohms tested all leads they are good idle adjustments were a little out adjusted them progression holes seem ok float levels are good had tops of thisarvo did notice it was running rough whith last jet change when idling so it is more than likley them not balanced properly will do that before driving again.
Thanks Hayden
#52
Posted 06 March 2009 - 07:49 AM
Warren
#53
_Drag lc_
Posted 06 March 2009 - 12:14 PM
#54
Posted 07 March 2009 - 11:26 PM
half rf100 and half premium from bowser
what the rest of the fuel system? pump, lines, reg?
#55
_Drag lc_
Posted 08 March 2009 - 07:34 AM
edelbrock 6 valve 130gph fuel pump, magnafuel mp-9633 2 port reg then going into the cool can then splitting into 3 for carbs we still have std fuel tank in boot and suction line but have -8 from pump to reg and -6 to cool can and carbs but we have had fuel starvation issues before that is when we fitted the edelbrock fuel pump.
Louie has told me some things to check on carb today so will do them.
Thanks Hayden
#56
Posted 08 March 2009 - 11:34 AM
the fuel system is as follows:
Thanks Hayden
what exactly is a cool can? do you have any pictures of it?
_Drag lc_
Posted 08 March 2009 - 12:12 PM
Thanks Hayden
#58
_Drag lc_
Posted 08 March 2009 - 04:00 PM
Thanks Hayden
#59
Posted 08 March 2009 - 06:36 PM
yeh on last pic of engine in engine bay it is the aluminium cylinder type thing with the fuel hoses going in and out.
Thanks Hayden
i was just curious as to what it does? is it like a surge tank?
#60
_why-psi_
Posted 08 March 2009 - 07:32 PM
#61
_Drag lc_
Posted 08 March 2009 - 07:35 PM
Thanks Hayden
#62
_NZ Toranaman_
Posted 09 March 2009 - 04:37 AM
I'll be pulling my motor down after this weekends meet and may remove my webers and return the fuel injection on it just to see the difference.
#63
_Drag lc_
Posted 09 March 2009 - 06:40 PM
nz toranaman, getting closer to final jeting but obviously will still be changed slighly to suit weather conditions proberly 155/160 mjets and 180/190 ac i think that will be very close to the money as it had afr 12.2 all the way till just before the limmiter it dropped to 11.9 so still a bit fat with 160mj 170ac so have fitted 180ac now but not tried it yet. then will try 155m/j .
have fitted a holley low pressure reg spring to the magna fuel reg as before it was 51/2psi was the lowest it could go but now i have it set at 31/2 psi.
Thanks Hayden
#64
_ballrash_
Posted 15 March 2009 - 02:35 PM
#65
_NZ Toranaman_
Posted 15 March 2009 - 06:03 PM
The webers I have are 3 x 45DCOE 13 Made in Italy, I was told Spain made some webers.
Pumps = 50
Idle = 55F9 (These were 45 F9)
AC = 200
Emul = F2
Main = 145
Dunno if this helps also I am open to any suggestions as to my possible jetting as well as I was told the carbs came off a 320hp 202
#66
_Drag lc_
Posted 16 March 2009 - 08:09 AM
#67
_1QUICK LJ_
Posted 16 March 2009 - 11:56 AM
#68
_Drag lc_
Posted 16 March 2009 - 04:28 PM
Thanks Hayden
#69
_1QUICK LJ_
Posted 16 March 2009 - 05:09 PM
#70
_Drag lc_
Posted 16 March 2009 - 06:08 PM
Thanks Hayden
#71
_1QUICK LJ_
Posted 16 March 2009 - 10:11 PM
#72
_NZ Toranaman_
Posted 19 March 2009 - 03:15 PM
Hey Drag lc I was just browsing my log book I run with this engine so I can document all changes etc trying to find something extra.
Pumps = 50
AC = 200
Emul = F2
Main = 145
Heres another setup from a Targa car from NZ, may give another perspective.
Carburettors 45mm Webers Side Draft
Chokes 38mm
Aux Vent 4.5
Main Jets 140mm
E Tube F16
A Correction 210
Pump Bleed 40
Pump Jet 0.45
Idle Jet 55F8
Needle Valve 250
#73
_Drag lc_
Posted 30 April 2009 - 03:59 PM
just a quick up date on this engine i have been rooting around trying to get somesort of tune in this engine with help from Louie (purple LC) as it is now fitted with 38mm chokes but that is another story altogether.i have now decided to fit a moroso vacum pump to this engine to help get the the most performance from this combination the first step has been to remove the trusty chev 6 valve block mounted fuel pump as that will be where we will be pulling vacum from so i have now fitted a magnafuel quick star 275 pump with filter i had laying around here and fitted the trusty system 1 fuel filter we used for the alcohol set up yes the quick star fuel pump is alcohol tolerent aswell :spoton:i just modufyed an old fuel tank sender unit as i have 5/8 pick up and 1/2 return in xu1 type tank.i have a huge fuel cell here aswell but it looked to much work to fit.
We will be sucking from fuel pump plate then to catch can then have moroso vacum pump sucking from there. have also been doing a few calculations as the moroso pump maxum rpm is 6,000 and they make a 5" pully for them so with all my calculations as we are spinning engine to 7,000rpm the biggest drive pulley i can have is 4.88" so have got a old comie pulley arangement im prolly going to try that first as there is very little room for much else between radiator and crank bolt on front.
oh yeah got my self a new optima red top battery aswell
Thanks Hayden
#74
Posted 01 May 2009 - 06:58 PM
Tweaked your exhaust ports yet??
I hear Petes mates mate is getting pretty good at them if you need a hand.....
Edited by Bomber Watson, 01 May 2009 - 06:58 PM.
#75
_Drag lc_
Posted 14 May 2009 - 07:25 PM
Thanks Hayden
