In need of Speedometer solution
33 replies to this topic
#26 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 August 2015 - 06:12 PM
VSS plugged in? I think so. ran out of time to check but I will later.
I watched him do the VATS didn't look to complex, he is a tuner himself.
Ill have a look at VSS and a general look around.
#27 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 August 2015 - 06:16 PM
Elec diagram shows pin 20 VSS Low signal and Pin 21 VSS High signal. Red large connector on PCM
#28 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 August 2015 - 07:24 PM
VSS is plugged into the gearbox. I thought it would be but couldn't quite picture it from memory. But yeah plugged into gearbox.
#29 Bigfella237
  • 4,377 posts
Posted 02 August 2015 - 07:55 PM
Do you have an OBDII adapter?
If so, does any of the software show a virtual dashboard to confirm the ECU is seeing a VSS signal?
#30 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 August 2015 - 08:08 PM
No I don't have any adapter. Is that a comms cable that splices into the loom?
Edited by Bart, 02 August 2015 - 08:10 PM.
#31 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 August 2015 - 08:19 PM
I should mention I removed the transmission switch and put back on close as possible to where it was.
Could this screw the gear change or is this mainly for P R N D selection?
#32 Bigfella237
  • 4,377 posts
Posted 02 August 2015 - 08:56 PM
No, you should have transplanted the OBDII connector with the LS wiring loom, it's a system diagnostic point that's supposed to be located within reach from the driver's seat and looks something like this...
Attached File  4360443_orig.jpg   21.94K   0 downloads
Then you can buy adapters to plug into that port and a laptop/touchscreen/smartphone/etc., there are literally thousands of them on eBay, this is just the first one I found (I'm not making any recommendations as most of these are cheap Chinese knock-offs)...
... but you can buy them for like twenty bucks and some of the software is free, including some that displays a virtual dashboard with all kinds of nifty stuff...
#33 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 August 2015 - 09:32 PM
Holy crap. Long gone are the carby days for sure lol
Ok so far I have found out that I need 12v on one of the wires in my loom for gearbox, Pink with Blue trace. Now I found this wire and it is not connected to 12v. Ill confirm soon and get back to you.
Edited by Bart, 02 August 2015 - 09:32 PM.
#34 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 03 August 2015 - 09:03 PM
Ok, this is good for the guys trying this conversion, so yes the Pink wire with Blue trace needed 12v connected to it to turn on the gearbox. Confirmed to a point as I didn't drive it but its definitely in first gear as it nearly did a burn out in the garage where before it would barely take off.
All good :)
Thanks guys I will confirm 100% this weekend when I drive it up the street again
