yep the bp avgas is green and the shell stuff is blue
EH Drag car
#151
Posted 29 April 2014 - 06:22 PM
#152
_ljxu1torana_
Posted 29 April 2014 - 09:59 PM
yes kevin,mine was bp.a friend of mine was a manager in the enginnering business @ airport.$30 for 20 litres.now my friend works in the same business up in darwin.
i am thinking of using acetone.has anyone done this yet?
#153
_Ned Loh_
Posted 30 April 2014 - 08:02 AM
Top result!
Apart from top end hp, how do the curves look comparing the 9 port to the 12 port? Assume similar outright flow???
#154
Posted 30 April 2014 - 08:04 AM
Love yer work, Kev.
#155
Posted 30 April 2014 - 05:41 PM
Thank's guy's, not sure Ned the gears are slightly different, was 4.56 and 3rd gear, now 5.0 and top gear.
Just by feel the two engines are worlds apart.
The Webers came straight off the 9 port engine with 165 main jet's which were correct, with the 12 port it now has 145's and the a/f is still around 11.5, so i will buy some more jets before i go back to the dyno.
But i think it's really because the carb's are too small even with 40mm chokes.
#156
Posted 30 April 2014 - 07:10 PM
Im pretty new to webbers but i would think 45-48mm would be more suitable for a 12 port?
_ljxu1torana_
Posted 30 April 2014 - 08:54 PM
i have a 48mm weber on mine.webers are the closest thing to mechanical fuel injection.THE BEST CARBY FOR DRAG RACING IN A HOLDEN 6.
#158
Posted 30 April 2014 - 09:19 PM
( or a single 52mm Delorto ) is that right Jason,
Nice to know, I will have to do a test. Dave I
#159
Posted 30 April 2014 - 10:01 PM
I'm thinking about making a tunnel ram for a couple of pro systems holleys, any of the US record setting cars have that setup, and for good reason.
#160
Posted 30 April 2014 - 10:31 PM
When you said Pro Systems Kevin, I think this
#161
_ljxu1torana_
Posted 30 April 2014 - 10:42 PM
ok.i am referring to holden 6 only.on my turbo set up i have 1, 48mm weber carby.for the turbo set up only take a look @ the ngm stratta set ups back in the the days.there basic combo was with 1 su carby,there all out race combo was with the weber carby.i know this topic is about your eh kevin.
#162
_ljxu1torana_
Posted 30 April 2014 - 10:45 PM
Sorry Jason IR is totally different to a draw through setup.
i know that that you are a proud man about using a manual.have you thought about the auto route.as it is a race car only.jmo
#163
Posted 30 April 2014 - 10:49 PM
I am a Manual Man myself,
no matter how good an auto is,
our fingers are taught to flick the shifter well, except when we miss. DaveI
#164
_ljxu1torana_
Posted 30 April 2014 - 11:14 PM
yes dave i am a manual man myself,my torana has a built trimatic so i did not have a say in it
#165
Posted 30 April 2014 - 11:18 PM
not bad at all Jason,
now rip the auto out before someone see's it, only kidding. Dave I
we all have some kind of thing to be different, and try to make that work, hey
#166
_ljxu1torana_
Posted 01 May 2014 - 12:00 AM
yes mate i understand what you are saying.if you give most of the quick auto powered street cars in this country a manual there cars will not be a quick.
#167
Posted 01 May 2014 - 12:04 AM
ha ha Jason, well said, gees, I have been is some quick Auto's,
but I am happy, at least we can rip clutch Plates apart. Dave I
#168
Posted 01 May 2014 - 07:13 AM
Bleeders are for tow cars.
#169
_stretchlc_
Posted 01 May 2014 - 02:05 PM
45 year old NGM catalogues huh?.............Nothing has improved in 45 years either right?......what a load of bollocks seriously!
I peruse those old catalogues and laugh Jason.
#170
_ljxu1torana_
Posted 01 May 2014 - 08:06 PM
what drugs are you on there stretch,where did i say about better technolagy,i am talking about carbys here.you will never convice me about su, holleys are better for performance than a weber 48mm.
#171
Posted 01 May 2014 - 08:25 PM
#172
Posted 01 May 2014 - 08:30 PM
We Need a Voting system for Carby Systems and other Systems, can have up to 10 different choices hey, as you all already Know. Dave I
who is going to start it
#173
Posted 01 May 2014 - 08:32 PM
Sure Jason will, and every choice will be a 48mm webber....
Then he will start a compression ratio thread and ever choice will be 3.2:1....
_ljxu1torana_
Posted 01 May 2014 - 10:25 PM
when it comes to turbos
#175
_ljxu1torana_
Posted 01 May 2014 - 10:31 PM
give me a pair of jumper leads and i will start everything.
