Blue 3.3 build
#26 _Muzzy_
Posted 12 February 2016 - 08:48 PM
#27 _Muzzy_
Posted 13 March 2016 - 03:29 PM
#28 _Muzzy_
Posted 13 March 2016 - 03:31 PM
#29 _Muzzy_
Posted 02 April 2016 - 03:24 PM
#30 _Muzzy_
Posted 02 April 2016 - 03:29 PM
#31 _Muzzy_
Posted 14 April 2016 - 04:29 PM
And have fitted a [email protected]" camtech cam with 442" lift, now sure about the roller rockers as yet if I do I will go 1.6:1
#32 _Muzzy_
Posted 14 April 2016 - 04:56 PM
SV = 560 ( 202 + .40" )
Cv = bowl 7cc, deck 5.77cc, head gasket 7cc, chamber vol 45cc
Therefore 560 + 64.7 = 624.7 /64.7. = 9.65:1 as is with stock small chamber head, loads like I will need to knock some off the head
I'm after 10:1
#33
Posted 14 April 2016 - 05:49 PM
#34 _Muzzy_
Posted 14 April 2016 - 06:07 PM
Looking good, I have been following your thread with interest. What was the deciding factor with that choice of piston?
I was advised they were the best for engine running sub 5500 along with a small chamber head, I had brought a VK open chamber head which I started on and may finish and sell off , ACL off set bowl offer an improvement in combustion from normal bowl style
#35 _Agent 34_
Posted 14 April 2016 - 07:35 PM
Brian - just check thoes cals again before you shave off the head
for instance i had a 3.3 @ 60 with flat tops and the block decked - had to dish the pistons + head gasket + spacer & 63 cc chamber and the piston were poking above the block without the spacer to get back to 10.5:1
the last motor i had flat tops @60 - 43 CC chambers and Zero deck and this was 12:1
just want to make sure that you dont shave the head if needed and once it's gone it's gone.
G - pretty sure you know what ur doing but it seems a bit out, i could be wrong and excuse me if i am.
#36 _Agent 34_
Posted 14 April 2016 - 08:21 PM
just looked again at the picks is the deck at zero - i presumed it was.
is decking the block another option to raise the piston eg to reduce the volume and keep valve lift @ max out of the head clearance this also plays into the shrouding of the valve when open.
put the head gasket on it and do the champers on the block for the valves as well. - not to clear but to allow better flow.around the valves but this will drop your comp a bit as well.
looking good - nice to see an engine build on here.
g
#37 _Muzzy_
Posted 14 April 2016 - 08:42 PM
#38 _Muzzy_
Posted 14 April 2016 - 08:47 PM
g
The dial gauge show the drop .86mm, it was 1mm so it was decked .14mm normal sort of decking job,
#39 _ljxu1torana_
Posted 14 April 2016 - 08:56 PM
brian,your pistons are the same as mine ,what thickness is your head gasket,did you do this with your calculations.
#40 _Muzzy_
Posted 14 April 2016 - 09:00 PM
As mentioned ACL quote 7cc for the bowl, the head gasket is 7cc which is 95mm and 1 mm thickness, and the deck .85mm and 93 diameter
When these are all added together with the head 64.7cc and a cylinder volume of 560cc,
#41 _Muzzy_
Posted 14 April 2016 - 09:03 PM
#42 _ljxu1torana_
Posted 14 April 2016 - 09:33 PM
ok
#43 _Muzzy_
Posted 15 April 2016 - 08:55 AM
I havent CC the actual Pistons I'm taking ACL word for it, but I can't see 7cc in the bowl, so tomorrow I will CC the actual piston bowl and see if that is different, maybe it's a typo on the ACL website
I have cc the actual pistons and they are exactly 7cc, the only difference I came up with is the stroke is 83mm not 82.55 mm as qutoted , the difference here once all put together is a shift from 9.65:1 to 9.7:1, so bugger all, needs to come off, 3 cc from the head would make it 10.1:1
#44
Posted 15 April 2016 - 05:08 PM
#45 _Muzzy_
Posted 15 April 2016 - 05:43 PM
Race series head gasket? I have not been able to find any others that compress past the 1.05mm that ACL state.
I rounded it down to 1mm
#46
Posted 15 April 2016 - 06:36 PM
#47 _Muzzy_
Posted 15 April 2016 - 07:20 PM
Yeah thats what I assumed. So it is a race series? I was only asking on the off chance you had found something else that thin rather than the soon to be impossible to find race series. Cheers...
Not sure if the head gasket is anything special, I used NOS ACL for the full rebuild, although I used a Felpro conversion set for the rear main seal as, I was very disappointed with the quality of the rope seals, even after soaking for days and making and making a jig up I couldn't get the drag low enough .
#48 _Muzzy_
Posted 05 June 2016 - 08:29 AM
#49 _rich243_
Posted 05 June 2016 - 04:14 PM
Looking good. How is your head coming along?
#50 _Muzzy_
Posted 06 June 2016 - 06:09 PM
