Not without its issues that takes time and money o course! Anyway so heres where i'm at.
I had issues with clutch fork hitting the back of the bellhousing and still putting a bit too much pressure on the fingers. I contacted CRS and asked for a shorter throwout bearing carrier than what was provided. This fixed my problem. Adjusted it up and bolted to the engine.
Had issues with starter motors too! I bought a cheapy off ebay, then heard too many horror stories about the casing being cheap and cracking so I bought a Bosch unit. Plus this Bosch had the solenoid on top, whereas the ebay unit had the solenoid on the side - was worried about the extractors fouling.
aaaaaaand, the expensive Bosch unit cracked upon torque!!! Why there is a cavity where the long bolt goes I have no idea - why can't it be solid!!!?!?
It's casting is identical to the cheap units!!!! So screw it, I put the cheap one on, torqued it up no worries! Plus the extractors clear the solenoid with ease!
Next was the new bearing for the steering column. My old bearing sheared from the plastic retainer and was flopping about on the knuckle underneath it.
Started with the outer tube.
Cut the excess, slid the bearing in, used rivets to stop it going up the tube (even though its a press fit, she aint going anywhere). I also retained the original clip to stop it falling out the bottom - should it ever.
Heater box seen better days
Thankfully I got the core tested and its perfect. Threw it back in with some new foam on the flaps and in it goes.
Engine in
Stripped all the wiring off the VN loom one by one. Turfed the wires I didnt want and repinned the ones I did into the connectors again (I hate spaghetti).
Still a work in progress, but ive separated into 2 sections. Interior and exterior wires - easy as
Chipped the edge of the door!! The front guard slid down a little bit and the door caught it when I opened it. So very carefully I feathered the edge of the chip down, used a razor blade to apply some fine filler to bring the level up, brush touched some epoxy, when that dried I carefully blocked it down and brush touched some paint. Once this sets up and I wet sand and polish it, it should be near invisible! Good fun
Edited by UCANG, 26 June 2016 - 12:07 AM.
