Another happy MCP customer then :-)
UFO304 Tidy up
#226
Posted 24 February 2015 - 11:22 AM
#227
_UFO304_
Posted 25 February 2015 - 07:39 AM
Did you get yours from Him aswell?
#228
Posted 25 February 2015 - 11:11 AM
Sure did. But only the rear bar. But several members in our club have bought front and rear from them too and are very happy with the quality.
#229
_UFO304_
Posted 08 March 2015 - 07:50 AM
Finally got around to changing the diff centre.
Going From 3.5:1 with a mini spool,
To Richmond Excel 3.89:1 gears with a Powertrax GT109028 TRU trac.
I also found out that Richmond make (or own the company) that do the Powertrax GT109028.
I had the centre rebuild over at Craft Diffs in Sydney, and they gave me $100 for my old gears, the guys in there are good guys and happy to help and provide advice.
Posted 08 March 2015 - 07:39 PM
I have 3:89's in mine too. They are a bit on the noisy side (apparently common for 3.7 and 3.9's) but good for acceleration :-). And extremely good when you have an overdrive like i do.
#231
_UFO304_
Posted 09 March 2015 - 12:20 PM
I have a 5 Spd, so it should be ok, although I think I should have gone 4.11:1.
The gears didnt seem to be heard over the exhaust, although I was only putting around for its first half an hour run-in at maximum 60 km/h.
When I backed it out of the garage and turned it full lock, I was so happy . . . . . No Locked diff anymore . . . . . . . . . . .
#232
Posted 09 March 2015 - 04:22 PM
Depends on whether you intend to drag race it too..I have to shift mine into overdrive just before the finish line and that is revving it to 6200rpm..3:7's would have probably been better for me. 4:11's are too wild for a street car my liking.
Anyway, enjoy the change, you will have some fun for sure :-) Especially without the locker :-)
#233
_UFO304_
Posted 15 March 2015 - 10:16 AM
For my next Little Project, fit up some big brakes before the new K frame goes in . . . . .
_UFO304_
Posted 17 March 2015 - 07:03 AM
Fits the wheels Perfectly . . . . .
Posted 19 April 2015 - 07:43 AM
Those wheels look great!
Thanks foe doing such a nice job on your car, encourages me!
What brakes are you upgrading from?
Do you already have some sort of Commodore set up?
I am trying to work out how to put 16in Commodore wheels on mine
Cheers, Tom
#236
Posted 20 April 2015 - 08:09 PM
Nice project man. Looks great. What stub axles are you running?
#237
_UFO304_
Posted 23 April 2015 - 06:34 AM
Hi Ken,
Cheers, Tom
Hey guys thanks for the positive comments.
I'm setting it up to run HQ Stub axles, UPC Hubs, Rear VE 350mm Rotors and the AP Calipers.
I am upgrading from the HQ setup with Girlock calipers.
Unfortunately the set-up im making is abit of a one off, as I got the front wheels made with a custom offset to clear my brakes. The wheels are to suit HQ setup, but u wouldnt be able to run this brake set-up with standard offset front wheels.
#238
_UFO304_
Posted 23 April 2015 - 06:38 AM
Got some brackets made up for this, I just need to make some spacers to weld to the brackets, and then All I need is brake lines.
_UFO304_
Posted 23 April 2015 - 06:43 AM
Ive also got a drawing of the brackets.
_LS1 Taxi_
Posted 23 April 2015 - 08:11 AM
#241
Posted 23 April 2015 - 10:29 PM
#242
_UFO304_
Posted 27 April 2015 - 08:38 AM
I had abit of a muck around with this on the weekend,
She all works, and clears everything with heaps of room.
I just need a spacer and brake hoses and im set.......
Posted 27 April 2015 - 10:19 PM
Well done
#244
_UFO304_
Posted 28 April 2015 - 07:36 AM
Cheers Tom,
Ive convinced myself to finish this car, I'm going to pull off the nose cone, Paint the Engine Bay, relocate the wiper motor, do the K-frame swap, and then put it all back together.
then I might be "finished"
#245
_LS1 Hatch_
Posted 28 April 2015 - 08:27 AM
Nice brake setup!
I got my wheels and built my brakes to suit, not sure if that way or brakes first is an easier way to go, lol..
#246
_UFO304_
Posted 29 April 2015 - 12:03 PM
Yeah, I got my wheels and then worked out spacing, rotor offset etc from there.
#247
Posted 29 April 2015 - 12:20 PM
UFO, are you getting your car engineered? I was led to believe that caliper bracketss (dogbones) are not to be welded in any shape of form. Victoria anyway. Others can help clarify.
#248
Posted 29 April 2015 - 03:59 PM
it's not welded is it? looks like it's bolted on in the pics?
#249
_UFO304_
Posted 30 April 2015 - 06:07 AM
I am just running spacers, I dont really need to weld them so I think i'll just bolt them in like that.
_LS1 Hatch_
Posted 30 April 2015 - 08:07 AM
The brackets I made up are similar and I welded the spacers, not sure if it was needed, but was just a bit of piece of mind to me to try and help stiffen things up I thought.. (If I had the means, would have made the brackets one piece carved out of one block, but don't have a CNC, sooooo...)
