well I seem to be making some progress of late, dropped the old banjo out which has definitely seen better days and finally finished coating the chassis with KBS...if I never have to do paint a chassis again, it will be too soon.
I stripped back the trailing arms, springs retainers etc and all got a fresh coat of satin black.
After finishing the chassis coating I decided to treat myself at set of low king spring for all four corners. I already had some low pedders rears which came with the car but opted for kings instead. You can see the height difference between standard and lowered, also note the king spring has an extra coil compared to the pedders item....
Have fitted the springs and trailing arms in anticipation of getting my diff housing stripped and painted this week....will be very happy to get this all back together, then I can start on the front end.
