EH Drag car
255 replies to this topic
#126 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 24 April 2014 - 03:56 PM
Thanks jonesy, my own engines have all been flat tappet's, i made 250 on meth with the 9 port combo and now the 259 with this eng with a 12 port and weber's.
https://www.facebook...er&notif_t=like
So i went racing last night, car is still in one piece so that is a positive.
It's developed a misfire at 7200rpm which i think is spark/electrical, you can slightly hear it in the 1st-2nd & 2nd-3rd gear change, so i was just shifting at 7000.
Wouldn't even go past 7200 in the burnout.
I changed the gear's from 4.56 to 5.00 and now i can't get it to hook !! I've also bent the slapper bars for the 3rd time.....
thinking of trying some of these http://www.srdparts....uemart&Itemid=1
hoping to run some more mph when i fix the miss as i was crossing the line at about 7100 when it starts to go flat/miss.
but the best et was 12.15 and best mph was 109.7, went 1.68 to the 60 and has been 1.55 previously.
#127 SA EH
SA EH
    Another Holden 6 tragic
  • 1,050 posts
  • Name:Jonesy
Posted 24 April 2014 - 06:19 PM
LOVE the revs! Sounds awesome mate.
That rear end traction set up looks a fair bit different to caltracs, but just the next thing to do hey!
Do you do all you're own head porting??
#128 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 24 April 2014 - 07:25 PM
yeah i think the SRD bars will be a bit easier to fit, less mod's to the front spring eye mount.
I port my own heads yes, had a bit of help at the end from my mentor with this one, seems to work alright  :spoton:
#129 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 24 April 2014 - 09:22 PM
pretty good price on those SRD bars too,im keen for a set for my hd. What Rear leaf setup are you running at the moment Kevin?
#130 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 24 April 2014 - 09:44 PM
Just EH ute springs with 2 leaves removed, I turned up some alluminium bushes for the front spring eye.
Keen on a set of Calvert split mono leafs but they wont be cheap by the time you get them here.
#131 warrenm
warrenm
  • 2,129 posts
  • Car:1972 LJ Torana
Posted 25 April 2014 - 07:43 AM
How much air gap are you using between the end of the slapper bar & the spring eye?
SRD traction bars look Ok.
Your giving me some big numbers to chase at the 6 bangers later in the year.
You need to hold the right pedal hard on the floor through the gear change, don't lift. :stirpot:
#132 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 25 April 2014 - 10:29 AM
they have about 5mm gap, I've tried them with gap's and preload and nothing really helps, pinion angle is 6 degrees.
hehe yeah i still have to beat the purple lc, i think he ran 7.5* something on the 1/8 last year i went 7.68 last night.
I think that's the gearbox's fault, it doesn't like to change gears when i hold it flat  :Headbang2:
Why do we insist on doing it the hard way with coggers !?! :dontknow:
#133 _Bomber Watson_
Posted 25 April 2014 - 10:54 AM
Because unlike low life little girls like myself who have tampon despensers mounted just below the Innovate LM-2, you are a manly man who's manlyness dictates you must have the manlyest of all pedals and a manly stick that not only moves in the girly up down direction but also moves in the manly side to side direction. .
Or some shit like that i've been told.
Jokes aside, i'd be ludicrously keen to see how much faster you went with a nice transbraked manualized tri with a suitable converter.....But we all know your not going to try that.
Edited by Bomber Watson, 25 April 2014 - 10:54 AM.
#134 warrenm
warrenm
  • 2,129 posts
Posted 25 April 2014 - 11:35 AM
It's not the hard way, but practice makes perfect.
Is that 5mm with you sitting in it?
Maybe the rear shocks are a little questionable?
Is that 6° down from the crankshaft centre line?
The oil is to slippery for the syncro's, so you have to granny shift. Try a SAE 30 gear(mineral) oil that meets GL-4, that might help it shift.
#135 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 25 April 2014 - 12:36 PM
5mm with me in it, the rear shocks are QA1 single adjustables, Calvert 90/10's up front.
yep 6 degree's down from the centerline.
you could be onto something it has a 75-85 penrite synthetic in it at the moment.
tell ya what dj pull the bleeder and all ya gear out of toy-202 and i will test it out for ya !   :tease:
but this is what tickles my fancy http://www.racingjun...-trany-4-1.html
#136 _Bomber Watson_
Posted 25 April 2014 - 12:40 PM
Howard broke a dough nash with a measely big block.
A 202 would decimate one methinks.
Wouldnt you be better off with something with dog shift?
How keen are you on testing the bleeder? I wont be using it for a while....
You might have to owe me one though, wink wink....
Edited by Bomber Watson, 25 April 2014 - 12:40 PM.
#137 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 25 April 2014 - 12:54 PM
yeah but i still can't manage to bust a w series supra box so i think the nash will be fine.
dog shift would be good but price tag comes with it and i can't really afford a $3000 clutch.
hmm i dont know, I've just finished building the car after 3 year's, I'd like to enjoy it a little first before i go ripping it apart again  :lol:
#138 _Bomber Watson_
Posted 25 April 2014 - 01:00 PM
I resemble that statement.
#139 N/A-PWR
  • 9,642 posts
Posted 25 April 2014 - 04:39 PM
yep, enjoy it till it dies, and then rip it apart Kevin
#140 warrenm
warrenm
  • 2,129 posts
Posted 25 April 2014 - 05:50 PM
A Muncie with M22z ratio, Fuchs TO4-10 & It'll "flat shift" :rockon:
#141 _ljxu1torana_
_ljxu1torana_
Posted 25 April 2014 - 08:21 PM
are you using meth on a 11.1c/r.just a question
#142 _Bomber Watson_
Posted 25 April 2014 - 09:34 PM
He said earlyer pump gas.
#143 _ljxu1torana_
_ljxu1torana_
Posted 25 April 2014 - 11:51 PM
ok,so all of his times of late are done with pump gas?
#144 _Bomber Watson_
Posted 26 April 2014 - 09:01 AM
Thats what he said a few posts up.....
#145 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 26 April 2014 - 12:10 PM
yes jason it's been running on avgas lately, but i will be switching back to meth soon.
i ran meth on 10.5:1 comp and it made a huge difference.
#146 _ljxu1torana_
_ljxu1torana_
Posted 26 April 2014 - 04:05 PM
what octane rating is the avgas?
#147 warrenm
warrenm
  • 2,129 posts
Posted 26 April 2014 - 04:08 PM
Avgas should be 100 octane minimum.
#148 _Macca97_
_Macca97_
Posted 26 April 2014 - 04:33 PM
and it goes all the way up to about 130 octane i think.
The EH sounds awesome kev
#149 N/A-PWR
  • 9,642 posts
Posted 26 April 2014 - 06:55 PM
Yep,
and Air Force AVG Gas is 112 Octane last I seen, which makes your Carby/s go Green. Dave I
#150 _ljxu1torana_
_ljxu1torana_
Posted 29 April 2014 - 04:33 PM
i have had 130 octane avgas,it was green in colour.it is the sweetest smell ever.
