I think the problem is not everyone would use the info in the same way.
I don't know what info is on the disk, but one would imagine it is in order of vin number, but that doesn't mean you cant search body numbers etc now it is on disc.
with the right info you can make a good mockup as good as the real thing, especially the real ones missing their plates
as for less work, it will increase it to provide greater info to prove it is not a number mock up as well.
maybe xray the engine numbers etc.
be spending time checking tags themselves, not the numbers on them.
it will be harder to check than a a9x, at least they had a modified body.
the people that should be worried are the ones that have payed good money for a matching numbers car.
with this info you can even provide service books!
how far will someone go to increase the value of a none gen car?
all you need is one of these discs to be copied, and soon we will all have one.
xu1 that is
you often see vin,body id plates not attached to a body, now they can be, and with the right numbers.
or miss matched plates
adds looking for this number body id etc, may have the correct one for your car!
the problems are endless. thats why only holden should have the numbers!
how would you go when you finally finished that 10yr resto, rock up to the rta to find you car already registered. that is someone checked reg info, reproduced these numbers as the car didn't exist. they would be long gone by the time it was found out. which one is the real one?
if people are copying new vehicle id's and sticking them to stolen cars, then reselling them interstate, and it takes ages for the cops to figure it out, what hope would they have with a 1970 car!
lots of early cars (pre 1985) don't even have the vin on the rta records, so they may never know there is a duplicate out there!
$250 a disk! would of probably reached more than an xu1 if let run on a bidding war. they are a licence to print money.
this info being shared is a sad day for all.
Edited by bryanw, 21 July 2006 - 11:34 AM.
