new engine
119 replies to this topic
#76 _82911_
_82911_
Posted 15 May 2009 - 05:17 AM
Hayden,
you need at least 12.7psi for every 1G of acceleration.
Don't for get about the G spike at launch.
And keep you regulator FORWARD of the carbs.
Cheers Greg..
#77 warrenm
warrenm
  • 2,126 posts
  • Car:1972 LJ Torana
Posted 15 May 2009 - 09:47 AM
Use a return style (not a dead head)regulator forward of the carbs & you shouldn't have any probs.
Warren
#78 _Drag lc_
_Drag lc_
Posted 15 May 2009 - 04:51 PM
arh hell i new this was a bad idea (Fitting electric fuel pump)........................... i know what you mean that will require a complete new fuel system at carb end as well.BUT
i can see how this system works with the return style reg and holley type pump holley type carb, but with this return style fuel pump if i were to fit a return style reg up front i will most likley have to block the pump return off completly and then rely on it to pump up the front and regulate it back to 3psi after carbs and then it would be pumping like well it reconds 275GPH freee flow i think past the weber carbs that scares me a bit it could prolly blow the arse clean out of the float bowl if somthing were to go wrong hehe.
geez i can see now why we stayed with the 6 valve chev mech both when we ran pump fuel and alcohol...............
Cheers Hayden
#79 _Drag lc_
_Drag lc_
Posted 14 June 2009 - 04:08 PM
hi just an update
things have been going slow as i dont have that much time to work on it latley and the intrest has also been lacking but i have finaly got the mount for the vac pump sorta made just some final trimming and i might lift it up some if i can as at the moment it sits just about 10mmm lower than the front crosmember but have now got some things back from pete (runna202) that he has welded for me the tank the fuel pump plate breather box oh and the gauge thing to accept the vac gauge.here are some pics.
Thanks Hayden
#80 _pacey1977_
_pacey1977_
Posted 16 June 2009 - 10:18 PM
Hi DRAG LC nice engine and car mate am building a holden 6 with 45 dcoe webbers and just want to know how much power and torque are you making and what parts and cam did you use
also what number have you want to run at the 1/4 mile
I would like around 300hp from my new engine. am using a soild cam ( comp cams grind) with all the goodies black motor crank and rod 186 9 port head with yt parts and rollers thats just to start.
Pacey
#81 _Drag lc_
_Drag lc_
Posted 17 June 2009 - 07:05 PM
hi pacey,
we have run 12.79@ 105mph on pump fuel and 12.83 @107mph on alcohol. we just have a profesionaly ported 9 port head and flat tappet cam 255deg @.050" 500" lift and acl pistons red crank blue rods. no never had it on a dyno only at strip.
we now are running same head and cam little less comp but forged pistons and a fair amount of other stuff on this engine but you would have read about it in this thread anyway.
Cheers Hayden
#82 _Bomber Watson_
Posted 17 June 2009 - 09:56 PM
haha i have .050" more lift than you.
Get with the times man :P
#83 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 18 June 2009 - 05:54 PM
bomber, small valves??
#84 _Drag lc_
_Drag lc_
Posted 18 June 2009 - 06:24 PM
hey d.j that head and cam have run into the 12's many a time mate dont forget.hehe :ZZZ: :rockon:
d.j u wana race mate?hehe
Cheers Hayden
#85 _NZ Toranaman_
_NZ Toranaman_
Posted 18 June 2009 - 06:37 PM
I always thought it wasn't the length of the lift it was how ya use it :P
Can't wait to see how it goes Hayden
#86 _Bomber Watson_
Posted 18 June 2009 - 07:01 PM
Cheers Hayden
Wanna race???
Whats the fastest tow truck around CQ region????
:P :rockon:
#87 _Drag lc_
_Drag lc_
Posted 18 June 2009 - 07:37 PM
Oh dj it would have to be at the strip mate hey, well you might have the bigger cam but i bet mine will do a bigger burnout complete with engine explosion hehe. :tease:
Graham,
Yeah i am getting closer to getting it going am still hoping to get it to strip this winter.
Cheers Hayden
#88 _Drag lc_
_Drag lc_
Posted 05 July 2009 - 06:54 PM
Hi,
just an update i have now fitted the vac pump but there is a few teething problems with it already just started it thisafternoon yet to drive it it seems very noisey and might be pulling to much oil aswell but will have to drive it to make sure and i gather i need to drive it to set regulator valve.. so here are some pics of it.
Thanks Hayden
#89 _Squarepants_
_Squarepants_
Posted 05 July 2009 - 07:07 PM
Awesome, nice work! :spoton:
Keep at it mate, it should be wicked once you get it sorted!
#90 _Bomber Watson_
Posted 05 July 2009 - 07:30 PM
Now you can impress chicks with the vac gauge Hayden :D
#91 _holset444_
_holset444_
Posted 05 July 2009 - 08:13 PM
Hi Drag lc
Just thought I'd show you my mad project. It'll also answer people's questions whether or not you can use mechanical injection and strata turbo systems.
#92 _sonic_injection_
_sonic_injection_
Posted 05 July 2009 - 09:23 PM
dats a nica set up.
#93 myss427
myss427
  • 1,636 posts
Posted 06 July 2009 - 12:34 PM
That vacuume pump pulley is too small, they need to be under driven (never over 6000 revs). The crank pulley should be half its size, thats why you are pulling oil. They should pull a small amount of oil, to help lubricate the seals.
#94 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 06 July 2009 - 03:48 PM
it is underdriven, he sed he's only taking it to 7000, so the pump would be spinning at near 6000 at those revs.
but cant see clearly in those pics. what diametre is the balancer and pully hayden?
#95 myss427
myss427
  • 1,636 posts
Posted 06 July 2009 - 05:24 PM
The balancer pulley in that pic looks larger than the pulley on the pump, so if it is, its over driven. Could be the photo but I don't think so.
#96 _Bomber Watson_
Posted 06 July 2009 - 05:53 PM
Na he's just got the belt loose so once the pump hits 6000 the belt starts slipping.
#97 _Drag lc_
_Drag lc_
Posted 06 July 2009 - 07:38 PM
yeah you are right it is over driven not by much i did do all the calculations and yeah 6,000 is tops for vac pump but dont have much room for a smaller pulley as the dam radiator is pretty thick but id say im going to have to make a small pulley for crank that will pick up the 3 balancer bolts up most people iv seen and spoke to said around 3" diam drive pulley.
but the noise it makes is like a baffle loose on an exhaust pipe but makes the noise whether it is blowing into breather box or not and makes it even if it isint pulling vac at all?.iv only had it running up on jack stands i guess when i drive it it might get a little quiter?.
Thanks Hayden
#98 _Drag lc_
_Drag lc_
Posted 11 July 2009 - 06:55 PM
hi
have been told that it will get quiter once run in. so i then went and made this new pulley arangement today and seems alot better way quiter am yet todrive it but pulls vacume at around 4,000 so will play with regulator valve tommorow as i still have to make spacer for pump hub .
but the new pulley is 2" diameter and from my calculations should spin pump to just under 3,000rpm
Thanks Hayden
#99 _Drag lc_
_Drag lc_
Posted 18 July 2009 - 04:24 PM
ok have finaly test driven this car today first off the vac pump was pulling alittle much vac than needed around 17" when flat, so i then changed that and it now has 13" when flat and has 5" at 2,000rpm so i think it has turned out alright i also think it sucks out a little bit to much oil from engine as i drove it across town and with 2 test runs and drive back home it sucked about 1 litle of oil out but will sus that out as if it is to much oil i will put the regulator valve on the tank i made insteed of rocker cover.
Cheers Hayden
#100 _cruiza_
_cruiza_
Posted 18 July 2009 - 05:42 PM
Hi Hayden nice job first time I have seen pics about of your car love the workmanship
