is the L34 the most collectable holden? (roadvehicle)
#26 _BATHURST-32D_
Posted 16 January 2009 - 05:44 AM
72 bathurst lj
lc xu1
l34
a9x coupe
73 bathurst lj
then to me nothing else matters.
cheers john
#27
Posted 16 January 2009 - 07:05 AM
I don't want to be too pedantic but the 1st 427 Monaro wasn't a Holden, it wasn't even a Monaro. AFAIK it was badged the HRT 427 & was made by HSV. HSV weren't allowed to badge their 2-door coupes as Monaros, they were called GTO or GTS Coupes. etc.Just on the 427 Monaro, yes there were 3 race versions built, 2 by GRM and I think the third by Team Brock. The road going versions however, one show car (fitted with a Gen3) and one pre-production car, which was formally owned by Yellowa9x's and I was lucky enough to drive at Eastern Creek in 2007.
I'm also of the opinion that the HRT 427 showcar/prototype was a different car altogether to the 427 'Monaros' built for the Nations Cup races. The original HRT 427 had wishbone front suspension & many other expensive tweaks that the Nations Cup cars didn't get. Didn't the 2nd version of the 24 hour Bathurst Monaro get a Harrop diff with 9" Ford internals.
Dr Terry
#28 _Skapinad_
Posted 16 January 2009 - 07:34 AM
#29
Posted 16 January 2009 - 07:40 AM
I remember someone telling me (I think it was Ben Stewart) that the HRT-427 as displayed at the Sydney motor show was actually the same car that debuted at the earlier motor show as a CV6! So in effect it was a secondhand car by the time HSV got their hands on it.
The pinnacle of the lot if we go into one-offs has to be the Black XW Bill Bourke Special. Or maybe the single Phase IV XA coupe built. I just wish Holden had bit the bullet and put a big block (even as a one off) into a HG oor HQ coupe.......
#30
Posted 16 January 2009 - 07:44 AM
#31
Posted 16 January 2009 - 08:30 AM
In reply to the original question, in terms of the most collectable Holden, I think the L34 is right up there but due to us all having our own opinion, you'll never get everyone to agree with you on this.
It won Bathurst 2 out of 3 times, just like the A9X did, and came 2nd on the other occasion which is 1 place higher than the A9X managed on debut so its racing pedigree is solid
It was hard to buy one, I don't think you could accidently end up with an L34 in the same way that you could accidently get a Bathurst XU1 (apparently)
It introduced a long list of upgrades like the 14" wheels, bolt on flares, bigger front brakes, as well as the HO kit, I mean it was a car designed to race under the rules of the day wasn't it, like the Bathurst XU1s were, and I don't think this applies as much to the Bathurst Monaros or the A9X, both of which were sold with fairly standard engines. So the L34 was the last Holden to be available with factory 'hot' engine bits available.
#32
Posted 16 January 2009 - 09:07 AM
What is the best/ most expensive/ rarest/ ect.
Everybody always selects the 'mainstream' vehicles. GTHO A9X E49 ect.
All the manufacturers [then & now] had their own tuning shops, where the 1off prototype vehicles were produced.
A lot of this work was 'outsourced', but it was usually always the same group of ppl doing the work.
There wouldn't be a Holden/ford/chrysler billboard on the building.
Sometimes these 1 off creations would be produced by the manufacturer, usually they wern't.
Most of these '1off prototypes' were crushed after the development was completed.
Bill bourke's big block XW is one of those cars.
I would bet my bottom $ that at some time, GMH would have tried to slot a 350 into the LH, what would that car be worth if it was found in a barn?
Little known is the prototype of the XC Cobra.
Ford actually built 12 of these coupes & sold them through dealers/ gave them to factory drivers.
It is on record, that Dick Johnson was given 1 of these, among others.
Factory fitted Simmons, droptank, oil recovery system, rollcage [removed for street use], straight cut gears in the toploader, locked 9", ect.
I was fortunate to drive 1 of these cars many years ago. The owner still has it!
Or how about the VG ute that chrysler used to test the E49 mechanicals?
A E49 ute would have been a wild ride! LOL
What would that be worth? How collectable?
Or the Leyland force 7V! You want to talk limited numbers.........
Is the L34 the most collectable Holden?
It probably is.........if you own 1!
But i doubt it!
Flame suit on......cheers, Col.
#33
Posted 16 January 2009 - 09:11 AM
It is correct that the HK 327 engines were pretty much stock engines, but the HT GTS350 manual engines, especially the later cars were by no means a slug. These easily outpowered an XW GT-HO and dyno tests and 1/4 mile times (and race results) of the day reflect this. Put an L34 and a HT GTS350 on a straight road and the L34 would struggle to keep up (until some corners were found of course!)
I would have also said that the L34 was close to the start of factory "hot bits" being available. HDT made 186 cast fuellies available for a limited time for the HT GTS350, but remember factory "hot bits" extended into VH/VK days where HDT bits were fitted to Holdens on the line which ended up in non-HDT cars eg intake, B cast heads, windage tray etc. Even the Group A packages had such stuff added for Homologation purposes. One reason the A9X had a standard engine was there was no need to have anything else but (another being ADR27A). The L34 spec engine was homologated for Group C and hence was allowed to be used for racing. The A9X just homologated the diff, brakes and suspension among a few other bits.
All said, I agree that the L34 is close to the top in collectability. To me it just comes behind the HK/HT 1837 Monaros and LX SS A9X. Probably line ball with the 1973 Spec XU-1. This is without including the VK, 2 x VL and VN GroupA HDT/HSV's as well.
Edit - Col, The Bill Bourke XW wasn't a prototype like the V8 XU-1's. It was a proper coded production car built by special request for Bill Bourke. It would never have been destined for the crusher.
Also forgot, remember that the engine code for the HK GTS 327 engine was L34! That car was always meant to be coded as a HK GTS (737) with engine option L34, just like the LH SLR5000 with engine option L34 was. GM politics caused Holden to hide it as a separate model. The extra power was gained by using a bigger standard engine rather than a modified same size engine like was done with the LH.
Edited by yel327, 16 January 2009 - 09:17 AM.
#34
Posted 16 January 2009 - 10:28 AM
I always thought the 68 Bathurst cars were pretty much your standard engine, for 69 the XW Windsor HO was probably a more 'hotted up' engine than the HT GTS 350 and then it was on for young and old in 1970 with the Phase 2 and the XU1.
Then after a few years of madness the factory hot bits ended. HDT introduced some hot bits but the engines were much more civilised than the 70-74 stuff.
#35 _oz772_
Posted 16 January 2009 - 01:06 PM
As for the two VG mule utes that they developed the E38 mechanicals in, a friend of mine owns both of them. They are both currently being restored in central Vic.
#36
Posted 16 January 2009 - 01:18 PM
because they don't have much of a race pedigree in Australia
Ok...they might not have won, but didn't they do ok in the places?
Great to hear the utes are still around!
#37
Posted 16 January 2009 - 03:32 PM
Not disagreeing here, just trying to put it all together in my head as I was a bit young at the time to be into the scene,
You are correct that the 1968 HK's were bog stock, small valve truck engines (Tonnawanda sourced). The second type 327 engine (Canadian built) were even less powerful. Remember though this is how the original muscle cars were built ie smaller body with bigger car's engine (engine ostensibly from the CKD Impalas, Parisiennes etc). The HT 350 had much better heads and higher compression (10.25:1, HK was 8.75:1). The XW GT-HO was a purpose built race car and was an awesome car, just the HT was better! The HT could also be ugraded with 186 cast fuellies.
Mike Preston quoted his figures on Fastlane for his HT GTS350 when bought new on Perfectune's dyno at 245 rwhp, dyno was setup to reflect engine hp. His mate's XW GT-HO managed 224hp. Here is the link where it's discussed:
http://www.fastlane....earchTerms=dyno
The reason the factory Holden hot engines died off was because there was no need to anymore once the L34 engine was homologated. It became important again in 1985 when GroupA kicked off. Ford pulled out of racing so they didn't officially bother past the PhaseIV effort.
#38
Posted 16 January 2009 - 04:33 PM
Gotta love the info that comes out on here.
#39
Posted 16 January 2009 - 05:27 PM
HK 1837 in Yellow
LX D77 A9X in White
LJ XU-1 in Bathurst 1973 spec in Silver
VH E49 in Silver
VH E55 in Yellow or Orange
XA RPO83 in Black
XW GT-HO or GT-HO Phase II in Red
HSV V2 GTS in yellow
HJ Kingswood Sandman ute, 308 TH400 in Black
VN Group A
Imagine that lot in your Garage!
Alongside:
Dodge Charger 426 Hemi manual (General Lee)
GT500 '69 Mustang
69 ZL1 Camaro
Fuel injected '57 Chev 2 door pillarless Belair
Just to name a few......
#40 _oz772_
Posted 16 January 2009 - 06:48 PM
Wasn't meant to be harsh, just that Chrysler pulled out of racing with the supercar scare, and that was before the E49 ever hit the race track. Leo G got togather a bit of dealer support to run his car and Doug Chivas (legend) prepared and drove Damon Beck's car, which he bought from a dealer in Dubbo. 49's did very few races in Australia. The kiwi blokes had them going well across the Tasman, but when they came to Australia, they couldn't repeat the performances. They are something to drive though - my old E38 was at 49 spec and running a 4 speed. They were just a handful around corners, especially with anything over 100 litres of fuel in them. The mule utes will be something to see when they hit the road - the owner is making sure everything is how they were when the Geoghegans were lapping them out at Mallala in 70 and 71.
Edited by oz772, 16 January 2009 - 06:52 PM.
#41 _rorym_
Posted 16 January 2009 - 06:54 PM
Edited by rorym, 16 January 2009 - 06:56 PM.
#42
Posted 17 January 2009 - 08:22 AM
Hmmm...L34 due to numbers...but the full development of that car was the A9X....as much as I hate to say it...I would prefer the A9X in the shed...the ultimate Torana...others?...easy..1966 Mini Cooper S ..original...Giant Killer...never underestimate the little cars...1-9 at Bathurst 66....its not always about engine size....Twin Cam Escort...another Giant Killer...finally...73 Bathurst XU1...my fav...wish I still had them all... Collectable USA car?..No contest ...1969 302 Boss Mustang...sexiest car alive....
Rory, you'd have the Boss over a GT500? I'd have to agree with you on how good a '69 looks. I prefer a '69 Camaro though. I'd love to have a 428 '69 'stang and a 427 '69 Camaro.
#43 _Dirty Deeds_
Posted 17 January 2009 - 08:23 AM
As fas as US muscle, agree 100%. Everyone loves the 69'r. We've got a 66 Coupe and I always say that the 69 Boss is the only one we'd trade into.
DD
#44
Posted 17 January 2009 - 01:16 PM
DD
I just did some looking on the 'web. It was the '68 GT500 I meant, the '69 is ugly. And the '69 Boss is a much better looking car. I like the Camaro better but I see what Rory means, the boss is a sweet looking car. Now the boss body with a Cobrajet 428.....
#45
Posted 17 January 2009 - 05:38 PM
DD
I used to 100% agree as well, but lately I have seen some absolutely stunning 65 mustang fastbacks that have made me change my mind.
It would also be a close race between a Hemi Cuda.
#46
Posted 17 January 2009 - 07:08 PM
woops, i'm off topic. lol
#47 _JBM_
Posted 17 January 2009 - 07:24 PM
It has a limited run, unique engine, flares and a HO pack. No other car has all of these items.
However its not the most practical car to own, its a rolling museum piece at best.
James
#48
Posted 17 January 2009 - 07:29 PM
Give me a split window 'stang with a Gen3! mmmmmm....................
Don't you mean 'Vette?
#49 _bathurst-racer_
Posted 17 January 2009 - 10:35 PM
An L34 is certainly my most admired Holden though I always wanted the Fords to win when I was a kid. I hated the fact that a lot of Toranas were painted up with putrid tobacco sponsorship. Thank goodness those days are over.
#50
Posted 18 January 2009 - 09:25 AM
LOL, yep.....bitten by the scotch monster again!
