My LC 2dr project!
#51 _2runa_
Posted 13 May 2009 - 01:10 PM
Just another thought
Remember, heat shrinks, so stretch your tacks with a hammer & dolly; the same applies when finish-welding. After 5-10mm (as you get more experienced, you may decide to weld more at a time), set your gun down grind it back close and use your hammer & dolly....Respectfully . The object is to remove some of the shrinking you've caused by welding, while keeping your panel in shape. Don't stray too far from the weld to begin with. You'll find you can get your shape back if you patiently work the weld area first, and then address any peripheral warpage. Remember, if your panel fits well to begin with, you should be able to make it fit when you're finished, without resorting to drastic measures like a sledge hammer
again your doing well
#52
Posted 10 March 2012 - 01:29 PM
Guess I'd better start uploading some photos....
#53
Posted 11 March 2012 - 10:27 AM
The shrinkage around the flutes came out pretty good... but will still require a bit of filler later on...
#54
Posted 11 March 2012 - 10:42 AM
I had to fabricate front & rear mounting arms for the torrie...
Dropped the front & rear ends out, & up, up and away....
The torrie's new view of the garage....
The only real downside has been the lack of wheels to move it around... Perhaps on version #2 if the good lady wife lets me do another project...
#55
Posted 11 March 2012 - 10:51 AM
with the RH side feeling like paper mache where the crush tube should be fixed..
Will post some more pics soon....
#56
Posted 14 March 2012 - 08:09 PM
Made a piece to fill it...
and welded it up...
Once ground back, it looked pretty good...
#57
Posted 14 March 2012 - 08:24 PM
I had a large washer made by the local steel merchant, and welded it to the 2mm thick patch for the outside of the rail...
Cut off the rusted bit and welded on the new...
After soaking the outer section in a Deox-C bath for a few days... swiss cheese...
Patched the section in two places & made a new crush tube...
and covered it in POR-15...
Finally welded it back together...
I'll be treating the area with cavity wax once the car is painted.
#58
Posted 14 March 2012 - 08:34 PM
It wasn't too bad, but had some holes around the accelerator pedal pivot... so I bought a Rare Spares patch for it.
It will be finished off when the floor is prepped & painted.
More to come, but still uploading them...
Hopefully it's not picture overload????
Cheers,
Jeff
#59 _Liam_
Posted 14 March 2012 - 08:35 PM
#60 _mick74lh_
Posted 14 March 2012 - 10:08 PM
Mate they are some nice repairs. Very neat. Good Job.
^^^ What he said. Very neat mate. I wasn't actually aware of this project till now.
#61
Posted 15 March 2012 - 07:28 AM
#62
Posted 15 March 2012 - 12:03 PM
Thanks guys - much appreciated... Unfortunately I'm a bit anal @ times with the detail which can make things take alittle longer than they should...but I'll get there.
geez jeff it has been ages since youve shown anything on here you did the chassis rail about 12 or more months ago would be getting close to comming off the rotiserie now wouldnt it
Yeah, it was a while ago - just been alittle slack in posting updates. Should catch up in the next few days...
#63 _AD_75_
Posted 15 March 2012 - 03:58 PM
#64
Posted 16 March 2012 - 08:14 PM
Removed the remainder of the paint from the LH guard to start straighten out the wrinkles under to bog...
Getting better...
I wasn't real happy with the bottom secton of the guard after previously removing it, so I decided to do it again, but cutting higher up...
The patch required some altering of the line on the trailing edge, but was otherwise good...
I tried to get the join as even as I could to butt weld it with the Henrob & no filler...
It turned out OK - just required some stretching to get the line back out because of the heat shrinkage....
Also had to shrink above the flute insert to remove a slight bulge, probably due to over stretching around the insert + the previous damage under the filler...
The guard still requires more work above the flutes, but I'll tackle that latter when the final bodywork gets done. So on with some primer...
#65
Posted 16 March 2012 - 08:27 PM
& clean up around the flute insert...
and then some primer...
A little bit of work is still required later around the flute insert, but nothing major...
#66 _ljharbsy_
Posted 16 March 2012 - 10:04 PM
Steve
#67
Posted 17 March 2012 - 07:22 PM
It was a little rusty along the outer edges, but also had a large chunk of filler on the drivers side of the number plate...
Looks like a previous owner hit something substantial and it's gone right through to the engine bay... ???
After cutting the spotwelds along the rear join, I marked a line alone the front edge to cut off the bent panel...
After cleaning up the corners of the radiator panel, the holes with filled with the Henrob torch...
Also welded and cleaned up the split in the panel...
Trimmed up the Rares Spares front valance to weld it to what's left of the original...
Cleaned up the cavity...
and covered it with POR-15... ready to weld...
The panel was tacked into place along the front & two sides...
then fusion welded along the front & plug welded along the rear with the MIG...
Finished...
#68
Posted 17 March 2012 - 08:03 PM
Didn't look so bad from the outside...
but....
Crap on the inside....
Added some metal to the cutout section to fill the whole..
Some seam sealer on the top of the inner panel...
and on goes the section.
The repair turned out OK but was a fiddly pain in the a$$...
Pretty much the same on the left hand side....
#69 _Liam_
Posted 17 March 2012 - 08:37 PM
#70
Posted 23 March 2012 - 07:28 PM
A Pillars are pricks of things aren't they. Good work mate, glad it turned out well for you.
Thanks - Yeah, they have been the most fiddly pain in the a$$ bit so far. But we're not done.... :-)
Cheers,
Jeff
#71
Posted 09 May 2012 - 07:05 AM
Finally got back to uploading some more photos - hopefully won't bore everybody to tears...
Another spot that I wasn't real happy with my first attempt at a repair. I tried taking the minimalist approach and initially repaired the lower LHR quarter with two small patches. Not a real good idea as the bit I left in had pitting behind it, ending up in a crappy weld job as the thin portion just disappeared when I pointed the MIG at it... :-)
Off comes the bottom...
The Rares section is a good starting point, but required some adjustment of the profile @ the bottom of the wheelarch...
voila...
Cleaned up the inner panel whilst I was there with some POR-15....
Time to put it back...
The repair turned out much better second time around.
#72
Posted 09 May 2012 - 07:21 AM
I cut this out and made a little patch for it...
One less hole...
#73
Posted 09 May 2012 - 07:41 AM
I thought it would be best to do this before I removed the bottom portion of the RHR quarter in order to make sure the replacement secton is in the correct spot.
I cleaned up this section from the rear cut I purchased some time ago...
and removed the offending rusty bits...
Replacement section in place..
and oxy'd up.
#74 _BATHURST-32D_
Posted 09 May 2012 - 05:54 PM
when replacing the bottem of your guards with after market parts you will need to trim them to look like the original on the drivers side and dont forget the hole for the splat to screw back on, have a close look at them and you will see what i meen, many people dont fix this when they do this same job...
i hope i have helped you some.
keep up the good work.
cheers gong
#75
Posted 09 May 2012 - 08:51 PM
Thanks heaps for you nice comments and encouragement, they're much appreciated. I too can't wait to see another LC on the road as it's been a long journey so far, but I can see the light @ the end of the tunnel....
Wow, I never even noticed... I had to go out to the garage and take a look after reading your post! Thanks for the detail tip - always appreciated.
Also, thanks again for your help with the seat pivot bolts, they look awesome on the retrimmed seats (will post a photo soon).
Cheers,
Jeff
