Lone Ranger LC 2door
#126
Posted 02 December 2014 - 07:35 AM
Posted 02 December 2014 - 07:46 AM
#128
Posted 02 December 2014 - 07:55 AM
#129
Posted 02 December 2014 - 02:17 PM
Ok if you go over it with something else.
Ideal world would be KBS then 2k black on top so if any chips you won't see.
#130
Posted 03 January 2015 - 08:56 PM
Not a great deal been happening of late, but slowly chipping away at a couple of things...The festive season resulted in a nice colour coded trolley jack for my car and which desperately needed.
I made a template of my boot floor and cut some MDF to suit, will cover this with a black carpet and give the boot a simple and neat appearance.
Found myself a brake booster bracket, in the process of giving this a freshen up and have drilled the additional holes in my firewall to suit.
Also acquired this cross member which is originally from a 3speed colomn shift LC, will this cross member be suitable for an aussie 4speed???
Lastly got my front end back from the sand blasters, has been etched primed, now to get a couple coats of black on and rebuild the whole front end, looking forward to getting the shell rolling again.
Posted 03 January 2015 - 11:35 PM
#132 _duggan208_
Posted 04 January 2015 - 12:36 AM
This is going to be a very nice little LC.
Regards
#133
Posted 08 February 2015 - 08:21 PM
Made a little progress recently...finally found myself an LC under dash at a reasonable price (not the $700 currently portrayed on ebay) trial fitted this along with the rest of my dash, glove box and instrument panel. Still need to fix the couple of small cracks in the dash pad and have the ignition barrel re keyed to suit my other locks.
Got my 'hamburger with the lot' from kingswood country, just a side note you don't get the 4 bushes that support the control rod to k frame, and I can find them anywhere, luckily my old ones weren't to badly worn so il just re use them for now. The only other annoying thing was one of my bottom ball joint wasn't tapped for the grease nipple, but to they're credit another one is in the post on its way as we speak.
Got my k frame all painted, bushes pressed and back together (despite the ongoing debate over which way the outrigger bush should go). K frame bolted back in today and is looking the part. Hope to get control arms, stub axles and brakes all mounted this week with any luck.
Next on the cards is roof lining, front and rear glass, brake booster and lines....plenty to keep me busy.
Posted 08 February 2015 - 09:24 PM
Hi Davis, got my control rod bush's from Rares.
My advice is leave grease nipples off until last. would be easy to snap them off while assembling.
Looking good, keep at it.
Marty
#135 _mikecatts_
Posted 09 February 2015 - 06:02 AM
nice work Andrew...
#136 _greg2240_
Posted 09 February 2015 - 07:23 PM
a real credit to you mate, looking really nice,
#137
Posted 19 February 2015 - 04:50 PM
Thanks for the comments guys,
Managed to get my car back down on all wheels this week and is a rolling shell again...
Fitted up my lowered king springs with the help of my home made spring compressor (thanks for the design idea Dave aka. s pack) worked a treat.
Got new wheel bearings and re fitted my hubs (waiting on xu1 spec disc rotors), then rebuild my callipers and run brake lines.
My biggest issue is my upper bump stops, as you can see my passenger side has popped out of the housing and is wedged between upper control arm and k frame. I understand some people cut the bump stop? how much should I take off?
Also I received the triangular lower bump stops in the bushes kit, I assume these wernt applicable on LC model?
Posted 19 February 2015 - 06:56 PM
I'm thinking of going a bit lower and I'll have to cut lower stop.
Marty
#139
Posted 19 February 2015 - 07:36 PM
Your going to have trouble getting that bumpstop in without removing spring. Looks like it wasn't seated properly. I don't think you need to cut it. Once all the weight is in the front end it is well clear. Only gets squished when using standard ride height springs. I'm thinking of going a bit lower and I'll have to cut lower stop. MartySent from my iPhone using Tapatalk
Thanks Marty, my drivers side upper bush does appear to sit better but is still getting squashed. I was hoping not to pull the front apart again, oh well has to be done. Cheers
#140 _duggan208_
Posted 19 February 2015 - 10:29 PM
Yeah. mine are also squashed, thinking about getting rid of them or at least cutting then to fit in better. Like that spring compressor. I went out and picked a couple of those triangle bump stops, put them in only to find that they bump on absolutly nothing, definatly, LJ bump stop.
Regards
#141
Posted 20 March 2015 - 03:01 PM
Got a little more done recently...fitted up some slotted xu1 spec rotors and had my steering rack rebuilt, fortunately it wasn't to worn and with 1 shim removed it's much tighter now. I wasn't happy with how it came back from the shop so cleaned it up and gave a fresh coat of paint, once dry I put it back on with some new tie rod ends.
Also had my brake booster and distribution block re-conditioned, ended up stripping 3 used boosters in order to make 1 good one. Got a new aftermarket master cylinder and will get this all mounted up when the paint dries also.
Next on the cards is to sort my callipers, already have my xu1 spacers to suit the rotors (cheers darway) along with new brake lines etc.
**ps. I'm missing one brake line retainer plate (you can see it in the top left hand corner of the callipers picture) if any one has a spare let me know.
Posted 20 March 2015 - 05:45 PM
very nice coming along well
#143 _Agent 34_
Posted 20 March 2015 - 06:19 PM
keep chippen away.
it's worth the effort.
PS marty had a good thing with colour on bolts - one tip i will give is to keep a record of which nuts/ bolts have been tightened to correct tension.
I lost a upper shock bolt at 140 and when straight into another toranas headlight off the bumper LOL
Edited by Agent 34, 20 March 2015 - 06:21 PM.
#144
Posted 20 March 2015 - 06:49 PM
keep chippen away.
Cheers, good idea. I will be checking and re checking every nut and bolt before this thing hits the road...
#145
Posted 20 March 2015 - 07:43 PM
Looking good Davis, if you have trouble getting a brake hose holder they're not too hard to make. Just used 40 or 50mm square tube. Remember there is a left and a right version. Think I showed how its done in my build thread? Post #707 on my computer.
All the bolts I hadn't tightened I taped them as a reminder so once the weight is on the front end you go through and torque em up.
Marty
Edited by sibhs, 20 March 2015 - 07:49 PM.
#146
Posted 20 March 2015 - 08:51 PM
Marty
Cheers Marty, some nice fabrication work there....that will definitely be on the cards if I can't find one.
#147
Posted 20 March 2015 - 09:06 PM
Hey Davis
Hate to have to inform you but you have the wrong front suspension set up for your LC. Now I'm not trying to be anal about something trivial as this is really important. It appears your LC was built after March 1970 however your front suspension crossmember and upper control arms are pre March 1970.
The early crossmember spring towers do not have the LCA bump stop strut or the LCA mounted bump stop rubber.. Instead the upper control arm (UCA) has a platform welded to the top and the bump stop rubber is mounted in a bracket assy that is attached to the chassis rail above the UCA.
You have the early suspension set up but your chassis rails don't have brackets for the bump rubber.
Effectively you have rebound bump stops but no compression bump stops which could prove to be quite dangerous and I'm sure your car would be deemed unroadworthy.
Edited by S pack, 20 March 2015 - 09:10 PM.
#148
Posted 20 March 2015 - 09:53 PM
#149
Posted 20 March 2015 - 10:29 PM
Davis
In this pic you can see the lower bump stop strut that your early LC crossmember does not have.
In this pic you can see the lower bump stop rubber and the bump stop strut on Marty's LJ front suspension.
Notice there is no platform piece welded to the top of the UCA.
Hate to say it but IMHO locate the correct front suspension for your LC and sell yours to someone with a 1969/early 1970 LC.
#150
Posted 21 March 2015 - 04:57 AM
Oh well 1 step forward, 2 steps back, shit happens.
