OVERHEATING ISSUES IN EFI V8 LH
#1 _LH SLR 3300_
Posted 08 February 2010 - 05:42 PM
Posted 08 February 2010 - 06:42 PM
Does it hold around 200? Sounds like you just need to fiddle with the shroud/fan options a little more to get the best compromise.
#3 _LH SLR 3300_
Posted 08 February 2010 - 07:03 PM
#4 _nial8r_
Posted 08 February 2010 - 07:23 PM
#5 _LH SLR 3300_
Posted 08 February 2010 - 07:51 PM
Posted 08 February 2010 - 08:41 PM
You are welcome to look at my setup,
my car has been in 45 degree heat in traffic and temp gauge hardly moved
i have twin thermos and hq 3 core radiator
tony
Posted 08 February 2010 - 09:35 PM
The way I read your first post, I thought you said you'd found a shroud/fan setup that works in traffic at the expense of some extra heat at higher speeds? If so it should be possible to have the temperature steady with some compromise in between.The gauge i'm using goes up to 210F, the temp has gone off the gauge before in heavy traffic while using the thermo, shrouded & unshrouded.
I don't think you'll gain a lot by putting fans on the front, just adding more obstruction. Everyone seems to love those AU fans, is there no way you can get them on there without cutting the car?
Is your radiator an HQ style one? Does the water flow through it OK? Unfortunately the Torana blocks off a lot more radiator than a Commodore but it should still work fine, perhaps its a dud?
Posted 08 February 2010 - 09:44 PM
I might of mentioned it the first time I saw your car that only 2 set ups worked well on my lc.
One was a solid plastic fan,spacers with hq shroud.
Second was au fans.
Commodore clutch fan would be too long,sold plastic fan & spacer will work.
Posted 08 February 2010 - 09:55 PM
Are you filtering the system?
And are you sure it's not cavitated?
Posted 08 February 2010 - 10:44 PM
Tried various water pumps, brand new 3 core radiator with hq fan shroud and plastic fan, still wants to heat up in traffic to the temps you are describing. It amazes me. As soon as i get moving again it will start to cool down. So I ruled it down to either water flow or air flow. But I know the theromstat is opening and have back flushed the block through the two ports either side. No joy.
Last weekend grabbed a set of AU fans. Still yet to fit them (they look fairly simple, im not overly concerned about cutting the car). Bought a manifold screw in temp switch from repco, and flogged a couple of relay's from U-pull it.
Will post up pics of my progress. This is my last resort, as I am sick of this issue, and i bet you are too!
Mike.
#11 _beergut_
Posted 08 February 2010 - 10:58 PM
as these can be faulty out of the box
#12 _BCR42Y_
Posted 09 February 2010 - 07:13 AM
How close is your oil cooler to the the radiator? I didn't look when I saw the car last, but I know that when I moved mine further forward away from the radiator (still need to make up a proper bracket) the car seemed to run a bit cooler.
My car runs the plastic fan with spacer and a big plastic shroud HQ Shroud Link and unless I am in stop start traffic for continuous periods it seems to work fine, in saying that my radiator isn't the best and I suspect that once I replace the radiator it should get better.
My last resort is going to be to fit the AU thermo's, I remember reading somewhere that you can just get them into a Torana without cutting the rails, but by turning them upside down and cutting the shroud, also remember reading that a lot of parts shops will try and sell people the el fans in place of the AU fans which look similar but are bigger.
Most importantly, don't give up, you have built a very nice car, and no doubt this will get sorted!
Edited by BCR42Y, 09 February 2010 - 07:16 AM.
#13 _nial8r_
Posted 09 February 2010 - 07:23 AM
SRY Matt
Posted 09 February 2010 - 08:48 AM
It is a good trick is to put them in a pot,boil the water to see if it opens,ust a thermometer to see what temp it opens at if you can.
Another thing when going to au fans is you'll need a better alternator,80 amp minimum.
Posted 09 February 2010 - 08:52 AM
As Heath mentioned...just maybe the impeller is a different size, & you are getting cavitation from the pump spinning too fast?
#16 _nial8r_
Posted 09 February 2010 - 10:55 AM
thats a good point with the impeller being smaller, didnt even think of that it might be a pain in the ass but i think i would be to see if there is any difference between the stanard one and the new one before going out and handing over any more hard earned coin MattIt seems strange that the only part you changed [from stock] is the waterpump.
#17 _robrenjus_
Posted 09 February 2010 - 12:53 PM
i am sure not everyone would agree but taking out the tried and tested thermostat and replacing it with a new one is not a good idea in my opinion .over the years ive had MANY BRAND new thermostats fail nearly causing damage to customers cars so now days i only fit them if i am replacing one that is faulty or it is required for warranty purposes when fitting new engines ect. And when i do i drill a 1/8 hole in it so if it decides its not going to play than at least there is some flow and it also helps when bleeding air out of the system.1 in 1000? LOL..I got 3 dud ones in a row.They were the Tridon brand.
Posted 09 February 2010 - 01:08 PM
http://www.gmh-toran...=1
Posted 09 February 2010 - 02:15 PM
If you really suspect thermostat when you do this, check it at a few different water temperatures around normal operating temp, from colder and from hotter. For example its not uncommon for a dodgy thermostat to open late or to begin opening correctly but won't open fully until too hot.It is a good trick is to put them in a pot,boil the water to see if it opens,ust a thermometer to see what temp it opens at if you can.
#20 _The Baron_
Posted 09 February 2010 - 02:19 PM
Save the mucking around later.
#21
Posted 09 February 2010 - 03:03 PM
I run a 383 holden (pretty grunty setup) on straight LPG in a lx sedan.
With the following cooling system I have no probs, even on the 40+ degree days.
EF/EL twin thermos behind rad (yes I trimmed the inner bay)
Desert cooler 4 row tripple flow rad
Std type water pump ie not the ninja star style blades
160 F tridon hi flow thermostat
Filter in top hose (pantyhose)
All air gaps around rad and fans taped/siliconed up
Recovery style 15psi cap with recovery overflow bottle.
I think you are correct to assume your problems relate to either too little water flow or too little air flow.
Good luck, I am sure your problem is solveable.
Rexy
#22 _LH SLR 3300_
Posted 09 February 2010 - 06:39 PM
On the reverse side of the shroud you can see the foam tape i applied to seal around the shroud in an attempt to make sure the fan pulled air through the radiator core, not from the engine bay. This set up worked reasonably well at low speeds, although after long periods of sitting in slow moving or stationary traffic eventualy the car would start to heat up. On the motorways this set up worked OK cruising on 1500-200rpm but i had to run the fan constantly & giving the car revs saw the temp climb. With the fan by itself without the shroud it was OK cruising etc but slow moving or stationary traffic saw the temp climb. This is how the car is now, an 82mm fan spacer & a six blade plastic fan. This has worked the best so far but again in slow moving or stationary traffic the temp will climb quickly. I know a shroud may help here but finding one that will fit has been difficult plus this was just an experiment & temp fix as this car is my only form of transport at the moment so i needed something that worked better than the set up i was using. I'm hoping to replace it with a thermo fan set up that works properly.
If it is more likely to be insufficient air flow,i'm not sure what to try next, twin 12 inch thermos seem to be a common fitment on these Toranas but i'm not sure how i'm going to mount them. I don't like mounting them directly to the core as i had one rub through & cause a leaking radiator on a 202 LH i had years ago. Heres why i'm having trouble with mounting fans on the rear side of the radiator (& a cowl for the engine driven fan). Rather than cut away the flange on the edge of the chassis rails as some people do, i trimmed 15mm off the sides of the radiator that a cowl etc normally bolts to. There is still 10mm left & i have mounted the DC fan & shroud here with no problems, it just makes it hard to use AU or VT-VX fans or the like as they are too wide.
I've looked at aftermarket 12 inch fans but the ones i've looked at aren't mounted in shrouds like the AU etc, i'm assuming they will need to be??. Anyhow i'll keep going through some of the checks that have been suggested here & confirm that everything else in the system is working as it should before i try anything else. Thanks again everyone for the advice given.
#23 _ass308_
Posted 09 February 2010 - 07:35 PM
have u checked to make sure u arent getting any hose cavitation.
the guy at pwr told me one 16inch 3000rpm fan was better than 2 12 inch fans,that they offered.when i bought my set up.
also that photo 4th above,it looks like the top hose goes down,makeing a high point at the radiator.i know my 308 hose goes up,high point at thermostat.i have know idea what this means,just pointing out a difference
its a bit of mucking around,but maybee swap the radiator from the 355 over.its a pwr from memory.cant remember if its 1 fan or 2,but i remember u saying it worked fine.
good luck.
#24 _BambooRon_
Posted 09 February 2010 - 08:03 PM
one thing not mentioned if a radiator is left out of the
car without water, the brown shit inside curls up away from inside
of the tubes-shake one when dry and listen.
Doesn.t matter how "clean things look"-get it cleaned
or "i don't think its that, because"-brought the best undone
go back to basics-it didn't overheat before and u changed the pump
why wouldn't u double check that
and finally stock metal fans throw fins through the bonnet
good luck
#25 _nial8r_
Posted 10 February 2010 - 10:38 AM
thats a bloody good idea, but one question ?? wouldnt it cause the thermostat to take longer to open ??
