Jamaican an LX
#151 _LXT333_
Posted 21 January 2020 - 06:13 PM
https://www.whitelin...Z5383_Z5326.pdf
Should be mounted on the lower arms.
I got the brackets bolted to the top arms, not that the instructions state which arms to bolt the bracket to.
#152 _LXT333_
Posted 05 February 2020 - 08:58 PM
Dash is a Bit hacked up but I’m still excited.
Someone has mounted in some auto meter gauges in factory cluster housing, they aren’t even straight FFS.
Tossing up whether to source an original cluster or just use what I got.
Been clearancing HQ caliper slides for tiered ends. Ordered new tiered ends today so wanna fit them all up and check clearance before going any further.
So many almost finished jobs but waiting for parts, time, money, other people,
Missus is pulling me up on the spending as she is planning a big weekend holiday end of this year.
#153 _LXT333_
Posted 05 February 2020 - 09:13 PM
Another hack job.
It actually needs to be moved furthur back to give a bit better clearance for the air cleaner.
Couldn’t even close the bonnet prior to cutting.
Posted 05 February 2020 - 09:41 PM
Took me a while to get my head around the bonnet in pic post 152
#155
Posted 05 February 2020 - 09:54 PM
#156
Posted 05 February 2020 - 10:21 PM
inside out ffsTook me a while to get my head around the bonnet in pic post 152
#157
Posted 06 February 2020 - 10:38 AM
Have you seen what original clusters are going for these days? You won't get any change from a thousand bucks for a very second hand one.
#158
Posted 06 February 2020 - 11:11 AM
SL/R Cluster prices are criminal...
#159 _LXT333_
Posted 06 February 2020 - 12:16 PM
Was like WTF the first time.
Don’t talk too loud about the cluster prices.
Been talking to DanWA about one he has for sale.
I’m not really chasing an SLR cluster, just after one to fill the holes.
Or I just fill the center gauge hole with a engine temp/oil pressure gauge/display.
Auto meter speedo is in MPH.
Also they cut out the lower dash so the big gauges will fit in.
When all installed the lower dash cutouts are super visible.
#160 _LXT333_
Posted 06 February 2020 - 04:47 PM
Most complete I have ever had the dash. Most complete I have ever had the whole car really.
This is not spost to say weekend holiday.
Going overseas holiday.
Bloody phone.
#161
Posted 06 February 2020 - 09:28 PM
If your going to spend 1000+ on a cluster
There's so many better options of gauges than stock ones
#162
Posted 07 February 2020 - 07:34 AM
Hi Mick. I had an SL cluster and thought about upgrading but the price to buy a secondhand/unknown condition one was not viable. I ended up sending mine away to Classic Gauge Restorations. Wasn't cheap but I believe I got a virtually new cluster for the price i would have had to pay for an old one. I know he has done a lot of Torana clusters, as well as other old Holdens and Fords, as well as other makes. Maybe worth a phone call. Cheers Ron
#163 _LXT333_
Posted 07 February 2020 - 06:35 PM
I just want it to look like a complete dash, with lights that turn on with the headlights. Oil pressure light, water temp, fuel gauge or whatever they got in them.
I can deal with using the auto meter gauges I got (tacho,speedo,oil pressure,water temp) but I’m gunna need a fuel gauge.
Is a MPH speedo even legal?
Picked up new tierod ends this week, grease nipples in the side so it fits better (less grinding of caliper slides)with HQ calipers.
Also got a set of pedders subframe bushes and front upper and lower control arm bushes.
Basic list to get car drivable.
Rework aftermarket wiring loom that was already in the car.
Get front brake calipers to fit and give em a rebuild.
Exhaust from headers back
Fuel tank
Radiator and hoses
Trans lines and cooler.
#164 _LXT333_
Posted 07 February 2020 - 07:56 PM
Just checked the clearance with new tiered ends and didn’t need to grind so much off.
Also had to do a little grinding on the back of the stub axle.
Bushes ready to drop subframe this weekend.
I really want to do the whole strip and clean, repaint and rebush the reassemble.
CBF painting it, Maybe just slap some black on it if it doesnt rain all weekend.
It’s just gunna be a clean and rebush I think.
Added a pic so you Can see the hack job that was done on the dash a bit better.
Posted 07 February 2020 - 10:24 PM
MPH won't be correct for your year of car
They will likely pin you on that one
#166 _LXT333_
Posted 08 February 2020 - 02:54 PM
Another hurdle to trip over along the way I spose.
On another note. Dropping suspension subframe and noticed this.
Assuming these should both have a shroud over the subframe to chassis rubbers?
Both sides are the same.
#167 _LXT333_
Posted 08 February 2020 - 02:57 PM
I’m uploading these direct from my phone.
With this one I held the phone sideways and uploaded the pic.
Pic in last post held phone vertical and it uploaded it sideways.
Posted 08 February 2020 - 05:36 PM
No That's how they are
#169
Posted 08 February 2020 - 05:58 PM
And they need replacing do it now not later rubbers are cheap
#170 _LXT333_
Posted 08 February 2020 - 07:34 PM
That’s the reason I’m m dropping the subframe.And they need replacing do it now not later rubbers are cheap
Back ones are still good though
So got subframe pulled out.
Arms off, rack off, degreased and pressure washed.
Engine being held up by a car ramp and a a couple blocks of wood.
I’m up for a steering rack rebuild and brake caliper rebuild and the front end can all go back together.
#171 _LXT333_
Posted 08 February 2020 - 08:46 PM
Rusty and starting to bell out from being over tightened.
Are these available to purchase?
Pedders kit didn’t come with them.
Also steering rack bushes I got are wrong.
I got the Round ones with the flat spot.
There is obviously different steering racks in these cars.
#172 _LXT333_
Posted 17 February 2020 - 07:16 PM
Now to start reassembly.
Posted 18 February 2020 - 01:06 PM
Hi Mick
Bit of light reading below regarding the nolathane
Hate to see you tearing out all of this in the near future
Was all the rage when it first came on the market and bit a lot of people - including me
http://www.gmh-toran...hes-nolothanes/
http://www.gmh-toran...nolathane-fail/
http://www.gmh-toran...ont-end-bushes/
http://www.gmh-toran...athene-problem/
#174 _LXT333_
Posted 18 February 2020 - 08:22 PM
Hi Mick
Didn’t read them all front to back, but got the idea after flicking through them.
I thought I read somewhere that they had fixed the issues at nolathane.
These ones are from Pedders, not that it makes any difference I spose.
Thanks for the heads up, but I’m not going to replace these again. I just need to get this car back together.
I’ll replace them “When” they fail.
#175
Posted 18 February 2020 - 08:59 PM
Looking good Mick. FWIW One thing I forgot was to put in the bump stops that go on the underside of the UCA before I had it reassembled. Now having trouble getting one in. Cheers Ron
