Pete's One Tonner build up
#51 _jabba_
Posted 20 November 2010 - 09:02 AM
#52
Posted 06 December 2010 - 06:25 PM
First thing I had to do before stripping the ute down was to get the hole in the bonnet sorted out as it looked like someone cut the existing hole out with a sharpened hammer.
After getting any of the bits of metal that were too close to the scoop ground away, I used 50mm masking tape to get a more accurate hole marked out. This shape was then transferred onto cardboard so it can be used as a template for when I redo the hole. Also, both bonnets are getting flat sheeted underneath, so I can use the same template to put the hole in the under side sheet too. The hole in the underside will have to be a bit longer at the back to allow for the bonnet coming forward as the hinges raise.
The butterfly linkage also needed to be sorted out and fitted so the hole could go around it.
The butterfly rod is now bolted through the carby linkage where the accelerator cable used to mount. I'm not happy with the cable being in front of the motor so it will come in from the back of the motor and attach to the top of the carby linkage instead. It will look a lot cleaner. This pic just shows the butterfly linkage, the accelerator cable is still in it's original position.
This is how the scoop sits with the bonnet fully closed. Personally I'd like to bury this scoop, as 1986 is long gone : ) It's not my car though so I'll just shut the hell up! hahaha, Sorry Pete : )
The next fun job was stripping the panels off and stripping the paint off the door jams and inner doors. The cowl vent and top of the firewall also got taken back to metal, as did the entire A pillars.
A few little bits of rust but nothing to get too worried about.
The plenum seems pretty clean inside. Looks better on the outside now too.
The inside of one of the doors got stripped as well. What a crap job that was!!!!
There is only a very small amount of rust in the inside of the door.
Well that doesn't look too much but it took care of today.
#53
Posted 06 December 2010 - 07:26 PM
all this talk of head butting the dash reminded me of why id never own a early commodore... Bet the passenger would hit there head in that crash hahaha. :S.
http://www.youtube.c...feature=related
From Wikipedia - http://en.wikipedia....en_VB_Commodore
100 kilometres per hour (62 mph) Holden VB Commodore crash test.This test was conducted on 9 June 1992 by theRoads and Traffic Authority(RTA) as part of a test series to commission the Crashlab test facility inRoseville, New South Wales, Australia. The test was of the facility's drive system, not the actual car which had thetail shaftremoved, 300 kilograms (660 lb) of sandballastplaced in the footwells andbootand a 75 kilograms (170 lb) ballast dummy placed on the rear seat. This was supposed to represent a worst case scenario.
The Tonner's coming along nicely Dirtbag.
#54 _Herbinator_
Posted 06 December 2010 - 07:27 PM
And i like the scoop. So now i will go cry into a rum.
#55
Posted 06 December 2010 - 07:38 PM
#56
Posted 06 December 2010 - 07:45 PM
Should no longer be alive.
Stay on his case and bury that ugly sucker.
#57 _LH SLR 3300_
Posted 06 December 2010 - 08:38 PM
#58 _Woodsy_
Posted 06 December 2010 - 09:05 PM
#60
Posted 07 December 2010 - 12:26 AM
#61 _gtr-xu1_
Posted 07 December 2010 - 10:01 AM
#62
Posted 07 December 2010 - 05:13 PM
Can I have it? Would look great on my torrie ute : P
#63
Posted 08 December 2010 - 07:17 AM
That's the shell all done now, as I'm making a flat firewall for it so stripping this one back is pointless : )
#64
Posted 08 December 2010 - 03:16 PM
#65 _wblje_
Posted 17 December 2010 - 05:37 PM
#66
Posted 17 December 2010 - 07:17 PM
get crackin need to see this thing looking sweet. how does it go with legalities with the bonnet scoop. does it meet requirments like no higher than half a tampon or something. or is it going to be registred as a classic over 30 yrs old. not 100% about rulings but am keen to know as id love a scoop on my tonner.
Hiya. In Queensland at least any part of the engine sticking out of the bonnet is illegal, no matter how high or shiny it is. The only cars that get away with it are hot rods (pre 1948) trans ams, mustangs etc with shaker scoops. There is no way in the regulations that would let a scoop like this be legal. Another reason is the leading edge flares up, where it would have to flare down to give a rounded front. I guess you just take your chances.
#67 _Woodsy_
Posted 22 April 2011 - 10:49 PM
Edited by Woodsy, 22 April 2011 - 10:50 PM.
#68
Posted 24 April 2011 - 07:28 PM
#69
Posted 24 April 2011 - 08:18 PM
Pity. Could have been a nice unit!
#70 _Bomber Watson_
Posted 24 April 2011 - 11:41 PM
#71
Posted 26 April 2011 - 10:12 AM
#72
Posted 22 May 2011 - 04:53 PM
#73 _wblje_
Posted 23 May 2011 - 09:42 PM
seeing as its a non payer that means you keep it until paid for so its yours now............i might place a bid
#74 _Quagmire_
Posted 23 May 2011 - 10:01 PM
one carton of xxxx
you know that horrible crap those wierdoes call beer
#75 _Bomber Watson_
Posted 25 May 2011 - 07:06 PM
