My '76 LX Project
#276
Posted 06 June 2008 - 02:55 PM
#277
Posted 06 June 2008 - 03:14 PM
#278 _Barman_
Posted 06 June 2008 - 05:27 PM
#279
Posted 08 June 2008 - 01:00 PM
#280
Posted 08 June 2008 - 03:07 PM
It looks ok to me, just scuff the surface rust back. Your paintworks looking great.
Chears Neil
#281 _P51_
Posted 08 June 2008 - 03:25 PM
#282
Posted 08 June 2008 - 10:55 PM
P51 i used the exact same "system" but from a different brand. It was a KBS product. I thought id give it a go. Had no issues with the cleaner, and the paint itself is great, just the 'metal ready' step was where it turned to the shitter... I might try the POR stuff.Project is looking good mate.....POR have complete systems for rust prevention and prep. Very good products....try" Metal Ready", which conditions the surface with a zinc phosphate coating, and leaves the surface ideal for topcoat adhesion, also try "Marine Clean" prior to this step, it is an excellent degreaser/cleaner, it will emulsify/dissolve all oils... Its hard to say what, if any, problem you had doing your engine bay....What product did you use??
#283
Posted 08 June 2008 - 11:12 PM
#284
Posted 08 June 2008 - 11:15 PM
EDIT: but even the light rust that was under the brake booster is now turned rust colour... looking worse off then after i wire wheeled it
Edited by toryman76, 08 June 2008 - 11:17 PM.
#285 _P51_
Posted 11 June 2008 - 01:37 PM
#286
Posted 11 June 2008 - 01:59 PM
#287
Posted 11 June 2008 - 02:17 PM
Some go this colour, some go blue/green, some go black etc, depends on the acid use.
#288
Posted 01 July 2008 - 06:45 PM
first approach was to use Ranex Rustbuster and wipe off with a damp rag (as per instructions). this turned it to a bluey/whitey colour in which i still wasn't convinced was a nicely clean etched surface. then i used the same acid and instead of wiping of with water i used Prepsol to wipe the acid off and then a clean rag to wipe the prepsol off. Seemed to give a very clean looking surface (not bluey and discoloured). Ran out of time to etch primer it so hopefully no surface rust appears over night...
Posted 02 July 2008 - 03:05 PM
Its no show finish but I'm happier now it has some kind of paint on it. I never puttied the bonnet hinge welds though...
#290
Posted 05 July 2008 - 01:31 PM
#291
Posted 16 August 2008 - 01:41 AM
#292
Posted 18 August 2008 - 09:25 AM
#293
Posted 21 September 2008 - 12:50 AM
hang tight fellas
leigh
#294 _2wild4u_
Posted 21 September 2008 - 12:57 AM
#295
Posted 22 September 2008 - 04:22 PM
Les
#296 _doogs_
Posted 22 September 2008 - 06:54 PM
#297
Posted 29 October 2008 - 09:07 PM
doors next, will be sprayed then fitted and aligned (anyone got any little tricks for doing this?), hopefully this will be done in the next couple of weeks.
good to be back on here, the site has changed somewhat!
Posted 06 November 2008 - 08:19 PM
Posted 07 November 2008 - 10:07 AM
#300
Posted 07 November 2008 - 11:12 AM
