High hp/rpm n/a efi plenum
134 replies to this topic
#126 _oldjohnno_
_oldjohnno_
Posted 14 September 2014 - 07:49 AM
I already added dividers in each runner which actually to my surprise made it react worse....
"Tuned length" runners can add torque if their length is matched to the valve timing and rpm range of the engine, but their rpm range is limited and when they're out of this range they'll actively reduce torque. So what I'm saying is it isn't enough to have equal length runners, they have to be the right length. The fact that the runner configuration is less than ideal (no taper, no entry bell, no corner fillets, sharp change of direction) may mean that the flow loss with the dividers may eat up much of the gain from a tuned length anyway.
#127 _rb3torana_
_rb3torana_
Posted 14 September 2014 - 09:34 AM
Yeah Im hearing what your saying, to be honest I was just trying to get some air speed happening. The new mod "should" help with that lol. Cheers
#128 _rb3torana_
_rb3torana_
Posted 17 September 2014 - 08:43 PM
Well I think its close enough lol. Its been hacked up, slightly smaller plenum volume and removed the runner dividers and carb divider although I did add a piece of angle welded to the floor as a difuser. Feels pretty good now. Surge and rich spot is all but gone, with fairly good distribution ( for a 4bbl anyway ). The plugs are a little dark because of the secondary float floods so I'll have to stiffin the float spring a little more.  Cheers
Edited by rb3torana, 17 September 2014 - 08:46 PM.
#129 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Location:Adelaide... city of... anyone know something good about it?
  • Car:UC hatch
Posted 18 September 2014 - 06:30 AM
You don't muck around do you?
Any plans to compare it to another manifold - see if you're getting a power increase over the aftermarket options? Would be interesting to see.
#130 _rb3torana_
_rb3torana_
Posted 18 September 2014 - 07:36 AM
Yeah Im kinda kicking myself I didnt keep my old aussiespeed intake to compare. But I guess all I can do is see how well it goes at the track. Cheers
#131 _duggan208_
_duggan208_
Posted 03 December 2014 - 12:20 AM
Have a look at Clifford 6 cylinders in the US. They have some radical manifolds for the chevy 6's. I think i can remember one with 2 2 bbl holleys. I don't know how to put those bloody web sights up.
Regards
#132 warrenm
warrenm
  • 2,124 posts
  • Car:1972 LJ Torana
Posted 03 December 2014 - 05:39 AM
http://www.cliffordperformance.net/
Copy & paste.
#133 _duggan208_
_duggan208_
Posted 04 December 2014 - 12:06 AM
Thanks, I'll try that out next time. Just in case, option 2 EFI mainfold is for sale on Ebay, $500.
Regards
#134 _Baronvonrort_
_Baronvonrort_
Posted 04 December 2014 - 08:52 AM
Just wondering some thoughts on an efi manifold setup. Looking at running a 12 anything in a full weight street UC torana, trimatic and 9 inch. Engine will be a 9 port head ported, 12:1 compression, 260-270@50 solid etc using an lt8 microtech to run it.
Similar to Option 2
This setup looks like it has potential, put an airbox over all 3 TB all and ram cold air in from beside headlight- radiator.
#135 _duggan208_
_duggan208_
Posted 07 December 2014 - 12:19 AM
Keep some one busy for a while building an air box for them. the air box is very important for an EFI system.
regards.
