Sometimes it feels like 2 steps forward, and one step back.
I put the engine bay into high build, then started to block the right side wheel arch. Of course, there are alot of high spots, and when I went to tap them down, some areas were weak and pretty much crumbled/ cracked. So I cut the problem area, re welded a nice strong plate. I should of done this first, but ah well, you live and learn. Times like these you wonder why you go through the trouble to customise things instead of keeping standard (engine bay in my case).
However, the repairs are looking much better, and using a lot less filler too once it's all sanded.
On the other side, the weld cracked. I think I ground it down too far that there was pretty much no meat left to fuse the 2 sides together. Plus i'm pretty sure it lacked peno, so re welded. I noticed this once the primer was layed down, I saw this faint line. It's a pain but had to be done now!
However, I did high fill some of the other panels, and it went on nicely.
