Pete's One Tonner build up
Posted 27 October 2010 - 01:35 AM
It's had some interesting repairs over the years but nothing that isn't normal for a tonner.
It's going to get a smooth chassis, flat firewall, smooth inner guards, shaved door handles (already done but need fixing), smoothed rain gutters, custom tray, 2 bonnets - one with a hole for a bug catcher and one without, but they'll both have flat undersides for a totally smooth look. It has a 308 and 4 speed and will run 17x8 Boyd Coddington Smoothies.
There's a lot of work to do in here before it can be called sexy : )
These plates that have been added to the chassis will be cut off and redone to smooth this section out.
The rear of the cab has had a section added to provide more room inside. Unfortunately when it was welded in it buckled so badly it's not worth trying to fix. I'll end up removing the whole rear panel from below the rear window and replace it.
All the holes in the chassis have to be welded up too. I am a glutton for punishment, but it will look awesome when it's done.
Here's Pete and his tonner. I don't know exactly how long he's had it, but it would be in the 10 year range, probably more.
Let the fun begin!!!!!
Because I'm going to cut the rear of the cab off, it wasn't worth stripping the paint off, but the rest of it is pretty much gone now.
Some of the little rust bits.
And then it was covered in the usual layer of rust converter.
This is going to be a fairly long term project so progress wont be particularly fast. I still have to strip back both the bonnets and all the inner surfaces, but this is a good start. Should be a fun one. I'll be painting this car, as I wasn't 100% happy with the finish on my brothers hatch. Plus, that was the first time I built a car and didn't paint it. It just didn't feel right.
#2 _mick74lh_
Posted 27 October 2010 - 08:27 AM
Posted 27 October 2010 - 08:30 AM
Posted 27 October 2010 - 10:07 AM
Looks like an awesome project. What do you use for stripping paint off exactly?
Hi Mick. I use a 2 speed sander/buffer with 24 grit sanding discs to remove paint.
#5 _1uzbt1_
Posted 27 October 2010 - 10:25 AM
#6 _Herbinator_
Posted 27 October 2010 - 03:14 PM
#7 _shadowmaster_
Posted 27 October 2010 - 03:39 PM
#8 _Woodsy_
Posted 27 October 2010 - 03:50 PM
Posted 27 October 2010 - 08:44 PM
Here is how its done (scroll about 2/3's of the way down)..... http://www.mcdonaldb...kprojects1.html
Posted 27 October 2010 - 08:55 PM
How's the UC going?
#11 _Bomber Watson_
Posted 27 October 2010 - 09:51 PM
I assume this means your building me a spray booth for when i come work for you in that case
Posted 28 October 2010 - 06:38 AM
Yeah Andrew I love their stuff, but if I did that it would NEVER get rego in Qld. They're really strict about commercial vehicles since they got the shits with all the lolux boys and their dodgy 4 link/airbag set ups. Plus it's only getting 8's on it, which will look good for a tidy street car.
How's the UC going?
Don't bother with the 4 link etc. Just narrow the chassis as they did (it would be almost impossible to spot, shorten the diff housing and original cross members etc and run with it !
I hope to get some colour on the UC in the next week or 2. Will update my thread soon.
#13 _Barman_
Posted 28 October 2010 - 03:10 PM
Is that a 1tonner chassis or a ute chassis, 1tonners are longer and they look weird
if its a tonner cab on a ute chassis, i had 1 and i sold it because of it.
Baz
#14 _1uzbt1_
Posted 28 October 2010 - 03:35 PM
#15 _Herbinator_
Posted 28 October 2010 - 04:31 PM
Hey
Baz
It was a bog stock tonner when i bought it.
Posted 28 October 2010 - 06:11 PM
#17 _Quagmire_
Posted 28 October 2010 - 08:09 PM
The one tonners chassis are the the only ones with that big triangle gusset in them too, just behind the cab.
this will be good
going to get some beers and pump some tallica and enjoy the show
#18 _eh-buddy_
Posted 28 October 2010 - 10:14 PM
#19 _Herbinator_
Posted 30 October 2010 - 07:21 PM
Edited by Herbinator, 30 October 2010 - 07:22 PM.
#20 _eh-buddy_
Posted 30 October 2010 - 07:47 PM
without seeing a clear look off the dash what is hq/j/x/z??
Edited by eh-buddy, 30 October 2010 - 07:48 PM.
#21 _Herbinator_
Posted 31 October 2010 - 05:40 AM
not a bad looking car to start with it will be good to see it coming along
78 hz
#22 _wblje_
Posted 31 October 2010 - 09:44 PM
#23
Posted 08 November 2010 - 12:03 AM
You can see here that the door is fairly ordinary.
The panel at the back of the cab got welded in too hot and has buckled everything, so I'll cut this whole piece out from under the window and replace it.
Usual door rust. There is also a little bit in the sill but it's not visible in this pic. Still, not bad for a tonner.
OK, so I left it for a few days and when I came back I figured I'd better strip the bonnets. Yes, two of the bloody things : (
The bonnet on the car has about 16 layers of paint on it and it took AGES to strip back. Thanks Pete : )
After half an hour I had this -
Nearly an hour and I was sick of the bonnet already so I did a bit on the dash top. Found some rust there too, but nothing too unusual.
This bonnet has a fairly drastic dent in the front of it. Most of them do from where you push the bonnet down to close it, but I've never seen one this good : )
Here's the hour and forty minute mark.
Found this lovely repair (?) on the left side of the bonnet.
Finally : )
I also stripped around the windscreen, the rest of the dash top and around the left door frame.
There's a few little holes around the top of the windscreen, but nothing major.
Some more rust in the dash top.
I also stripped the paint from above the rear window.
Then I was lucky enough to start on the second bonnet.
It's not bad except it had a lot of surface rust spots under the paint and a few tiny rust holes.
Here it is all rust converted. I'll give this lot, the kombi and the camaro another lot of etch primer tomorrow to seal everything up. The kombi is getting stripped back at about the same rate as this so priming them together makes it a bit easier.
You can just see the kombi in the background. The cab is now totally stripped back and rust converted. I'm not going to worry about stripping the side panels as I'm going to make new ones from scratch.
#24 _2DR_
Posted 08 November 2010 - 09:51 AM
are you just spraying straight over the rust converter or
#25
Posted 08 November 2010 - 11:57 AM
