The clutch had begun to get some chatter into it and making the car misbehave and as its Amandas car and she will be driving it alot it needs to get sorted.
So i put it up on stands and went to work, Most of it was easy the hardest bit being getting the gearbox itself out as it has some extractors on it and they had to be removed to let the gearbox drop.
It has some worn linkage arms so they will be welded up and re drilled / re shaped
It has had this oil leak since we got it and i thought it may of been the rear main oil seal, turns out it is the front oil seal in the gearbox. Which would explain why only 50ml of oil came out of the gearbox when i drained it!
Years of people not knowing how to change gears + we didn't help it. It also has a loose circlip on the mainshaft. Doesn't matter because i think we will replace the whole box anyway.
Finally its out! It was rebuilt at some stage as it has a sticker on it saying so and also 1986 stamped on it.
Edited by Woodsy, 19 January 2010 - 03:47 PM.
