Clints LH Project
#76 _2wild4u_
Posted 10 April 2010 - 11:16 PM
#77 _Viper_
Posted 16 May 2010 - 03:16 PM
Also fitted my Billet Ignition lead covers as well as a Stainless steel bolt set for the Intake manifold
Stainless steel Washer bottle (with motor hidden underneath)
Polished Alternator bracket with bolts matching the intake manifold
And engine bay as is, oh also got a Chrome thermo housing and Stainless steel Rad hose
I will get the Intake manifold ceramic chrome coated next time it comes off (to be drilled for larger injectors) Also want a chrome wiper motor and then I think its pretty much done, oh cept the Procharger at a later date
#78 _2wild4u_
Posted 16 May 2010 - 11:25 PM
#79 _Viper_
Posted 17 May 2010 - 09:28 AM
#80 _2wild4u_
Posted 18 May 2010 - 11:47 PM
#81 _Viper_
Posted 19 May 2010 - 01:03 AM
#82 _Viper_
Posted 19 May 2010 - 07:59 PM
So off to bunnings and grabbed a length of 30mmx3mm Flatbar and whipped up a little stand/base for it, Welded a couple of nuts to the bottom of the bracket for the hold down clamp to bolt into and all works pretty good... only negative is that I cant remove the battery from the box while its in place but thats not really a problem just means I goto pull the box out with the battery inside and I dont really plan to be putting the battery in and out too often.
Just goto weld the bracket to the floor and give it a coat of paint
Edited by Viper, 19 May 2010 - 08:00 PM.
#83 _Viper_
Posted 06 January 2011 - 09:35 PM
Actually only took me a couple hours to finish off just aint touch the car in that time, But watch this space... Im on holz till Feb so plan to get alot done.
#84 _Viper_
Posted 07 January 2011 - 09:19 PM
I bought a set of rusty doors as I was missing alot of the internals so been busy putting my doors back together, Dam those bailey channels are a bitch, anyone got any tips? altho Ive almost finished
Also trimmed the tops of my doors with the same Black velour as the roof lining
And I had the rear seat trimmed a couple months ago... Tired to get the same material as the front seats but the supplyer doesnt sell it anymore so had to settle for something a little different (black and blue pattern) but I think it turned out alright
Also spent bout an hour trying to work out why the headlights were not working! drove me nuts but turned out to be one of the terminals on the UC dipper switch on the steering column was touching abit of metal and shorting it out
Im just happy stuff is actually being done on it
#85 _Liam_
Posted 07 January 2011 - 09:28 PM
Your set up looks ideal. Good work by the way, I might PM you about your brake set up if you don't mind.
#86 _Viper_
Posted 11 January 2011 - 04:23 PM
Now I can give it a wash! Altho I did have some trouble with the rear doors and its still an issue, more info can be seen here: http://www.gmh-toran...29
All thats really left now is fit the carpet, Make up a parcel shelf, Fab some front seat brackets, Fab a dash facia to suit my Dakota Digital Dash, double check all the wiring and tidy up last couple of things then its off to the Dyno!
#87 _Bomber Watson_
Posted 11 January 2011 - 05:04 PM
Posted 11 January 2011 - 05:06 PM
She's lookin sweet!
#89 _Viper_
Posted 12 January 2011 - 07:28 PM
So using the stock dash to get me a rough outline I cut a piece out, and after some careful trimming and sanding got it to fit quite snug and then I cut the hole for my Dakota Digital Cluster...
I had marked a centerline on the lower dash panel just using the steering column opening to work it out while it was out of the car... But once I actually fit the cluster it became apparent that this isnt actually center, and the steering rack comes out at abit of an angle so ill have to move the hole over about 10mm to the drivers side. (looking at the pic use the steering wheel mounting spindle.. thats center) But thats ok isnt hard to cut a new one out now that I have a template
Once this peice is finalised Ill start welding in some mounting plates behind the dash, Think I will just have 8 allen key button head bolts evenly spaced to hold the front panel down... Unless I can think of a way to have the bolts hidden or something?? I suppose I could make it like a door trim and just have those plastic plugs to hold it on? It fits pretty snug as is so should be enough to hold it in place... Altho I dont think button head bolts would look bad either... Also need to think of something to fill in the rest of the dash... 4" LCD screen? aftermarket heater vents? (since I deleted the 2 stock ones) or maybe just some nice cup holders which slide away into the dash... decisions decisions
#90
Posted 12 January 2011 - 08:26 PM
I'd have the bolts/screws external and try to make them part of the design, especially if you're going to use some sort of metal (maybe alloy sheet?) - you could possibly make them a feature by etching some sort of line around the edges similar to an original style dash. If button heads don't work then stainless countersunk allen or even philips head screws would look good I reckon.
#91 _Viper_
Posted 12 January 2011 - 09:29 PM
Actually was really easy/quick the 2nd time as the template was sorted...
Feel free to photoshop the next pic and add whatever to make it look better... Can send full res version if anyone is keen
I did a quick one with allen key button head bolts.
#92 _Liam_
Posted 12 January 2011 - 09:34 PM
#93 _Viper_
Posted 12 January 2011 - 09:51 PM
#94 _Liam_
Posted 12 January 2011 - 10:09 PM
Cross section of a J Mould*.
I
I_I Imagine as a continuous piece of metal.
Small side goes to the front as a stainless display, the big side, you can fabricate or get some good high grip push clips and tack them to the back of it.
Hope you understand may not be clear enough though?
#95 _nicko61_
Posted 12 January 2011 - 10:34 PM
#96
Posted 12 January 2011 - 10:56 PM
You could have a look at making the panel from 3 or 4.5 mm black leather grain ABS plastic. It is a reasonably close match to the grain in the dash. Mainline Plastics will usually cut sheets to the size you require.
I would also try photoshopping the aluminium panel anodised black or maybe black in the ball milled groves.
Edited by ls2lxhatch, 12 January 2011 - 11:00 PM.
#97
Posted 13 January 2011 - 05:31 AM
Black would definitely be better on the dash of course, the plastic idea is good if you can reinforce it and its cheap enough, would have to cost less than machining aluminium
#98 _Viper_
Posted 13 January 2011 - 11:20 AM
or maybe just polished...
#99 _Liam_
Posted 13 January 2011 - 12:12 PM
#100
Posted 13 January 2011 - 12:33 PM
