My Hatchback Rebuild
#51 _Barman_
Posted 22 August 2008 - 07:37 PM
Need to change my little pic(avatar) no longer have SL/R....
#52 _Barman_
Posted 23 August 2008 - 09:10 PM
also found 3 pistons with broken top rings.
also looks like some mild porting ..
striped 9inch and sanded ready for paint
and picked up a 5 speed for my new daily driver HJute
anyone know what is is I need a new clutch plate,
#53
Posted 23 August 2008 - 09:22 PM
Don't forget to replace the bearing in the back of the crank with the correct fitting one.
Dellows in sydney sell them.
#54 _HQ SS_
Posted 23 August 2008 - 10:43 PM
a different crossmember and possibly a different speedo cable. (I am not sure from the end of the cable it shows in the picture)
If you contact either Dellow or CRS they sell a slip yoke to suit std Holden uni's so that you do not have to get a tailshaft modified
to suit, you can just use the std one.
Looking at the bellhousing You will need a HZ pull type clutch cable and peddle assembly and also the thrust bearing and carrier to
suit the pull type clutch system as well and thinking about it you will also have to cut a hole in the firewall for the cable to go thru if
this is to go in to a HJ.
I may be easier to get the push type clutch bellhousing and fit that but the pull type system is the better set up.
If you have a look here
http://gallery.oldho.../Tech/Gearboxs/
There are pictures at the bottom of the page that show what you will need if you want to go the pull type clutch route.
Cheers Paul.
#55 _Barman_
Posted 24 August 2008 - 07:16 AM
And im gunnna get my ute regoed with 3on tree then put 5speed in, to save $110 for mod plate, doin the same with bench to bucket seats.
Baz
#56 _Barman_
Posted 24 August 2008 - 07:27 AM
Im goning to buy a procomp stroker kit so i wont be needing any thes bits,
#57
Posted 24 August 2008 - 11:57 AM
FYI some brands and models may need a slight amount taken off the inner diameter of the pressure plate for the clutch plate to fit in.
Always check the fitting of new parts well when mixing and matching brands/ parts etc.
EDIT, if not replacing ur pressure plate, take it with u to the shop if possible.
Edited by ALX76, 24 August 2008 - 11:58 AM.
#58
Posted 24 August 2008 - 02:10 PM
Tim
#59 _Barman_
Posted 24 August 2008 - 05:50 PM
tell me of other kits and prices before i measure up blockand buy a kit ,please
#60 _Barman_
Posted 24 August 2008 - 05:52 PM
#61
Posted 24 August 2008 - 06:03 PM
I have read a lot of bad stuff about Procomp/Sydney Speed Supplies/AT Racing, and not a lot of good stuff...
Have a squiz here - http://www.fordmods....its-t64899.html - that was found with a quick Google search.
Also here - http://www.calaistur...ead.php?t=95132
and here - http://www.aussiev8....s-anyone-2.html
and also here - http://forum.streetc...pplies strokers
Doesn't look promising... I'd be looking at a ProStroke kit...
Tim
#62 _user asked to be removed_
Posted 24 August 2008 - 06:23 PM
Pro-Stroke make brilliant stroker kits
Edited by Liam.W, 24 August 2008 - 06:24 PM.
#63
Posted 24 August 2008 - 06:30 PM
#64
Posted 24 August 2008 - 06:33 PM
#65 _Barman_
Posted 24 August 2008 - 06:39 PM
i noticed ill have to get a gasket fit aswell...no problem
#66
Posted 24 August 2008 - 06:59 PM
As RED says in his signature: 'The bad taste of poor quality remains long after the sweet taste of low price is gone'. Or something along those lines anyway...
Better off paying a bit more and getting a good, proven product than buying a cheap shit one and replacing it anyway.
Tim
#67 _Barman_
Posted 09 September 2008 - 07:15 PM
(so i can carry people in back without scraping)
Replaced all bushes in diff and cleaned it up and paint ...
Starting on frontend I have all new bushes ready to put in ....
And i cleaned up on Fathers day New gas/gasless mig and a VB bar fridge...fully loaded
gotta be happy about that..
#68
Posted 09 September 2008 - 08:17 PM
#69 _UNVSM8_
Posted 10 September 2008 - 05:28 PM
#70 _TJ253_
Posted 10 September 2008 - 05:37 PM
make sure you get plenty of pics up
#71 _Barman_
Posted 10 September 2008 - 07:12 PM
and prostroke 355
and im real keen to get it done..
pics later...
#72 _UNVSM8_
Posted 10 September 2008 - 07:42 PM
#73 _Barman_
Posted 10 September 2008 - 08:16 PM
and replaced upper inner bushes and lower inner bushes,and paint
also painted rear shocks and swaybar , assemebly tommorow, pic when done
cheers Baz
#74 _Barman_
Posted 11 September 2008 - 07:58 PM
put centre in and axles in
Turned back to upright
painted swaybar and fitted..
#75 _evilsim_
Posted 11 September 2008 - 08:26 PM
