Project: MKII Cortina
#51 _wblje_
Posted 23 May 2011 - 09:28 PM
#52 _jabba_
Posted 25 May 2011 - 01:53 PM
#53 _jabba_
Posted 25 May 2011 - 08:00 PM
Here i have started to unpick the drivers rear 1/4 panel
mmm rusty
Somehow i missed taking a photo with the entire inner and outter panel removed, but in the next few photos you can see that we have replaced the entire piece and started to weld the replacement panel in! Woohoo!
#54 _udderchaos_
Posted 26 May 2011 - 10:53 PM
interesting little cars
#55 _jabba_
Posted 21 June 2011 - 04:43 PM
Neil talked to an engineer today and got the thumbs up to join the chassis rails, he also mentioned 4 link rear end to him and he said show him what we are planning and he would decide .
I cut more of the old rail out and stuck some 65x35x2mm RHS between the front and rear rails, i initially thought id have to put a slight bend in the rail but turns out with minimal work it fits! Just have to make sure Neil is happy then tack it in and do the other side . You can see where the old rail went from the stub of RHS bracing left over, a little bit of persuasion had it lining up with the rear rail.
The bead roller must almost be in the country by now, i cant wait to start working making the new floors!
#56 _mick74lh_
Posted 21 June 2011 - 08:49 PM
Good luck with the rest of this project.
#57 _jabba_
Posted 21 June 2011 - 09:20 PM
#58 _jabba_
Posted 22 June 2011 - 07:04 PM
I've tacked the rail in place, I also stuck in a bit of 50x50 RHS to join back up to the transmission tunnel. I sprayed some weld through primer inside the rails before tacking the RHS in so its not metal on metal.
#59 _jabba_
Posted 23 June 2011 - 05:43 PM
Heres the drivers side rail, its clamped in place atm. I just need to sandblast and prime inside the old rails before i can tack it in.
This is where a chassis brace used to live, it kinda just fell off when i cut it from the chassis :/
Heres another wonderful 'rust repair', a sheet of steel glued over rust. mmm nummy
another angle of the inner sill bit
Here i have removed the lower 1/4 of the front guard to get access to the rust.
A little patch, you've gotta start somewhere?
If i get bored ill remake this outter piece, it just doesnt look right, not that you'll ever see it.
Thats a nice lower guard repair, i hope i can replicate a fantastic repair like this!
Outer sill removed
Replacement sill, the person who cut this off didnt really cut out all the sill we needed so i have to remake the lower lip. Still, its easier than trying to recreate that shape i guess .
Heres the new metal folder on the stand i made yesterday.
dont buy bunnings G-clamps :@.
Lower lip folded up, just need to trim and tack it on.
#60
Posted 23 June 2011 - 05:50 PM
yeah those g clamps must come from the same sweat shop the supercheap ones come from, i broke one pushing the piston back in on my uc caliper, and it wasnt very tight
#61 _jabba_
Posted 24 July 2011 - 07:20 PM
We also welded up the rear 1/4 panel
and welded up some trim holes that we didn't want
#62 _77hatch_
Posted 24 July 2011 - 10:56 PM
one of the biggest things for people to understand is how BLOODY cold it is in the shed right now!!!!!! , well out west here it been freezing & achieving any sort of after hours work is a mission ! bring on daylight saving & warmer whether i say !
#63 _jabba_
Posted 24 July 2011 - 11:05 PM
Good too see your making some progress ! thats not just any kind of restoration you've got going on! the thing will take a big block with that chassis ;-)
I hear what your saying, a big block is really a nessesity with the full chassis .
Its ridiculously cold atm, i haven't felt like working on the car coz its just too cold in there. I feel bad making noise after the sun goes down. At least the sun has come out the last few days!
#64 _77hatch_
Posted 24 July 2011 - 11:24 PM
#65 _jabba_
Posted 24 July 2011 - 11:26 PM
#66
Posted 31 July 2011 - 11:17 AM
#67 _jabba_
Posted 31 July 2011 - 09:51 PM
The long awaited bead roller turned up fresh off the sea! I still can't use it tho because USPS seems to have lost my package with the die's in it . I ordered the die's by air separately thinking they would turn up well before the bead roller :(.
Detailed Results:
Processed Through Sort Facility, July 12, 2011, 6:18 pm, ISC CHICAGO IL (USPS)
Arrived at Sort Facility, July 12, 2011, 6:18 pm, ISC CHICAGO IL (USPS)
Shipment Accepted, July 12, 2011, 1:35 pm, CHICAGO, IL 60688
Electronic Shipping Info Received, July 11, 2011
Still, its a nice bit of gear.
Edited by jabba, 31 July 2011 - 09:51 PM.
#68 _Quagmire_
Posted 31 July 2011 - 10:17 PM
how did the supa crap sandblaster go?
considering one....for a once only project
or should i just save a few $$$ and use paint striper?
#69 _jabba_
Posted 31 July 2011 - 10:18 PM
#70 _Quagmire_
Posted 31 July 2011 - 10:51 PM
#71 _nicko61_
Posted 01 August 2011 - 07:35 AM
i am in awe of your talent and gameness to take it on
#72 _jabba_
Posted 12 August 2011 - 04:20 PM
#73
Posted 12 August 2011 - 04:23 PM
#74 _jabba_
Posted 12 August 2011 - 04:34 PM
Shouldnt you be out welding something .
#75 _jabba_
Posted 12 August 2011 - 07:43 PM
