So many mixed emotions
#51 _NSS308_
Posted 07 July 2007 - 11:43 PM
#52
Posted 07 July 2007 - 11:44 PM
Tim
#53
Posted 08 July 2007 - 12:03 AM
#54 _NSS308_
Posted 08 July 2007 - 12:05 AM
#55
Posted 08 July 2007 - 12:07 AM
Obviously the air bags will be there just for show, the wont actually be used to raise and lower the car.
Why bother with bags then? Just go without shocks and springs altogether...
Tim
Edited by RIM-010, 08 July 2007 - 12:07 AM.
#56 _NURVUS_
Posted 08 July 2007 - 12:22 AM
#57 _NSS308_
Posted 08 July 2007 - 12:27 AM
#58 _garagenights_
Posted 08 July 2007 - 01:36 AM
I DIDN'T WANT TO STRETCH THE REAR WHEEL ARCHES ALTHOUGH IT WOULD HAVE MADE IT A HELL OF A LOT EASIER, I JUST THINK THE LC LJ BODY LINES LOOK AWESOME FROM THE FACTORY AND DIDN'T WANT TO DISTURB THEM.
ALSO IT MAKES THE WHEELS LOOK EVEN BIGGER.
ALSO I HAVE HAD 15X10S UNDER THE ARSE THEY JUST HAVE TO SIT IN A LITTLE BIT , I DO PLAN TO RUN THIS BABY IT'S MOST DEFFINATELY NOT JUST A SHOW CAR.
AS FOR THE AIRBAGS THEY ARE NOT JUST FOR SHOW THEY ARE IN THERE PERMANENTLY,THE CAR CAN SIT WITH THE SILLS ON THE GROUND AND WITH A FLICK OF A SWITCH RAISE UP 8 INCHES AND THE RIDE HEIGHT IS TOTALLY ADJUSTABE IN SECONDS. THE REAR AND HAS A TRIANGULATED 4 LINK STYLE SETUP' AND I RUN THE BAGS SIMILAR TO HOW YOU WOULD MOUNT A COILOVER SHOCK.
AIRBAGS HAVE BEEN PROVEN ON THE STRIP AS NSS 308 STATED, THERE ARE QUITE A FEW ADVANTAGES I CAN RUN MORE PRESSURE IN THE RIGHT HAND REAR TO COMPENSATE FOR TORQUE WHICH TRIES TO TWIST THE BODY OF THE CAR COMING OF THE LINE THIS TENDS TO UNLOAD THE REAR LEFT TYRE AND RESULTS IN WHEELSPIN.
WHITH THE FRONT I CAN RUN LESS PRESSURE AND ALLOW THE FRONT OF THE CAR TO LIFT AND TRANSFER THE CARS WEIGHT TO THE REAR WHEELS MUCH THE SAME AS A 90/10 SHOCK WORKS WHICH MEANS MORE TRACTION AND BETTER 60 FT TIMES WHICH AS WE KNOW WILL MAKE OR BREAK YOUR 1/4 MILE TIMES.
MY HK PANELVAN ALSO RUNS FULL AIRBAG SUSPENSION AND IT RIDES GREAT AND ITS MY DAILY DRIVER/PARTS GETTER. AND I CAN PULL UP FLICK A SWITCH AND DROP IT TO THE DECK, MAKES IT HEAPS EASIER TO LOAD ENGINES INTO LOL.
AS FOR THE SPARE YEAH RIGHT LOL
AND TO TAKE THE REAR WHEELS OFF I DO HAVE TO DROP THE DIFF WHICH ONLY INVOLVES 4 BOLTS LOL
AND TO ANSWER THE OTHER QUESTION I'M NOT A MECHANIC BY TRADE, I WORK FOR QANTAS AS AN AIRCRAFT MAINTENANCE ENGINEER BUT I DO HAVE MY OWN WORKSHOP ON THE SIDE WITH A MATE WHERE I MOSTLY DO CARBON FIBRE AND COMPOSITE WORK. BUT ALSO ALOT OF MECHANICAL STUFF.
I RECENTLY BROUGHT A 2 POST HOIST TOO WHICH IS THE GREATEST THING I'VE EVER DONE EVERYONE SHOULD GET ONE LOL I PICKED MINE UP FOR $1000 BUCKS SECOND HAND AND SUDDENLY HAVE A HEAP MORE MATES LOL.
#59 _NURVUS_
Posted 08 July 2007 - 01:47 AM
This is only my opinion and educated guessing and yes i have been drinking so fire away. I do not know Joel personally so even he may not agree with me.
The car looks to have been tubbed (not mini tubbed to the rails) so he will fit massive rubber under there while keeping the 1/4 untouched, throwing big bl#ng wheels under there adds to the wow factor ...(for me anyway). If it was only mini tubbed to the chassis rails then yes, the 1/4 panels would have to be stretched to accomodate the bigger tyres sitting out further towards the guards.
I have no clue of how the air bags are used. On my truck, the air bags replace the springs, i do not know if this is the same case here.
I think that the air bags are there to lower and raise the car, it is a show car and 1000hp is what the elite hall is all about...the complete package.
Hope i havn't started another arguement,seems i'm good at that. Lee.
Edited by NURVUS, 08 July 2007 - 01:55 AM.
#60 _NURVUS_
Posted 08 July 2007 - 01:48 AM
Edited by NURVUS, 08 July 2007 - 02:02 AM.
#61 _garagenights_
Posted 08 July 2007 - 02:22 AM
THE CAR IS FULL TUBBED AND THERE IS NO TORANA FLOOR OR CHASSIS REMAINING IN THE CAR. IT IS A FULL TUBE CHASSIS NOW,AND FULL FLAT FLOOR AND IS RAISED UP ABOVE THE SILLS SO IT CAN GO TO THE GROUND.
AND YEAH THE AIRBAGS DO REPLACE THE SPRINGS
CHEERS JOEL
#62 _LX406_
Posted 08 July 2007 - 02:26 AM
Keep up the good work!
#63 _garagenights_
Posted 08 July 2007 - 02:30 AM
#64 _NURVUS_
Posted 08 July 2007 - 02:47 AM
Sorry mate, i didn't think you were going to reply but beat me to it ,hence my reply after yours. You must type with more than one finger.NERVUS YOUR PRETTY MUCH ON THE MONEY,
CHEERS JOEL
I found out that you can't delete posts and can only edit them once on this site,LOL
Only a handful of posts and i've already made a dick out of myself!!
Sorry for the confusion.
Hows those new pics comin? Got some more?
#65 _garagenights_
Posted 08 July 2007 - 02:51 AM
#66 _NURVUS_
Posted 08 July 2007 - 03:05 AM
#67 _NRV051_
Posted 08 July 2007 - 05:42 AM
Gav
PRO TOURING RULES!
#68 _willo_
Posted 08 July 2007 - 08:01 AM
that just looks SHIT!!!
#69 _misszilla_
Posted 08 July 2007 - 09:07 AM
It's nice, different, unusual
#70 _threeblindmice_
Posted 08 July 2007 - 09:38 AM
#71 _LXChev366_
Posted 08 July 2007 - 10:06 AM
You can only edit the post within the first 10 minutes or so, after that it locks you out.I found out that you can't delete posts and can only edit them once on this site,LOL
Note the original time I posted this... I will come back in 5 and edit it, you will then see "edited by" bla bla on the bottom....
Here ya go... edit at 10.12 am. Origanal post was at 10.06
Edited by LXChev366, 08 July 2007 - 10:12 AM.
#72
Posted 08 July 2007 - 10:58 AM
#73 _NSS308_
Posted 08 July 2007 - 11:33 AM
#74 _garagenights_
Posted 08 July 2007 - 11:51 AM
As for you willo go play in the mud with all the other carny folk who think there race car drivers, you probably didn't even build your own speedway shitbox. but gee it just looks so nice lol.the craftsmanship is second to none i'm sure theres a valiant forum on the net somewhere where there are more of your kind go play in the mud with them.
#75 _garagenights_
Posted 08 July 2007 - 11:55 AM
awesome mate sounds like you got some sweet cars up there yeah i'd love to see some of them and anytime your down this way let me know.Hey Garagenights, your project is crazy keen to see it finished. I am from sunny coast and have some cool projects on the go up here. Just finished windowless hq panno for a mate of mine.It runs original white paint and brown vinyl bench seat and 10/71 blown methanol 454. its on the deck and has done quite a few street kays since finished a couple of weeks ago. also doing 50 cadillac low rider, also mini tubbed and caged nitrous 355 lx sedan and 390 cube 4v clevo in td corty to name a few. We get down gold coast a bit, maybe catch up and suss your projects out sometime. Cheers Stewie
