Blue 3.3 build
87 replies to this topic
#76 warrenm
warrenm
  • 2,107 posts
  • Car:1972 LJ Torana
Posted 05 October 2016 - 10:59 PM
Brickies? Mick.
#77 yel327
  • 13,120 posts
Posted 06 October 2016 - 06:13 AM
I had a metallic blue HK 307 auto 3.36 with 34000 miles when i was 21 yrs old ,it was rated at 210hp and it did 16.6 1/4 mile at Castlereagh which was a second faster than those dumb road testers,then i modified the engine and fitted a 4spd and did wheel spinning 14.7s .I remember calculating 220hp using the weight shifted hp formula which would be pretty close to rwhp.
Those were the days when a street meet was racing on a Sunday night not far from my place .
Remember though Mick the Press tests for a 307 GTS around October 1968 were for a fully loaded car (air and steer) and from memory a 2.78 rear axle (will check). And GMH purposely didn't have a 307 manual at the Surfers Paradise release, as that car would have showed what they were trying to hide a bit (the true potential of the GTS327). All Press 1/4 mile tests of the day were done with two people, and they throttle lifted at each gear change (on a manual). Your 14.7 from a modded 307 manual with 3.36 putting out approx. 220rwhp is a very good indication of the true 1/4 mile capability of a HT-HG GTS350 manual. The later HG version with the bigger port heads was good for about 207rwhp, had a 3.08 rear axle, weighs about the same and AMC Magazine pulled a 14.78 out of it with two people, 26 Gallons of fuel in the tank and throttle lifting at shifts. So pretty much shows a direct comparison between the cars.
#78 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 06 October 2016 - 06:29 AM
Brickies? Mick.
Yep Brickies , Shell refinery and Smithfield...I even remember someone unloading an XT Falcon pro stock car at Smithfield for a test run.
#79 _Muzzy_
_Muzzy_
Posted 06 January 2017 - 03:02 PM
And the final picture to this post, the finished engine in the vehicle, I know it's a 3.3 , however I have keep it looking like the red engine, as mentioned the dyno figures were done with the air cleaner on.
#80 _Agent 34_
_Agent 34_
Posted 06 January 2017 - 03:55 PM
nice - simple and clean.
good stuff.
the grin is always bigger when you do the work yourself, its the challenge of why we do stuff.
G.
#81 Ice
  • 15,127 posts
Posted 06 January 2017 - 06:05 PM
Wow very neat engine bay
#82 SA EH
SA EH
    Another Holden 6 tragic
  • 1,050 posts
  • Name:Jonesy
Posted 06 January 2017 - 10:20 PM
Hey nice radiator bud, pardon my ignorance but what's the story with that? Custom, off the shelf, ??
#83 _Muzzy_
_Muzzy_
Posted 07 January 2017 - 08:32 AM
Off the shelf GPI racing alloy, designed for Holden six, just have to cut the side flanges to mount, it has around double the number of tubes,
#84 gad05
gad05
  • 420 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 07 January 2017 - 10:22 PM
Hey Brian what's the trick with fiting the stock air cleaner on the webber?
Well done with your engine build,a great read.
Cheers Graham.
#85 _Muzzy_
_Muzzy_
Posted 08 January 2017 - 02:55 PM
Cheers Graham.
I used a varijet base, and cut it out and welded in a new base with a weber bolt pattern that I made from mild steel sheet
#86 RallyRed
  • 7,858 posts
Posted 08 January 2017 - 04:38 PM
nice and clean.....good job Brian
#87 gad05
gad05
  • 420 posts
  • Name:Graham
Posted 08 January 2017 - 05:54 PM
Cheers Brian, looks good.
#88 _2ELCS_
_2ELCS_
Posted 09 January 2017 - 09:59 PM
Your showing your age Mick  lol
