EH Drag car
255 replies to this topic
#101 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 14 May 2012 - 06:30 PM
not hard just VERY time consuming.
yes warren i turned him to the dark side hehe
#102 biga064
biga064
  • 196 posts
  • Name:Adam
  • Car:EH Holden
Posted 28 June 2012 - 12:35 PM
grant, yeh mate been there already, cheers, ill be at six banger nats next month if your coming out. yeah im 17 too haha.
adam, thanks man i have had pacemakers in there with no worries but these are 3 into 1 custom jobbies 1 5/8 primaries & 2 1/4 secondaries with half decent collectors on them. they are a bit tight around the eng mount and you can only just get a reduction starter out after 10 mintues of swearing and cursing. next pipes will just go through the inner guard :buttrock:
Hi Kevin Ive been doing other stuff around the home but im keen to get a good set of pipes for the Eh .Have you ever run or done any testing with the cast iron headers ? To see wether they work on a strong motor . I can see that they tend to be a little short for the scavenging process and drop off the port face to quick !!! thanks Adam
#103 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 28 June 2012 - 06:54 PM
Hi Adam, no sorry i haven't done any testing with them at all.
How much power are you making with the casties?
I have been busy as with this car as well.
Head has had a touch up and a bit of chamber deshrouding, new valve job.
I have moved the Head over .160".
Pistons are 2cc dish acl's, were 15 thou down the bore, now 10 out the top.
Compression should be from 10.7:1 to about 11.8:1. Yes, i gained 30rwhp switching from pump fuel to methanol with only 10.5:1 Comp!
Valves were 1.65 I and 1.43 E now 1.7 and 1.49.
And modded the extractor's.
So we will see how it goes! I have to keep my crown at 6 banger nat's, those pesky torana's will be back!
#104 biga064
biga064
  • 196 posts
  • Name:Adam
  • Car:EH Holden
Posted 28 June 2012 - 07:30 PM
Hi Kevin 170hp with the casties !!! Ive got 11.2.1 comp small chamber head flowing 192 cfm at 480 thou lift , 6 x 48mm throttle bodies , 3800 stall with a modified trimatic and ICE ignition . Car has run 14.2 at 99mph consistently with a GTECH in full street trim .
#105 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 28 June 2012 - 07:54 PM
Hi adam, you are doing well!!!
the problem is there are so many variables on a chassis dyno, that auto could be robbing 30hp.
99mph is not too shabby mate i know how heavy these whales are in full trim! what diff are you running?
i have struggled to get mine to 2550lb's. i have no doubt your EH will weigh 2900lb-3000lb with you in it!
how much duration does the camshaft have?
I wonder how well a set of HM9c's fit in an EH?
Edited by greens nice, 28 June 2012 - 07:56 PM.
#106 biga064
biga064
  • 196 posts
  • Name:Adam
  • Car:EH Holden
Posted 28 June 2012 - 08:25 PM
Hi Kevin,it runs a 3.9 ratio borg warner 28 spline with a lokka,cam 249 inlet 254 exhaust at 50 . Ive tried to fit a set of HM9cs but they foul in several places and wont go past the steering drag link (hr frontend) . Dyno was a mainline dyno with a good operater he told me that it was the strongest red 6 he had come across and he thought it would be making over 200 at the tyres with a manual .
#107 orangeLJ
Posted 29 June 2012 - 09:35 AM
We made just shy of 200hp with cast iron headers on the 202 in the track car (LJ 2 door) and ran a 14 flat @100mph at the last drag day (celica 4 speed, 3.55 diff, 15" wheels)
#108 biga064
biga064
  • 196 posts
  • Name:Adam
  • Car:EH Holden
Posted 30 June 2012 - 01:04 PM
Well I suppose the old EH is not to far off the pace ?? But how much could a real good set of pipes improve her ????????
#109 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 30 June 2012 - 05:26 PM
Warrenm ?? i think picked up .5? tenths on the strip with a set of handmande pipes over a set of Genie's.
#110 warrenm
warrenm
  • 2,129 posts
  • Car:1972 LJ Torana
Posted 01 July 2012 - 07:37 AM
i picked 3 tenths on the 1/8th after I fitted these pipes, no other changes.
Attached File  Headers (600 x 436).jpg   55.32K   4 downloads
#111 _Bomber Watson_
Posted 01 July 2012 - 09:28 AM
There uckin sexy.
Home made mate?
#112 warrenm
warrenm
  • 2,129 posts
Posted 02 July 2012 - 07:27 AM
Yes, I made them myself.
#113 _BuBsYsHD_
_BuBsYsHD_
Posted 02 July 2012 - 11:55 PM
They look good tune length ??
Edited by BuBsYsHD, 02 July 2012 - 11:55 PM.
#114 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 31 July 2012 - 07:29 PM
been busy as but im not going to make it to the 6 banger nat's, other stuff has gotten in the way, but i will give it a shot.
i have found a bloke who makes Fibreglass panels for EH's so the plan is to get another mudguard (i already have one) and a bonnet, still deciding on the boot lid. Fibreglass bonnet should lose a tonne of weight.
and a set of wheel's is on the card's soon, the steelie's on there now weigh 13kg's each!
Final comp ratio has come out to 11.6:1.
the crank the flywheel has had 2 interference fit 3/8 dowel's put it in. used the ? tonne press to get them in and it struggled!
Edited by greens nice, 31 July 2012 - 07:33 PM.
#115 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 13 October 2012 - 05:25 PM
glass bonnet and two mudguards weigh just 15kg, theres a glass bootlid on its way as well
Edited by greens nice, 13 October 2012 - 05:25 PM.
#116 orangeLJ
Posted 15 October 2012 - 03:28 PM
Nice!
#117 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 02 June 2013 - 09:32 PM
got my 9 port flowed @ 28", not bad.
#118 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 02 June 2013 - 10:26 PM
this is with EVL Black 1.68 & 1.44 valves.
#119 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 26 October 2013 - 10:41 PM
Well, the fibreglass boot lid, bonnet and mudguards are on and we've had a paint job!
Had some water leak's with my 9 port that deemed it unusable, so jammed the engine out of the FJ in it to make the 6 banger nat's.
It also got a another roller cam in it at the same time, pretty soft but 268 @ 50 & 550 lift.
my Gearbox and diff ratio's were way too tall for this cam, went 7.88 @ 88 mph doing 6500rpm over the line, cam doesnt start workin till 7000!
60 ft timers weren't working, but it felt like it got out of the hole better when it spun the tyre 1 - 2 times on the hit so i have some tinkering to do here.
Edited by greens nice, 26 October 2013 - 10:43 PM.
#120 _Agent 34_
_Agent 34_
Posted 27 October 2013 - 07:09 PM
kevin,
that's pretty awesome stuff.
#121 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 21 April 2014 - 06:34 PM
Thought i should update this, new engine is in the hole.
Its a 202 with a blue 173 head I ported, SFT and Weber's on Petrol.
It has a tiny 9 port manifold on it that needs to be changed when i get the courage to cut the firewall.
same dyno I've always used, it still made more power than the old 9 port engine on meth.
I'm going racing on wednesday at a test n tune, so i will report back.
#122 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 21 April 2014 - 06:50 PM
https://www.facebook...&type=2
And a dyno run, sound quality is pretty bad
#123 warrenm
warrenm
  • 2,129 posts
Posted 22 April 2014 - 07:11 AM
Well done. What sort of HP did the previous motor get?
#124 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 22 April 2014 - 10:37 AM
The last one made 250 on meth, I'll be swapping this one over to alky after 6 banger nats
#125 SA EH
SA EH
    Another Holden 6 tragic
  • 1,050 posts
  • Name:Jonesy
Posted 24 April 2014 - 01:03 AM
Great thread Kev, I've got a long way to go.
Very impressive numbers coming out of those engines mate, what's the most you've made from a solid cam?? - I've lost track of which one has what!
