The Bedford Project
some thing different
90 replies to this topic
#1 limo
limo
  • 2,673 posts
Posted 19 November 2012 - 07:53 PM
after 4 Torans in 5 yrs thought I would do some thing else.
This old girl has been sitting in the paddock for over 10 yrs
Posted Image<a href="http://s79.beta.phot.../Bedford truck" target="_blank"><img src="http://i79.photobuck...ck/bedfrd2.jpg" border="0" alt="BD2"/></a>
Posted ImagePosted ImagePosted ImagePosted Image
it appears there was a hawk living in the cab for a while,
lots of feathers / crap and a dead hawk
off to the workshop to strip, had to get a tow truck as the brakes didn't work. Master seized
started and drove it out of paddock and I can still reg it.
#2 Potta
Posted 19 November 2012 - 08:09 PM
Cool.
Is that motor in the standard location?
I don't think I've seen one of these before and it looks a bit weird with a donk in the cab :o
I guess there is supposed to be a console over it or something?
#3 _Bomber Watson_
Posted 19 November 2012 - 08:28 PM
Got offered one of these exactly like that the other day for the princely sum of $50.
So lucky i've cut myself off from buying more cars.....
#4 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 19 November 2012 - 08:34 PM
i want one :) look forward to updates
#5 _Quagmire_
_Quagmire_
Posted 19 November 2012 - 09:28 PM
your going on a road trip....you should do a detour :)
if you where closer i'd be interested....
#6 _niterida_
_niterida_
Posted 19 November 2012 - 10:18 PM
Mate used to have one of these - he extended the cab backwards about 400mm just to give him a bit more room and moved the engine (308 from memory) back between the seats.
Some of the Perth guys might have seen it around - was the work vehicle for Maddington Motorcycle Wreckers.
I used to have a Bedford van years ago - factory black and windowless - looked mean - would love to have another one.
Good score.
Whats the plans for it ? V8 and extended tray for a car transport ?
#7 yel327
  • 13,698 posts
Posted 20 November 2012 - 07:23 AM
Can I get the engine number and the ID plate details off it? I've been trying to place where the CF Bedford engine numbers fit, I think they are in the HQ number series but once I have a PSN and an engine number i'll know. This one is either an aussie 3 or 4spd (I think the LWB were trimatic or M22 4spd). The 3 and 4spd both used the same shifter (4spd off other Holdens and Toranas), and it was remote mounted from the gearbox.
Tony Windsor in Newcastle had one of those, he put an EFI 304 and auto behind the cab, under the tilt tray.
I've got all the parts catalogues off these things if you need to know anything.
Edited by yel327, 20 November 2012 - 07:24 AM.
#8 limo
limo
  • 2,673 posts
Posted 20 November 2012 - 07:58 PM
the engine number prefix starts FE, I had a look at the motor tonight but too grotty to read the reast, can clean it up later. as for the ID tags will check tomorrow at depot
#9 limo
limo
  • 2,673 posts
Posted 20 November 2012 - 08:13 PM
yeah the motor belongs there, these Bedfords were originally fitted with Vauxhall slant 4 cyl same as used in the LC/LJ/TA Toranas
Holdens just chucked in a 173 or 202 with 3 speed syncro but didn't change the diff so motor over revs
mine has a 173 and a tonner 4 spd(changed by previous owner)
also there is a cowling that covers the engine in cab
my plan
lengthen chassis and add lazy axle with rocker setup
I have a black injected 202
injected gas unit for dual fuel
Tarago 5 spd
HQ salisbury LSD
HQ disk conversion kit for the front
the idea is to end up with a tilt tray car transporter plus a removable stock crate so I can shift cattle and sheep
first I have to renovate the cab
#10 limo
limo
  • 2,673 posts
Posted 20 November 2012 - 08:17 PM
bit of work done
I was amazed how easily bolts and screws came out, all the bolts are fine thread as well
#11 Potta
Posted 20 November 2012 - 11:34 PM
Doesn't look too bad rust wise.
This is gonna be cool!!!!
#12 yel327
  • 13,698 posts
Posted 21 November 2012 - 06:26 AM
my plan
Tarago 5 spd
HQ salisbury LSD
They actually had either low comp 173 (FE prefix) or hign compression 202 (FL prefix) with aussie 3spd M15, 4spd M22 or trimatc. If you are going to build one for a tilt tray/transporter you'd be better off with the original trimatic off the VK EFI engine than a manual Tarago box! And the HQ Salisbury and available wheels may not really be strong enough for the GCM of the truck and the load! You might be better off with a diff like one out of a F250, or C20 or J20 or something like that. Some of the Dana60 diffs came in 3.54:1 ratio, you can find these in many of these trucks like the Jeep J20.
Greg at Classicoz has a LWB van (camper) there at the moment he is wrecking if you need parts. It had a 307 Chev and TH350 in it when he bought it.
Edited by yel327, 21 November 2012 - 06:31 AM.
#13 warrenm
warrenm
  • 2,119 posts
  • Car:1972 LJ Torana
Posted 21 November 2012 - 07:19 AM
Plenty of info here. http://www.buga.com.au
#14 _BARRY JACKPOT_
_BARRY JACKPOT_
Posted 21 November 2012 - 06:46 PM
You're gunna have to start wearing a bunch of gold chains and start saying "I pity the fool" a lot. Lol.
#15 _Quagmire_
_Quagmire_
Posted 21 November 2012 - 11:57 PM
different van barry
that was a gmc they drove not a bedford
Edited by Quagmire, 21 November 2012 - 11:57 PM.
#16 yel327
  • 13,698 posts
Posted 22 November 2012 - 07:12 AM
CF Bedford was used in Scooby Doo movie.
#17 _Quagmire_
_Quagmire_
Posted 22 November 2012 - 02:31 PM
http://khongthe.com/...h-res-69231.jpg
http://www.flickr.co...ean/3653136007/
similar but no cigar...
#18 yel327
  • 13,698 posts
Posted 22 November 2012 - 03:13 PM
Yep, that is an Aussie CF Bedford as the mystery machine! Scooby Doo was made in Australia, had one of my favourites in it: Isla Fischer.
#19 limo
limo
  • 2,673 posts
Posted 22 November 2012 - 07:43 PM
different van barry
now I know what that's about.
yel327 your numbers
engine FE750778
PSN 97760F J525457
ADR FJ525457
BODY 525457M
CAB 77000M
CHASSIS 97760 854174
DIDN'T WORRY ABOUT TRIM AND COLOUR
#20 limo
limo
  • 2,673 posts
Posted 22 November 2012 - 07:46 PM
been there many times but haven't contributed much just read and searched
member for few yrs
#21 limo
limo
  • 2,673 posts
Posted 22 November 2012 - 07:51 PM
read up on the BUGA forum last night and the HQ diff is too short so looking at F100 now but still with lazy axle and HQ stud pattern but Jag wheels (got a heap of them at farm) so 15"
#22 yel327
  • 13,698 posts
Posted 23 November 2012 - 07:32 AM
I think you'll find HQ wheel studs and Jag wheels won't be up to the task! Or F100 either. You'll need probably 1000kg minimum rims, possibly double rims like an F350 has. I'm assuming you want a car carrier, so you have to add the weight o fhe car you are carrying, plus the tray plus the vehicle itself. So you are looking at least 2 tonne load on the rear axle as a guess.
#23 yel327
  • 13,698 posts
Posted 23 November 2012 - 07:38 AM
yel327 your numbers
engine FE750778
PSN 97760F J525457
ADR FJ525457
BODY 525457M
CAB 77000M
Thanks mate. That PSN (J525457) puts it as May 1976, and all the Holdens I have recorded from Dandenong at the same time had engine numbers around 745-750000 so I think this one answers the question, looks like CF Bedfords used HQ series engine numbers! Note that if you want to re-use that engine, just put a 173HC head onto it and she'll be a high comp engine, 173's just used a 202 head to make a low comp engine unlike the bigger engines which had different pistons.
#24 limo
limo
  • 2,673 posts
Posted 23 November 2012 - 09:10 AM
but I will have 2 rear axles with a tandem rocker setup and I could use jag studs which are 1/2 "
#25 yel327
  • 13,698 posts
Posted 23 November 2012 - 09:17 AM
Ok, I get what you are doing, that will probably be OK.
