Flywheel bolts
#51
_judgelj_
Posted 31 July 2012 - 10:26 PM
Now as to not turn this into a COW ill butt out, hopefully others do also.
#52
Posted 31 July 2012 - 10:29 PM
I dont care how fast his car is,its just wrong.
#53
_judgelj_
#54
Posted 31 July 2012 - 10:30 PM
#55
Posted 31 July 2012 - 10:31 PM
Using a rattlegun to install flywheel bolts is bodgy.
Correct
#56
_judgelj_
Posted 31 July 2012 - 10:32 PM
You know what is bodgy? Half the cars that come into the workshop with dangerous repairs from other mechanics that need to be rectified. Experience is experience, professionals are just that for a reason.
#57
Posted 31 July 2012 - 10:33 PM
You have very little, if any control over how tight they are.
You can easily leave them too loose,too.
#58
_judgelj_
Posted 31 July 2012 - 10:36 PM
Ill leave it at that, im not going to be part of a big whinge. All i was trying to say is that there are different requirements for different applications. That's all.
#59
Posted 31 July 2012 - 10:40 PM
There is more to it that just zapping them up.
Its the reason a torque wrench should be used.
Does he nail down cylinder heads with a rattlegun,too?
Edited by wot179, 31 July 2012 - 10:41 PM.
#60
_Inj gtr202_
Posted 01 August 2012 - 07:41 AM
my 2 cents
#61
Posted 01 August 2012 - 09:07 AM
TQ figures and procedures exist for a reason,
There is no way on gods green earth that a rattle gun will do the same bolt up to the same torque every time, there's too many variables.
Doesnt matter whether its a 200k 9 second drag car or a 2k 90 second Kombi, flywheels experience a shitload of different forces and vibrations and no one is perfect enough to do them with your average rattle gun...
Its an example of pure laziness and a shining example of why mechanics get a bad reputation. If he is getting paid to work on people's cars, it shouldnt matter if her thinks it will be ok, he should be doing it by the book and the proper way.
I dont think anyone is going to agree that its a good method of tightening the flywheel bolts man... because it really isnt.
#62
_My74LH_
Posted 01 August 2012 - 09:10 AM
#63
_judgelj_
Posted 01 August 2012 - 03:35 PM
#64
_threeblindmice_
Posted 01 August 2012 - 03:45 PM
#65
_My74LH_
Posted 01 August 2012 - 05:16 PM
I don't often hear a rattle gun on song in an engine builders shop, well at least the ones I visit. Though If I go down to Tempe Tires they have an orchestra of them going , do they build engines too?
Edited by My74LH, 01 August 2012 - 05:19 PM.
#66
Posted 01 August 2012 - 06:06 PM
Edited by slr_v8, 01 August 2012 - 06:07 PM.
#67
Posted 01 August 2012 - 06:19 PM
Well you know what, more than 25 years of not a single problem says something? And im sure there's more to it than zapping everything up.
You said it yourself when you mentioned other peoples cars coming in with bodgy work done by mechanics, If you have a really bad experience with a mechanic your unlikely to take it back to them, most mechanics have probably never seen a fault.....
_PeteXU1_
Posted 01 August 2012 - 10:14 PM
Even on a mild 202 now, I would use two dowels and the bigger bolts. Why spend big coin on an engine build only to skimp on what is already known to be a weak point on the 202.
Anyone tried doing up the bolts with a ring spanner and hitting the starter motor?
Edited by PeteXU1, 01 August 2012 - 10:20 PM.
#69
_ljxu1torana_
Posted 02 August 2012 - 01:37 AM
do you want to break your wrist.this one of the most stupidist idea that i have heard of.Lots of comments on here.... My engine let the little bmc arp flywheel bolts go after only 50km. It only took one big skid to really loosen them. Learnt an expensive lesson.
#70
_PeteXU1_
Posted 02 August 2012 - 10:26 PM
#71
Posted 03 August 2012 - 08:03 AM
#72
_PeteXU1_
Posted 04 August 2012 - 07:37 PM
#73
Posted 04 August 2012 - 09:32 PM
marks on the flex plate would indicate a rattle gun was used.
Posted 04 August 2012 - 10:37 PM
#75
Posted 04 August 2012 - 10:44 PM
never mind how your holding the ring spanner, how are you holding the starter?
