these are the numbers, first set A291, then 2815843, h5
ljzedded 036.jpg 561.62K
6 downloads
yellaterra or not
Posted 31 October 2013 - 08:58 PM
_Skapinad_
Posted 31 October 2013 - 09:03 PM
There the factory castings, its a high comp...
Shot of the ports, valves, and the back of the cylinder head will help....
Posted 31 October 2013 - 09:13 PM
hi bomber,gonad gobbler,ports are std,and valves no markings,me mate reckon its yellaterra, my old one had a pipe through the gut of the inlet,i will put another pic up
Posted 31 October 2013 - 09:19 PM
Just because its Yellow doesnt make it Yellaterra, smack your mate upside the head.
Adam appears to be right, pretty sure thats the xu-1 number.
Posted 31 October 2013 - 09:21 PM
Posted 31 October 2013 - 09:24 PM
yep done it didnt like it,hes sayin whats the xu-1 number,will i smack him again,he just went out the door
Posted 31 October 2013 - 09:28 PM
LOL.
Posted 31 October 2013 - 09:31 PM
Posted 31 October 2013 - 09:38 PM
Mostly holden heads modified, but they did cast some.
Posted 31 October 2013 - 09:41 PM
they cast tere own didnt they
wernt the first ones with nothin on the valves and the guts missin out of the inlet with the head bolt in there
Posted 31 October 2013 - 09:44 PM
Didnt the XU1's come out with 12 port heads?
Posted 31 October 2013 - 09:45 PM
what will i do with it toss it
12 ports are 80s arnt they
Posted 31 October 2013 - 09:49 PM
far as i know xu1 would of been 9 port?
Posted 31 October 2013 - 09:51 PM
12 port came out for Commodores
All reds are 9 I think
Most YT heads are just old castings... not new fresh stuff
Posted 31 October 2013 - 09:53 PM
Datto is correct.
THere was never a red motor with a 12 port.
There are a few butchered bastardized 9 ports with port dividers, but was never factory.
YT had various stages, Stage 2 which looks similar to what you have there, Stage 3 which was the inlet divider removed and a steel pipe pressed in instead, these were both factory GMH castings.
Afaik YT never supplied heads with the inlet divider totally removed and the bolt in the bottom of the port. Keep in mind YT isnt the only company to ever have a play with these.
YT did cast several heads, in both cast iron and aluminium, but these are easy to pick from an origional one, what you have there sir is not one.
If your going to toss it, i will pay freight and chip in $100 for packaging and your time if you feel like sending it to me.
Personally if i was you i would sell it....
Edited by Bomber Watson, 31 October 2013 - 09:56 PM.
Posted 31 October 2013 - 09:54 PM
how did gonad come up with xu1 head,is it the first no i said or the second set
Posted 31 October 2013 - 09:57 PM
tell me what it is first,and dont make it up lol
Posted 31 October 2013 - 10:01 PM
TMK A291 is the date code and 2815843 is the product code for a XU-1 head. Which year im not sure, not that into them.
THe fact that the valves are obviously oversized but the ports look relatively untouched somewhat confirms this.
I would be removing the rocker cover and having a good look if i were you, then cleaning it up and putting it on ebay/gumtree/whatever.
Or post it to me and i will do it
its not a willow head is it,fake
#22
Some discussion here, same topic. http://www.gmh-toran...lla-terra-head/
#23
Posted 31 October 2013 - 10:03 PM
lol ,me mate is jumping up and down again should i smack him harder
#24
Posted 31 October 2013 - 10:05 PM
So long as he doesnt take the head off you then yeah, sure.
And start prepping your ebay add .
And check the engine number of the block while your going....
#25
