EH Drag car
255 replies to this topic
#201 _Bomber Watson_
Posted 14 June 2014 - 05:13 PM
YOu can have the 9 port your doing for me if you buy me a JZED?
#202 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 14 June 2014 - 05:43 PM
Doesn't seem fair to me DJ !!
I'm going to see if I can get it spray welded, fail that, save my pennies for a jzed
#203 _Bomber Watson_
Posted 14 June 2014 - 05:53 PM
Na mate trust me, deal of a lifetime.
#204 _2ELCS_
_2ELCS_
Posted 14 June 2014 - 07:38 PM
^^^^Sound like a used car salesman ?
#205 SA EH
SA EH
    Another Holden 6 tragic
  • 1,050 posts
  • Name:Jonesy
Posted 14 June 2014 - 10:18 PM
RIP....
Pulled the intake off this morning to swap it with the bigger one, it's developed a hole in no6 intake port, it wasn't there a week ago.
Looks like we're back to square one.
Spewin Kev, what a pisser.
Dont you have an old 9 port hanging around that you pulled off this engine earlier?
But im guessing there's no point going backwards hey!
Onwards & upwards mate, make it alloy & make it awesome :buttrock:
#206 warrenm
warrenm
  • 2,129 posts
  • Car:1972 LJ Torana
Posted 15 June 2014 - 07:45 AM
Water injection.
Get out the Devcon.
#207 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 17 June 2014 - 12:51 PM
The old 9 port expired awhile ago, I moved it over a stupid amount and the head studs were pissing out.
Retorqued the head 6 times chasing leaks and it broke the casting, lesson learnt.
The other 9 port engine with the roller cam is still together but the block is worn out after 20 years of use.
It definitely cannot be welded so going to try some Belzona 1111 epoxy, which looks to be the ducks nuts for this sorta stuff.
#208 warrenm
warrenm
  • 2,129 posts
Posted 17 June 2014 - 11:58 PM
Haven't used this stuff, but looks like a similar product to Devcon.
#209 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 10 July 2014 - 05:44 PM
I sent the head out to get welded, the magician's put it in a furnace and welded it with an oxy and some sort of cast iron welding rod ! It pressure test's fine and has been crack tested and we are all good !!!!!!  :rockon:
They seem to have done a really good job, there's only .004-.005 warp end to end  :dontknow:
It's being machined at the moment but hopefully i'll have it running next weekend.
I'm upping the spring pressure too as i believe that my misfire is valve float, bumping it up to 165lb's @ seat and 385 open
Edited by greens nice, 10 July 2014 - 05:44 PM.
#210 _datpsi_
_datpsi_
Posted 11 July 2014 - 10:12 AM
That's amazing that was able to be done. ... Is the above in WA able to perform surgery like that? haven't got a damaged head yet fingers crossed but interesting if my cracked block can be saved in same manner!
#211 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 12 July 2014 - 11:17 AM
I wouldn't try doing a block, it would distort way too much.
Would need a line bore too so much cheaper to just prepare a new block.
Maybe try pinning/crack repair plugs??
Picked the head up from the machine shop and valve springs will be here Monday
#212 warrenm
warrenm
  • 2,129 posts
Posted 19 July 2014 - 07:47 AM
What did the head end up flowing Kev?
#213 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 19 July 2014 - 11:10 AM
Only had it in a 10" bench, I'll stick a sheet up when I get home.
I went some like 126 cfm at .500.
#214 warrenm
warrenm
  • 2,129 posts
Posted 19 July 2014 - 05:33 PM
So that should be 210cfm @ 28", if I'm working it out correctly.
#215 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 19 July 2014 - 06:23 PM
Doesn't flow that great, but has the cross section for my rpm range.
#216 _rb3torana_
_rb3torana_
Posted 22 July 2014 - 07:52 PM
What cam and comp did it have when it ran the 12.1? Cheers
#217 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 22 July 2014 - 10:27 PM
12:1 comp
Comp xtq 6267 on the intake
Xtx 6420 on the exhaust
107 separation
105 centerline
The same combo is going back together
Edited by greens nice, 22 July 2014 - 10:28 PM.
#218 _rb3torana_
_rb3torana_
Posted 23 July 2014 - 07:36 AM
Cheers mate, nice and big :D .
#219 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 23 July 2014 - 09:19 AM
That's with 1.6 rockers as well
#220 _rb3torana_
_rb3torana_
Posted 23 July 2014 - 10:20 AM
How did you go with piston to valve clearance?
#221 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 23 July 2014 - 05:26 PM
No problems with piston to valve clearance, plenty of issues with valve to block clearance though.
#222 _rb3torana_
_rb3torana_
Posted 25 July 2014 - 07:20 AM
Thats good to know cheers, are you still running stock blue rods with bolts and castys? 8000rpm? when that first conrod failed did it look like it had picked up and then chucked it or just rod bolt fatigue? just trying to work out whether I should go to the trouble of putting 1 and 7 main external lines lol. It also looks like your running single springs?  sorry for the 21 questions lol. Cheers
Edited by rb3torana, 25 July 2014 - 07:25 AM.
#223 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 25 July 2014 - 01:09 PM
That's fine I need to write out a list of engine spec's anyway's.
The rod blowup, was actually piston failure, the piston separated around the wrist pin.
They were old repco repower piston's, the whole engine was pieces together with shit we had in the shed.
Valve springs were pac beehive's, 1211x had 140lbs closed & 370 open but was nowhere near enough.
Has 165lb closed & 402 open now, so see how we go.
This donk has blue motor rods and JE forgie's.
I've spun blue rods & acl duralites to 8200 but I think that's pushing the friendship.
Both with ARP bolt's fitted.
No need for the external line's, I do a lot if internal oiling mod's but.
Ext pickup is a must, -10 or -12 hose
#224 _rb3torana_
_rb3torana_
Posted 25 July 2014 - 01:53 PM
Cheers mate thanks for the info. :)
#225 warrenm
warrenm
  • 2,129 posts
Posted 26 July 2014 - 07:09 AM
Plenty of oil in the sump ALL the time & not in the rocker cover too.
