UCANG is back after 2 years
#101
Posted 21 November 2012 - 05:57 PM
#102 _toddyz airbrushing_
Posted 22 November 2012 - 11:37 PM
#103
Posted 23 November 2012 - 06:22 PM
Body deadener has been applied to the front inner guards.
Half of the underneath of the car was cleaned and stone guarded also. (I only did half because I dont have a rotisserie!)
I'm organizing the front suspension bushes and balljoints im needing then will work on that next, then bolt it back up to the car.
#104
Posted 24 November 2012 - 02:28 PM
What method did you use to clean it?
#105
Posted 24 November 2012 - 04:32 PM
If my floor pan was in average condition I would of brought out the wire brush on the grinder then went to town that way. Or cleaned it up with rust converter (if light surface rust) and kbs/ por underneath.
Hope that helps, cheers
#106
Posted 07 April 2013 - 11:03 PM
Long time since update. Not too much to show, been renovating new house and preparing old house for sale.
First thing for 2013 though, was the purchase of a standard bore 308 trimatic blue. Got it complete for $300. I wanted something so I can rip down and build it myself so this was perfect. Trimatic pattern so I can fit an aussie 4 speed or something along those lines.
Next I redid the front end. Ive only got as far as clean, de-spatter, paint, new balljoints and bushes and bolt back to the car. I had to stick the old dirty springs in there so I could bolt the wheels on so it can be rolling to the new house. I still need to finish the steering rack, new shockers and springs, complete the HQ brake conversion - but all in due time.
and the last load of pics is it leaving the house. 4 years it came on a trailer in its sad original state, and now its leaving in a somewhat nicer straight state
#107
Posted 07 April 2013 - 11:59 PM
Just read your thread Ang, great work and learnt a few more tricks for my build.
Once you're in the new house it's time to pull your finger out and get back into it.
Love your work.
Marty
#110
Posted 10 June 2013 - 04:39 PM
So better keep busy while I don't have a shed at the new house.
Started to work on the drivers door (this is the worst, and it needs a whole new skin) So I unpicked it,and cleaned her up.
The skin spot welds onto this bit, as you can see its a bit munty
stupid blur
Inner all cleaned up
That section all fixed
Welded back onto the frame
Epoxy some parts
#112
Posted 12 October 2013 - 07:34 PM
Well, bit of an update is overdue. This year pretty much a write off as the new house renos have been top priority, but still finding time to work on her!
Got my new door skins, I decided to go for both sides, Retro rods were so good, i got 2 for the price of one at Rares (pretty much).
Fixed the gap on the hatch lid, sorry this is the only photo i took.
Cleaning and putting some new parts on the steering rack:
Removing skin of other door:
cleaned up ready for epoxy
found rust
Realised that the weather strip mounter needs to be spot welded to the skin first, then attached either side of the door. Makes sense, because with this part left on the door then the skin put on after, will make it very difficult to weld it to that bit of frame and grind down smooth.
other side all cleaned up and zinc primed and welded on
epoxied the inner door frame (and underside edges)
and scuffed the inside of the skins and epoxied. The black coating seemed pretty good, but best to be safe than sorry
#113
Posted 13 October 2013 - 11:55 AM
Nice work there Ang,
Will be like a new car from the inside out when your done!
Sounds like you need to get to and build a shed though!!
#114
Posted 13 October 2013 - 12:16 PM
#115
Posted 13 October 2013 - 01:29 PM
Good work!
The local pizza bar does good enough pizza's without cooking your own.
Will have to catch up with you sooner or later and have a look in person.
If you get time call in to my place one afternoon and have a squiz at some progress.Just give us a buzz here first.
#116 _greenmachine215_
Posted 14 October 2013 - 04:51 PM
Good to see it coming together again! And your doing it all yourself so there shouldn't be any farkups that you payed some clown to do!
#117
Posted 15 October 2013 - 03:18 PM
looking solid ang,
#118
Posted 20 October 2013 - 04:58 PM
Yeah thanks fellas.
And Damo, i'll have to take you up on your offer!
Anyway a bit more progress this weekend.
So the door skins are on. As you can see in some of the pics I have been trial fitting and getting lines to line up and setting some gaps.
I actually hammer and dollied the edge instead of cutting and welding. I like it.
A bit of temporary zinc primer to stop any flash rusting of my work
#119
Posted 20 October 2013 - 06:49 PM
i actually like the look of the fat hotwires under that thing.
#120
Posted 20 October 2013 - 06:58 PM
#121
Posted 28 October 2013 - 05:06 PM
You can see the tape. This is where I need to build up in that area.
Done
Chasing out some highs and lows from the panel beating
Other side
End result. I cleaned up all the zinc spray primer and epoxied my repairs.
Theres still one more panel left to paint strip, repair and epoxy, and thats the bonnet. But i'm going to do that some other time. My next steps for this build, is the filler work. I'm looking forward to it, as its only been metal work since 2009.
I'll keep who evers interested posted.
Posted 28 October 2013 - 05:10 PM
Nice Work.
#123 _greenmachine215_
Posted 28 October 2013 - 06:33 PM
#124 _greg2240_
Posted 01 November 2013 - 10:17 PM
Sure you don't want to put an lx front on it? (please), , wouldn't mind more pointers as your work seems very professional, doin well mate
#125 _greenmachine215_
Posted 01 November 2013 - 11:00 PM
It's only a matter of time before he turns, and finishes the job of properly :-P
