The Bedford Project
some thing different
90 replies to this topic
#26 limo
limo
  • 2,673 posts
Posted 23 November 2012 - 06:33 PM
the only bit still bothering me is the brakes, I would put brakes on the second rear axle but,
how do I connect them in? been told I have to use electric on second axle but when I asked RTA guy he couldn't say
can I use disk on 1 and drum on the other or both disk/drum
might have to talk to local engineer
I am going to use Torana master cyl and booster, the Bedford master is only 3/4"
#27 limo
limo
  • 2,673 posts
Posted 23 November 2012 - 06:40 PM
the rust is mainly in the roof
the front
the back
so turned it into a soft top
no going to repair the sections under the roof and the roof then put it back on,
#28 limo
limo
  • 2,673 posts
Posted 29 November 2012 - 07:44 PM
roof looked like quite a bit of work so thought I would start here,
but not that easy as you would expect
once I had cut the rust out, 3 pieces over welded
so 1
then treat with metal conditioner and etch primer
will think about the roof for a while
#29 limo
limo
  • 2,673 posts
Posted 04 December 2012 - 08:55 PM
the roof, still thinking
viewed from inside and out
found a bit more to fix, easier
cut bit off the chassis ready for extension
about a 100 kgms and tow hitch hanging off bit of 2 mm plate with 8 tack welds holding it to chassis
it's wonder it held with the stuff I used to tow
#30 limo
limo
  • 2,673 posts
Posted 13 December 2012 - 08:23 PM
repaired the floor section, twice as much as usual
has been ground back and coated with metal conditioner ready to etch prime
repaired the roof frame by plating over the original after cleaning back to metal, plus few holes when rust removed
full chassis vehicle so roof strength not critical
front right
front left
back right
back left
back top left, cut out and replaced
#31 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 13 December 2012 - 08:30 PM
Just a thought about the roof, surely you could make a Torana roof skin fit? Might be a bit of cutting and welding, but you're going to have to do that anyway.
#32 yel327
  • 13,698 posts
Posted 14 December 2012 - 08:35 AM
Make it a rag top! With one of those clip on vinyl roof tonneau looking tops like VW's used to have. Or just put a perimeter of steel and get a really big sunroof!
Edited by yel327, 14 December 2012 - 08:35 AM.
#33 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 14 December 2012 - 10:55 AM
You've made a difficult job harder by cutting the roof off with a grinder instead of drilling out the spotwelds.
I think I would be sourcing another turret and either unpick the skin and plugweld it back on or cut and join it through the pillars.
#34 limo
limo
  • 2,673 posts
Posted 14 December 2012 - 07:56 PM
have look at the pics of the roof, there was a ring of rusted metal with holes for about 70% of the perimeter, I cut through this to remove it. (it was about to come off by itself
also the spot welds holding in on are in the gutter, never find them
doubt it I would find another any better, very common fault
Edited by limo, 14 December 2012 - 07:58 PM.
#35 limo
limo
  • 2,673 posts
Posted 14 December 2012 - 08:00 PM
thought about a rag top or buy a fibre glass one but didn't know how they fitted and it was a challenge to fix it
#36 rodomo
  • 18,046 posts
Posted 14 December 2012 - 08:06 PM
Fibre glass if available would be my pick? Like early Landcruiser. Rivet on. Or, make a mold/mould using your old skin?
#37 limo
limo
  • 2,673 posts
Posted 14 December 2012 - 08:07 PM
hers the roof repaired ready to weld back
I used a LC roof to cut strips for backing and fill, same vintage metal, additive content and thickness
#38 limo
limo
  • 2,673 posts
Posted 14 December 2012 - 08:11 PM
to buy $500
to make would need to repair mine enough to get full shape and then work out mounting flanges/tabs
I am practicing my welding and metal work, starting on my XU1 next
#39 rodomo
  • 18,046 posts
Posted 14 December 2012 - 08:15 PM
Nup....................sorry..................you've won me with the repairs...............speshly cos your usin HOLDEN panel to fix it! :spoton:
#40 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 14 December 2012 - 08:19 PM
Maybe I'm not so silly after all?
#41 limo
limo
  • 2,673 posts
Posted 14 December 2012 - 09:06 PM
spose I should say it's from the same wreck I have been cutting up for about 4yrs before you pick on me again for cutting up Torans
#42 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 15 December 2012 - 08:36 PM
It was only a toy Torana anyway.
#43 limo
limo
  • 2,673 posts
Posted 17 December 2012 - 07:20 PM
the roof is on and real happy, no buckle, warping or twisting
it's tight and rigid
I have dressed the weld back and cleaned up, hardest part was the ridge that runs around the base
when I cut roof off I cut along this edge leaving a raised section so when the roof went back it rested inside, less couple of mm to weld
also this rim was missing in few places due to rust
could have ground it all off and welded to flat base but why do it wrong just be easy
bare metal
#44 limo
limo
  • 2,673 posts
Posted 17 December 2012 - 07:26 PM
actually it was an excellent car until a drag racer got it, (grandpa LC 4dr SL passed on to young lad, he tricked it up then moved on so drag guy got it)
only bit of rust was 50 cent piece size LH lower back quarter
gutted it, cut out dash, rear parcel shelf, section in front of windscreen
then welded up every hole in the shell
changed his mind and did same to a 2 dr and offered me the 4 dr $300
best bit I later found it had LSD and HQ front discs
Edited by limo, 17 December 2012 - 07:31 PM.
#45 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 17 December 2012 - 08:28 PM
That's all history now limo, now its a rust repair supply.
#46 limo
limo
  • 2,673 posts
Posted 18 December 2012 - 08:37 PM
yeah but useful, parts to Sydney, Perth, ACT, Adel for other forum members and what I have used
about 12 cars and counting so far
#47 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 19 December 2012 - 08:03 PM
The perfect form of recycling!
#48 limo
limo
  • 2,673 posts
Posted 24 December 2012 - 08:06 PM
not much time this week but had 4 litres red oxide under coat that has been sitting in shed for 20 yrs or so,
still good, 1/2 hr of stirring and sprays OK
also worked out front hub and disc rotor, fitted Ford Econovan Maxi 6 stud hub and with bit of machining should be able to use Pajero rotor and caliper
pics to follow
couple of dents to get to
had a win with the diff
bought a F100 8.8 diff couple of weeks back ($250 from wrecker) and have been looking for a LSD centre at the right price, best from USA
but needed to know spline size, 28 or 31 and I was checking today and it's a LSD
BARGAIN
Still have to take axles out to change stud pattern to 4WD 6 stud
#49 _stretchlc_
_stretchlc_
Posted 26 December 2012 - 07:18 PM
The great thing with using 6 stud rims (4wd ones anyway) is that the stud pattern is universal......WIN!
#50 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 26 December 2012 - 08:38 PM
Mostly. Try fiting patrol rims on a land cruiser, the rims hit the brakes. Or the other way around, I'm going from what I was told 20 years ago.
