Posted 01 November 2015 - 07:33 AM
Mike, the rear window rubber is the generic rare spares one, and looks nothing like the pic you have added. I never had any rubbers on my car when I bought it, so unsure what the originals look like.
The weather strips are a pain in the arse, I found the best way was;
Instal 1/4 window first, secure at the top in position, but leave the bottom screw out for now.
Instal glass, but just let it sit in the bottom of the door, so u can move it around.
Now start with the external weather strip, it only goes one way, I put the little metal clip sideways in a pair of needle nose pliers then reach up through the door and try to secure (you will drop the clip a dozen times before you get it right. Once I had two clips on, I applied the sealant to glue, then attached the other two clips.
Now attach window mechanism, and get glass in the runner. Wind window all the way.
Instal internal weather strip, this one is a little easies because clips are attached to strip. Use pliers or screwdriver to reach inside door and put pressure against clips. I didn't glue this strip, as it didn't feel necessary.
Leave the door for a day so glue can dry.
Install window Chanel, I started with 1/4 window side, you will need silicon spray to help lubricate, window should be in down position, start feeding channel, eventually u will get too much friction and can't push it anymore. Wind window up, reach in door and start to pull channel from the bottom. Use silicon spray as required. Repeat process for other side of door, make sure channel isn't twisted, once in place, wind window down and glue channel into position.
Hope this helps, it's a pain in the arse, and tests your patience. If your still having dramas, happy to give you a hand, I start holidays next week. Cheers
