Shame the build is just so dam good
Edited by Muzzy, 11 April 2015 - 09:31 PM.
Posted 11 April 2015 - 09:30 PM
Posted 04 May 2015 - 01:25 AM
Posted 04 May 2015 - 01:30 AM
Posted 05 July 2015 - 06:18 PM
Posted 06 July 2015 - 04:59 PM
thanks rexy , really appreciate the help updated bay photo
Posted 06 July 2015 - 08:13 PM
Posted 06 July 2015 - 08:16 PM
Posted 06 July 2015 - 10:33 PM
Fantastic looking car Ryan - inside and outside. I really like the colours you've used for the engine, it's nice and different. The Convo's rock too.
Can I ask what sort of collector joiner that is in your exhaust system? Is it just a slip join or is that some kind of clamp arrangement? Either way it looks awesome.
Keep the photos coming.
Posted 07 July 2015 - 08:14 AM
thanks lxchev, cars is coming along nicely now , just ironing out all the little things now , the exhaust are a slip on clamp setup , i can take more photos later so u can see , the guy at extracted did a wicked job on the exhaust ,
Posted 07 July 2015 - 07:09 PM
Ryan awsome build, the torana looks amazing, thanks for sharing, the hpc pipes look to good.
Posted 07 July 2015 - 07:41 PM
thanks guys , few more pics to come shortly , just getting cluster rebuilt atm , speedo stopped working so did tacho :(
Posted 08 July 2015 - 02:01 PM
hi mate....did you get to the bottom of the crank float issue?
Was talking to a guy today who knows about such things and he commented that he has seen this previously where the flex plate / torque converter isnt fully ""ÏN"" at the back of the motor ( I dont recall his exact words) but it related to there being no movement being possible where the engine joins the trans. i.e. instead of a coulpe of mill forward/aft moovement being possible, there would be none, which means any mechanical force on the whole drivetrain can be transfered directly to the end on the crank. Whereas it should be just taken up in the 2-3 mm gap thats supposedto be there?
I dont understand the specifics of it, but he gave me the impression it happens from time to time when the motor - trans is joined together, if not just right?
Like I said, I dont fully understand it , never done it...just offering info in case it assists.
Posted 08 July 2015 - 04:28 PM
hey rally red , crank was being forced forwards but never really found the problem, now everything is up and running with new flex plate new crank machined , so hopefully ill go get everything checked over in a couple more drives , so far so good atm ,
Posted 08 July 2015 - 07:05 PM
ok , all good.
Hope it works out.
Posted 31 July 2015 - 07:38 AM
got some custom rear springs done at brown springs, came up well , sitting nicely and nice and firm in the rear
Posted 31 July 2015 - 07:42 AM
side pic atm moment
Posted 31 July 2015 - 07:54 AM
Good one. Just need to give that bonnet a tweak now.
Posted 31 July 2015 - 10:57 AM
Posted 31 July 2015 - 11:29 AM
Easy fix.
If you can't get sufficient adjustment out of the hinges, you need to remove the rear bolts and grind a flat onto the washers to allow more adjustment.
Posted 31 July 2015 - 07:23 PM
Posted 31 July 2015 - 07:22 PM
Posted 31 July 2015 - 07:32 PM
Posted 31 July 2015 - 08:19 PM
