LC 2Door S Project to XU1
#151 _squirralien_
Posted 29 March 2010 - 06:33 PM
I used POR15 on all my front end parts but its just under $100 per litre so its not the cheapest paint to use but if you can it is worth it, but just go for the main coat and don't worry about the clear coat, altho I apparently got a bit of a dud can of the clear. anyway good luck with it and try and take alot of pictures of your progress and start a thread like this one if you haven't and send me the link Id love to watch your progress.
#152
Posted 29 March 2010 - 07:15 PM
http://www.gmh-toran...=0
cheers Blakey
#153 _squirralien_
Posted 30 March 2010 - 12:53 AM
#154
Posted 05 April 2010 - 12:39 AM
Cheers Blakey
#155 _squirralien_
Posted 05 April 2010 - 01:04 AM
#156 _squirralien_
Posted 27 April 2010 - 10:17 PM
Here is a couple of pictures to show what my rear brakes look like at the moment
#157
Posted 02 May 2010 - 08:08 AM
#158
Posted 02 May 2010 - 12:10 PM
Did the diff centre receive as much attention to detail?
Anyway if everything is half as neat as that the car will be awesome
#159 _squirralien_
Posted 02 May 2010 - 12:55 PM
theres not much to understand, I just don't want anything going on the car unless its New, plated in zinc or chrome or painted, when i got to the rear brakes I just thought it would look good
with everything in colour instead of just cleaned metal that rusts, I know it will all be black before to long when its on the rd but I know its all done to a reasonably nice level
and it was a bit of fun and I really do like the red springs especially the small one on the yellow bar, they were jobs I was able to do when I was stuck looking after my daughter, The springs were so rusty looking so I cleaned them up on the wire wheel and they came up like new, then I knew they would rust again so on went the paint, at least I might be able to blow off the black crap and have reasonable looking brakes one day,, but theres no way I could get the springs on without a few scratches and I didn't brush touch them,,,,,yet haha
I never like to say rude things about someone's hard honest efforts... but I really can't understand that.
#160 _squirralien_
Posted 03 May 2010 - 01:52 AM
The next step is to put in the brake and fuel lines that go underneath for the length of the car, put the brake drums on and front pads in the calipers and then bleed the brakes and ill set up the steering coulomb and then its time to put it back on its wheels and put the engine in, now that will be a moment.
#161 _squirralien_
Posted 04 May 2010 - 12:49 AM
Today I finished it off and painted it and it looks just like they were never there,
I have a picture but its not very good Ill have to take a better one outside in real light,
black items don't seem to show up to well with a flash in a darker area in the shed
It actually looks better in the flesh than in the photo
Edited by squirralien, 04 May 2010 - 12:51 AM.
#162 _squirralien_
Posted 05 May 2010 - 05:36 PM
#163
Posted 06 May 2010 - 07:40 PM
Cheers Blake
#164 _squirralien_
Posted 07 May 2010 - 12:32 AM
#165 _squirralien_
Posted 07 May 2010 - 12:46 AM
mate things are looking good with your project!!
semi gloss paint code 04 149
Well I went to the paint shop and gave them the code and couldn't believe it when they said it didn't mean anything to them, I think he just wanted to do his own version,, I must say it does look great
he said they do the black for a restoration company and they use a satin black with a slash of white I think it was just to give it the slightly bluey black, not straight black anyway,, well I do like the result so quite happy with it, I think it looks great,
Thanks for the code anyway
Edited by squirralien, 07 May 2010 - 12:56 AM.
#166 _squirralien_
Posted 14 May 2010 - 12:34 AM
#167
Posted 14 May 2010 - 11:45 AM
keep the good work up !!
#168 _squirralien_
Posted 14 May 2010 - 12:18 PM
If it was I would consider it worth re doing the engine bay,,, infact I may possibly re do it anyway before the motor goes in that way I can't say I wish I did
glad your happy with your colour...some pics of 04 149
well I have found a distributor all ready and they are only about 13 minutes away,, unreal, I used to have an account with them many years ago,,
Thanks Johnno
Edited by squirralien, 14 May 2010 - 12:15 PM.
#169
Posted 14 May 2010 - 01:16 PM
I don't suppose that's the same colour for the paint outs on the outside is it
yes it is....
#170 _squirralien_
Posted 16 May 2010 - 02:18 AM
#171
Posted 16 May 2010 - 03:34 PM
Cheers Blake
#172 _squirralien_
Posted 16 May 2010 - 03:48 PM
If you get the alloy parts acid washed or material blasted the raw alloy will stain so easily so it needs a coat of paint or the other thing I would do if it was a show car would be to sand the complete alloy units to a smooth finish and polish them, but that's over board for my car, but that would look awesome better than shit hot
hey squirell, has your bellhousing and back of your gearbox been glass beated or polished? looks realy good the way it came up.
Cheers Blake
Edited by squirralien, 16 May 2010 - 03:49 PM.
#173 _squirralien_
Posted 18 May 2010 - 02:42 PM
here is a picture of what I found
#174 _squirralien_
Posted 19 May 2010 - 07:42 PM
He will also put a new plastic bit on, he recons the metal ones will end up rattling and the noise of the rattle will end up traveling up the gear stick and as I am not going to give the car a hard time by racing it or burnouts the plastic should be ok.
He also said it is likely to be an m20 as it only had a single groove in the shaft and the m21 had a dual or 2 grooves, I will check that all out tomorrow, he also said that some people convert them from V8 box's as well so he will tell me more tomorrow when I go there, He will probably charge me double just for all the questions I will ask tomorrow
#175
Posted 19 May 2010 - 09:37 PM
8 m20 to 6 m2o, 8 m21 to 6 m21
Edited by limo, 19 May 2010 - 09:39 PM.
