UCANG is back after 2 years
#51 _Liam_
Posted 08 January 2012 - 07:57 PM
#52
Posted 09 January 2012 - 09:11 AM
#53 _wally308_
Posted 10 January 2012 - 09:55 AM
Keep up the Good Work we will be Cruising in no Time..:-)
#54
Posted 10 January 2012 - 10:41 PM
#55
Posted 13 May 2012 - 07:04 PM
the engine bay is also stripped, ready for some mods.
#56
Posted 13 May 2012 - 07:12 PM
#57 _sjp67m_
Posted 13 May 2012 - 08:51 PM
Do you want to come up to Darwin and do my repairs lol ! :-p
#58
Posted 17 May 2012 - 09:18 PM
It's good to see someone that skillfull with the metal work and welding!
haha a bit too hot, and when its not hot, its wet and hot!
#59 _berro59_
Posted 17 May 2012 - 09:52 PM
I ve noticed the c pillars are next.
Nearly there.
Keep it up.
#60
Posted 17 May 2012 - 10:19 PM
Man you have been busy!
Nearly there.
Keep it up.
Not really Berro, been a couple months since working on the car (got married and everything that goes with it) but now im cranking an hour each day after work, and solid days worth during the weekend. So chipping away.
Yes the C pillars are next, I was only just making the inner skin today... I procrastinate alot though, because every bit of piece I went in, I always make sure the underside is not bare metal.. So rust converter, etch, weld in.. maybe i'm going too far with it.. piece of mind I guess!
My digital camera has a backlog of pics, will upload them in due time
#61 _greenmachine215_
Posted 18 May 2012 - 02:44 PM
Some killer metal work skills you got there, that your trade by any chance??
Whens the front end happening?
Posted 18 May 2012 - 05:58 PM
Good to see another uc being done right!
Thanks for your kind works, greenmachine..
No, no trade, just enjoy metal work I guess...
Not doing the front end conversion, I like UC's, im just improving the rear - something interesting I guess
#63 _greenmachine215_
Posted 18 May 2012 - 06:29 PM
What do you do for a crust if u dont mind us asking?
#64
Posted 19 May 2012 - 01:11 AM
#65
Posted 19 May 2012 - 05:44 PM
ouch
first time its seen daylight for a long time
home made so I can use my ground down cutting discs
unpicked
inner skin repair on C pillar
that repair I did earlier now finished
happy with that
I cut out the rusted plenum section, and re made it bit by bit, mostly all new metal now with a hint of original metal
#66 _Liam_
Posted 19 May 2012 - 06:34 PM
#67 _greenmachine215_
Posted 19 May 2012 - 07:47 PM
Posted 27 May 2012 - 04:50 PM
flat tray mod to come..
plenum area
started removing the.. ill call it....."factory rustproofing" on the floor pan and look! Theres a bit of a dent from jacking up I suspect but no rust!
That's all for this week
Edited by UCANG, 27 May 2012 - 04:55 PM.
#69 _greenmachine215_
Posted 27 May 2012 - 11:31 PM
You keeping the factory k frame holes in the top of the rails or filling and hacking the arse out of the sides of the rails?
Should look killer when it's done
Posted 28 May 2012 - 06:49 AM
#71 _greenmachine215_
Posted 28 May 2012 - 09:44 AM
#72
Posted 28 May 2012 - 10:04 PM
Anyway, bought some C pillar repair panels, ready for that job.. Got some more KBS to seal up the metal/ etch underneath and on top of the plenum repair I did. And will be putting some KBS on the inner C pillar skin and backside of the C pillar outer panel. Hopefully slow down the rusting process on a common problem area!
#73 _greenmachine215_
Posted 28 May 2012 - 11:15 PM
Either way your doin a killer job, keep it comin!
#74
Posted 02 June 2012 - 06:14 PM
I fixed all the rust on the drivers side of the plenum and cleaned up the whole area and put some KBS down and the same on the underside.. Pretty sealed now. Tomorrow i'll wipe some Sikaflex over the joins.
I also wire wheeled the boot floor and put some rust converter down.. still a bit of work to do here, but had to clean up there..
#75
Posted 02 June 2012 - 07:28 PM
Good on you for having a go. It will all be worth it in the end.
